1st gen Tacoma clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itstaco, May 12, 2017.
  1. May 14, 2017 at 5:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My manual has 2.6 qt listed for the 3rz 4x4 trans.
  2. May 14, 2017 at 6:19 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    About $110 iirc. LCE also has the same set up for $10 or so cheaper. I would definitely put a new shifter bushing in while you're doing the job. It'll make your shifts much smoother and they're only $10-12. This what my old one looked like next to the new one
  3. May 14, 2017 at 9:00 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    And not sure if you have a 4 or 6 cyl, but be careful of your oxy sensors while yanking and stabbing. I broke mine doing my clutch. Thank god for aftermarket warranty and cool service advisors
    erice and Dalandser like this.
  4. May 14, 2017 at 9:03 PM
    Wulf
    rock raisin
    no but it might be, my left leg is noticeably bigger than my right :D
  5. May 15, 2017 at 7:41 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    I went with Aisin. did the TG kit and got the flywheel refinished locally (it didn't appear to need to be replaced)
    Wound up just pulling everything back with a tranny jack like someone mentioned above, twist and pull (think its clockwise towards passenger if i remember correctly).
    Clutch was a bit heavier than before but it grabs great on and off road. Granted i think when i got the truck the clutch was going out already (started smelling burny) so it could have always been that heavy like someone mentioned above having it feel like a new oem clutch. It can be a little grabby if i'm not paying attention but i find it handy off road.
    A marlin short throw and bushing like the one Boosted posted above are next on the list. hear nothing but good things about them.
    Good luck OP, Be thorough and don't rush it. Also good idea to have a helping hand if you haven't done something like this before.
    skycamper and boostedka like this.
