1st Gen Tacoma owner here, inherited from My Dad.
Discussion in 'New Members' started by ElBro7872, Apr 3, 2022.
  1. Apr 3, 2022 at 4:17 PM
    ElBro7872
    ElBro7872 [OP] New Member
    Fernando
    96 Toyota Tacoma
    Stock
    Needing advice, trying to do an oil pan gasket replacement and I'm stuck wondering what's the easiest/fastest/best way to get oil pan Off?! It's a 4 cylinder Automatic, just wondering if I should loose motor mounts & raise engine? OR remove power steering rack? There 2 brackets on each side of the tranny attached to motor, do these come Off? In the middle of this now just trying to do it right, Thanks ✌
    buckhuntin-tacoma likes this.
  2. Apr 3, 2022 at 4:44 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Forget the gasket, use Toyota FIPG sealant..
    On a 4wd the front differential has to be removed.
    The real trick is raising the whole truck high enough for the pan to clear the oil pickup tube.
    Got a lift ?
    https://youtu.be/w_gPiDvh9v4
  3. Apr 3, 2022 at 6:17 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila and ElBro7872[OP] like this.
  4. Apr 3, 2022 at 6:33 PM
    ElBro7872
    Fernando
    96 Toyota Tacoma
    Stock
    Not a 4x4 just a standard rear wheel drive, no lift I have it on jackstands Thx
