1st Gen Tacoma headlight upgrade
Discussion in 'Lighting' started by TacoTuck, Apr 14, 2015.
  1. Apr 14, 2015 at 4:41 PM
    TacoTuck
    TacoTuck [OP] Well-Known Member
    NorthWest
    2001 4x4 TRD SR5
    Leer canopy, OME 881 lift with dakar leaf pack, 265/75/16 duratracs, 16x8 KMC enduros, line-x bedliner and more...
    I'm looking for a cheap and easy way to get some brighter headlights on my 2002 toyota tacoma. I am in college and budget is tight. I don't want to spend hundreds of dollars on retrofits. Any suggestions? Ive done some research but haven't found anything that has seemed to be in budget or is too complex for me. I am a newb when it comes to wiring and lighting
    I found this kit on Amazon and was wondering if anybody has had any luck with it or if you guys think it would be worth a shot. A pair of bulbs cost about $22 or something so this seemed worth a try.
    http://www.amazon.com/Toyota-Tacoma-Ballast-HID-Conversion/dp/B00D53E8L6
    Any suggestions or advice is much appreciated.
  2. Apr 14, 2015 at 4:50 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    General consensus on TW is to save up and do it right. I know its not the answer your looking for but if you want brighter lights Retros are a great option.
    Putting HID bulbs in a reflector housing scatters light everywhere and into peoples cars. Aint nobody like that.
  3. Apr 15, 2015 at 12:30 AM
    snowbrdd
    snowbrdd Well-Known Member
    Philips X-Treme Vision bulbs are your only good choice on a budget. I know that's not what you want to hear, but that's the only option.
  4. Apr 15, 2015 at 11:38 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    I would say either LED headlights or Sylvania
  5. May 7, 2015 at 6:56 PM
    1stgen
    1stgen Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
    I have vision x bulbs in now. They are slightly blue but are whiter than the factory. I'll grab a link for you.
    Vision X VX-LH4 H4 55/65 Watt Hi or Low Beam Superwhite Bulb Set
  6. May 7, 2015 at 11:08 PM
    TacoTuck
    NorthWest
    2001 4x4 TRD SR5
    where did you buy them? how long have they lasted you?
  7. May 8, 2015 at 10:14 AM
    1stgen
    18 SR5
    Amazon, I got them on 4/20
