1st Gen Tacoma EMP?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sandersgtn, Dec 13, 2024.
  1. Dec 13, 2024 at 6:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I mean the ECU is going to be the most important. There's not much you can do to isolate it however. I suppose you could put a Faraday cage around it
  2. Dec 13, 2024 at 7:06 PM
    sandersgtn
    sandersgtn [OP] Active Member
    I'm thinking to buy and protect a correct backup for the ECM. Want input on other electrical components that need similar backup/protection and replacement for EMP.
    ECM seems obvious. Relays, fuses, other essential solid state components??
    Thx
  3. Dec 13, 2024 at 7:21 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    There are some uninformed statements being made but that's to be expected.
    Glad the op had the balls to ask questions. Many if not most informed people can see modern warfare as such a possibility if not probability.
    The more one eyes are open to digest a few facts on EMP, lets just say "lightning high voltage strikes" the less sarcastic and vocal they need to be.
    OP's post is simply a curious one.
    7.3 idi is a great diesel but still alot of electronics to fry on a high voltage, lets call it a "lightning strike". A mechanical IDI diesel (early Mercedes, MKI MKII VW non TDI diesel, non U.S. early Toyota, Mitsubishi diesel will run off its own old oil.
  4. Dec 14, 2024 at 10:23 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    A basic relay is still susceptible to destruction.
    The only possible protection I can fathom is totally isolating your entire electrical system from the body of the vehicle, and wrapping every component in a dielectric/air gap, fully enclosed in another isolated frame (such as a Faraday cage), and grounding that. A theoretical EMP would hit the chassis and induce it's own eddy currents, which would hopefully block a high level of the initial pulse before re-radiating its own, to where your cage would "absorb" it. Think of it as air locks.
    You're chasing fairies here.
    0xDEADBEEF and Speedytech7 like this.
  5. Dec 14, 2024 at 10:24 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Man, I cannot think of anything critical on my FORD IDI that would prevent it from running in the event of a lightning strike, other than glow plugs. Mechanical fuel pump, injector pump, etc. course the gauges would fry.
  6. Dec 14, 2024 at 12:49 PM
    sandersgtn
    Lots to digest.
    My limited understanding is most high voltage components (ignition coils, spark plugs, battery/cable, etc.) are rugged enough. Low voltage solid state devices (SSDs) are sensitive to voltage surges and will fail.
    Thought is to find new or used critical sensitive components to protect and replace. Hoping I can get a list of such components from informed blog members to see how feasible this is.
    E.g.:
    ECM, voltage regulator, relays, spare fuses.
    Any other known critical SSDs? Anything in the distributor? ABS sensors? Don't care about radio, gauges, etc. Only items that would prevent running.
    Thanks!
  7. Dec 14, 2024 at 1:25 PM
    1 Limited Toyota
    California
    08 XRunner
    High pressure injection pump being electronic is susceptible? The VW TDI can go hammer and anvil mechanical high pressure injector pump by a hybrid pump (mTDI). Mercedes fuel cutoff can be manually switched as can be a modified electro magnetic type switch used on many others. The IDI is ideal as it isn't near a finicky to super heated water and other alternative fuels
  8. Dec 14, 2024 at 2:03 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Anything connected to 12v is susceptible. Some might be good up to 18 or 24 volts even, but that wont be enough.
  9. Dec 14, 2024 at 4:45 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    And where will you be storing these spares
  10. Dec 14, 2024 at 4:47 PM
    sandersgtn
    Yes. Faraday bags and old microwaves.
  11. Dec 14, 2024 at 4:49 PM
    sandersgtn
    Meant to say Faraday bags INSIDE old microwaves.
