1st Gen Tacoma Bolt On Outboard Shock Mounts
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by nzbrock, Apr 12, 2025.
  1. Apr 12, 2025 at 12:42 PM
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Up for sale is a set of rear bolt on shock mounts for a 95-04 Toyota Tacoma. These bolt onto the rear cross member bolts and move the upper shock mounts outside of the frame rail. I prototyped these and have been using them on my truck since March 2023. They come with 5/8” ID bushings for the upper studs as well as a Toyota pickup lower rear shock mount that installs on the passenger side. You will reuse one of your stock lower mounts on the driver side. There are only two sets of these in existence, the other one is on my truck. Go here and read all the details if you are interested: https://www.tacomaworld.com/threads/feeler-1st-gen-tacoma-bolt-on-outboard-shock-mounts.794657/
    These require wheel spacers to clear tires at full articulation. I have various other shock bushings if you need them to go with this.
    $300 plus shipping
    TRD493, chrslefty, C_tanner and 2 others like this.
  2. Apr 12, 2025 at 2:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Nice work, ever going to put these into production?
  3. Apr 12, 2025 at 2:40 PM
    nzbrock
    Noah
    San Marcos, TX
    Really just depends on interest, If people want them then I will make them
    Reh5108[QUOTED] likes this.
  4. Apr 13, 2025 at 4:57 AM
    Reh5108
    Idaho
    Being that it's 100% bolt on I bet there would be a fair amount of interest from those who can't or don't want to weld.
  5. Apr 13, 2025 at 3:14 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    What about if using wheels with very low offset?
  6. Apr 13, 2025 at 4:53 PM
    Madjik_Man
    Colorado Front Range
    This is sick.
    kctmet likes this.
  7. Apr 13, 2025 at 5:04 PM
    nzbrock
    Noah
    San Marcos, TX
    I'm running the following right now:
    16”x7.5” 15mm offset TRD FJ Trail Team Wheels
    1.25” Wheel spacers
    265/75/16 Cooper Discoverer Road + Trail
    (Previously had 255/85/16 Cooper ST MAXX)
    With the MAXXs I had 3/8" between the shock body and the side wall. I have not measured with my new tires.
    Based on that information, you could probably get away with 1" wheel spacers with the same wheel/tire combo. Or same wheel specs with at least -10mm offset.
    Changing the wheel width will change those numbers. Say you had 16x8 wheels, you would need at least -17mm offset without spacers.
    SCS F5 16x8 with -25mm offset would work without spacers, for example. There aren't that many wheels that have that negative of an offset though.
  8. May 1, 2025 at 5:07 AM
    nzbrock
    Noah
    San Marcos, TX
  9. Jun 1, 2025 at 2:22 PM
    nzbrock
    Noah
    San Marcos, TX
  10. Jul 28, 2025 at 8:29 AM
    nzbrock
    Noah
    San Marcos, TX
