1st Gen Tacoma lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by DeltaBox3, Sep 20, 2023.
  1. Sep 20, 2023 at 6:41 PM
    DeltaBox3
    DeltaBox3 [OP] Member
    DeltaBox
    2002 Base Tacoma
    Hi everyone, I am having a world of issues with my lights. 1st gen tacoma, base. When I turn my DRL on my driverside rear tail light all three bulbs light up. The OEM tail light was replaced years ago with a China one. So I thought maybe this was the issue. So I just bought a brand new tail light from Toyota and still same issue.
    Other issues I noticed.
    1. One license plate bulb has no power.
    2. Passenger side front lower turn signal not working.
    3. Driver's side turn signal will only work with head lights and DRL off.
    4. When headlights are on and I depress the brake the green right arrow on my dash will glow green.
    Any help would be greatly appreciated.
    Thank you!
  2. Sep 20, 2023 at 6:47 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Do you have trailer plug? On older rigs, the plug can corrode, create a blob of greenish material that conducts electricity. This material feeds one port to another.
    Weird things happen with the lighting when this occurs.
    TLDR:
    Can you check your trailer plug for corrosion?
  3. Sep 20, 2023 at 6:52 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If your tail lights, light with your Daytime running lights .
    You have some serious physical damage to the wiring harness allowing the the DRL circuit to energize the tail light circuit
    This is one of those in person one step at a time jobs.
    Get one circuit at a time working.
  4. Sep 20, 2023 at 7:23 PM
    DeltaBox3
    DeltaBox
    2002 Base Tacoma
    No trailer plug. I was just under the rear and it looks very clean. The factory black cable covers are still there.
    koditten likes this.
  5. Nov 25, 2023 at 8:42 PM
    DeltaBox3
    DeltaBox
    2002 Base Tacoma
    So its been some time since I tried anything new. Today I replaced both brake bulbs in the back, and replaced 2 small bulbs on the "middle" brake light above the rear windshield.
    Now when I turn the DRL or headlights on the driver's side (left) turn signal doesn't work. But the right does.
    In addition when the DRL or Head lights are on the entire tail lights are on. Brake, turnsignal, reverse lights.
    This morning I also replaced the turnsignal switch on the steering column and still no change.
  6. Nov 25, 2023 at 9:01 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Just bc I ran into this on Chinese tails….
    Are u mixing LED/conventional bulbs?
    I got new tail lamps, and swapped some led bulbs I had in tool box. Crazy stuff started occurring. Not hyper flashing, but one lamp blinking once then staying on/one side would blink upper then middle when brake pedal pressed
    I slept on it
    Then in the AM took out led’s and replaced with conventional bulbs
    No issues since
  7. Nov 25, 2023 at 9:08 PM
    DeltaBox3
    DeltaBox
    2002 Base Tacoma
    The driver side tail light was Chinese, I replaces 2 bad bulbs then this happens. So I replaces the entire tail light with an OEM one.
  8. Nov 25, 2023 at 9:24 PM
    ControlCar
    Steven
    Sugar Land TX
    Dang.
    sorry not going to be very helpful
    But
    Guessing something to do with a Ground wire………somewhere
    Too many issues/affected lighting systems at once
    kinda like this:
    ^^^on this ground, 5 separate ground wires for 5 separate systems….all related to one ground bolt to frame rail
    GL
    Please let us know
    DeltaBox3[OP] likes this.
  9. Nov 25, 2023 at 9:28 PM
    DeltaBox3
    DeltaBox
    2002 Base Tacoma
    I have been reading about the grounds. So far all grounds iv checked are fine. No corrosion, well torqued...
  10. Nov 25, 2023 at 9:37 PM
    ControlCar
    Steven
    Sugar Land TX
    Damn
    I absolutely HATE electrical shit like this
    I’m going to revert to what Bivouac stated
    It’s going to be a PITA
    But so easy to fix once u find issue
  11. Nov 26, 2023 at 7:15 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    When you replaced the tail light with OEM, did you reuse the bulbs? Are the bulbs led? The only place where the brake circuit comes together with the turn signal circuit is the tail light. Power is most likely bleeding through the bulb to the turn signal indicator. By your description it seems like you have multiple issues, but start with the tail lights and put incandescent bulbs in to eliminate any variables there.
  12. Nov 26, 2023 at 2:09 PM
    Glamisman
    Glamisman Well-Known Member
    Verify that all bulbs are single element first.
  13. Nov 26, 2023 at 5:56 PM
    ControlCar
    Steven
    Sugar Land TX
    Naw nbz
    Cheap budget tails came with oem bulbs
    Swapped in leds (brake only) and weird stuff started happening
    As u stated
    Placed original bulbs in….works no issues
