1st gen tacoma lifespan?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jonass21, May 8, 2016.
  1. May 8, 2016 at 4:48 AM
    jonass21
    jonass21 [OP] New Member
    My 96 tacoma just hit 280k and is still running great, a little on the sluggish side but definitely still driveable. It recently started leaking quite a bit, looks like it is from the rear diff, so I took it in for an oil change and asked them to check on the leak. Essentially what he told me is that he wouldn't put any money into cleaning or fixing any of the leaks and just see how much longer I can drive the truck before I need to buy a new one. His reasoning was that if he went in and did any deep cleaning or any major seal repairs, then he would likely just cause more problems, whereas now its driving fine. Does that sound resonable? I would love to keep this around for as long as possible as it is a family truck, however I do currently use it as a daily driver and if trying to fix it is going to break its reliability, then I probably will just look into a new car.
  2. May 8, 2016 at 6:49 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    If its just a pinion seal then whats the big deal? Believe it or not but theres alot of trucks with more miles than you still going strong.
  3. May 8, 2016 at 7:18 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Fix the leaks. It will run much longer.
  4. May 8, 2016 at 7:19 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    it will outlive you
  5. May 8, 2016 at 7:37 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Definitely look in to fixing it. As for it running sluggish, how up to date on maintainence are you? Might need plugs, wires, filters, etc.
  6. May 8, 2016 at 10:44 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Where did you take it in for a oil change? Jiffy Lube or Walmart type place? Those guys are mechanically qualified as the Burger King cook.
    Hitstick and high n mighty like this.
  7. May 8, 2016 at 11:16 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    A 3rd gen 4Runner with the 2.7 4 cylinder came in the shop Thursday with 420k miles on it still running strong. I think you're good to go for awhile yet! Most mileage I've ever seen on a Taco was a 2003 double cab that had 624k on it when the original owner traded it in on a new one. They last for however long you take care of it.
  8. May 8, 2016 at 3:09 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I would crawl underneath with some solvent and clean the 3rd member of the differential. Drive it for a week or so, then crawl underneath again and see where the leak comes from.
    I would also find another mechanic. The one you saw sounds like either he is booked full with real money-makers or is just too lazy to help you out. IMO prolly just too lazy.
  9. May 8, 2016 at 7:59 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    sounds like a cop out to me... my dcab has just under 325,000 miles on it now and still runs strong... i have had a few leaks and gaskets replaced over the years... considering how reliable it is and how PAID OFF it is, it's been well worth the maintenance investment...
    Sugar Silva likes this.
  10. May 9, 2016 at 9:10 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Ive heard of 2 that reached the 1 million mark. One of them is on youtube.
  11. May 9, 2016 at 10:35 PM
    jonass21
    It was a Fletcher's. Thanks for all the input, I'll take to another mechanic to take a look at it. Like I said t really isn't having any trouble at all. But the hoa doesn't appreciate the mess on the driveway
  12. May 10, 2016 at 9:14 AM
    BillTheTruck
    BillTheTruck New Member
    Justin
    2001 Red tacoma v6 4 door
    2.5" Dual exhaust
    So mine has 322k and is still running just fine (it is the second engine but the engines that were swapped had about the same number of miles) if its a seal on the rear diff seal thats not a hard fix and gives you a reason to change the fluid inside of it.
  13. May 10, 2016 at 9:57 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like he doesn't want to do it....move on....
  14. May 11, 2016 at 9:18 PM
    2004TacomaSR5
    Jon
    Montana
    Link?
  15. May 12, 2016 at 7:24 AM
    devinzz1
    devin
    2023 aclb trd or mt
  16. May 13, 2016 at 7:31 PM
    2004TacomaSR5
    Jon
    Montana
    All highway miles, I'm not so sure it could be done on a rig that gets used in stop and go traffic every day. Highway miles are easy peasy on the engine, it barely has to work at all. If my truck ever reaches 500k, it will probably be retired and replaced with something newer. I wouldn't get rid of it, just have it as a second driver. They get to that point and you just never know what's going to happen.
  17. May 14, 2016 at 5:22 AM
    culli292
    culli292 Well-Known Member
    2001 Tacoma
    338,000 on mine and going strong!
    Jimbo446 likes this.
  18. May 14, 2016 at 10:38 AM
    MoonCrawler
    MoonCrawler Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
  19. May 14, 2016 at 10:41 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If mine is is 14 years old and only 54k original miles I guess you're right LOL!!
  20. May 14, 2016 at 10:49 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    The first one I remember hitting the 1 mil mark was a delivery truck that did in town deliveries IIRC
    Not the first ever just the first one I remember seeing
