1st gen Tacoma Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by JDawg562, Feb 3, 2014.
  1. Feb 3, 2014 at 7:06 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    Hello,
    I just have a few questions.
    -How can you tell if the 1st gens have a Locking Differential, Limited Slip Differential or an Open Differential?
    There's this 1999 toyota tacoma SR5 pre runner, 3.4 liter - 6 cylinder, power windows and locks, cruise control, 6 lug on craigslist.
    I might have more questions if I decide to go with it or wait.
    -Justin
  2. Feb 3, 2014 at 7:11 PM
    jamco20
    jamco20 Well-Known Member
    James
    Socal
    Bilstein 5100's up front
    Look for the button on the dashboard or look for the actuator on the diff, assuming you can get more pictures or ask the seller as i see no sticker? Even if there was a sticker I'd still double check.
  3. Feb 3, 2014 at 7:25 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
  4. Feb 3, 2014 at 7:45 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Wow would not pay that much for that vehicle, I would wait. About your first question if it has a rear locking differential there should be a button for it on the left side of the steering wheel on the dash along with the other accessories, being a pre runner it should be equipped with one IIRC
  5. Feb 4, 2014 at 11:20 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Ah alright thank you!
    Another Quick question
    -What's included in the TRD Off Road package on the 1st gen Tacomas?
    :confused:
  6. Feb 5, 2014 at 12:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Locking diff, metal skid plate under gas tank, Bilstien shocks and decals. I can't remember if 16" alloy wheels was part or not. These are the differenes that I know of because I have a regular 4 x 4 and a TRD 4 x 4. Both are 1st gens.
  7. Feb 5, 2014 at 12:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    easiest way is to get under and look at the diff.
    If there is an actuator on the front driver side, its a locker.
    If the drain plug is on the driver side, its a locker
    if the drain plug is on the passenger side its a non locker.
  8. Feb 5, 2014 at 12:45 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ok im not going out to crawl on the ground to go look...but really? Never even noticed it before haha
  9. Feb 5, 2014 at 12:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yep.
    Easy way to identify
  10. Feb 5, 2014 at 10:05 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Oh wow thank you!
    I always poked my head under the bed and looked at the diffs and they all looked the same, since I didn't know what to look for.
    Thank you!
  11. Feb 6, 2014 at 6:54 PM
    DoccoM85
    DoccoM85 Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Competes with PNW pricing, i was actually looking in CA at one point considering flying down and driving up after buying one
  12. Feb 6, 2014 at 10:24 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Is it pretty easy to swap a locking diff into one with an open diff?
  13. Feb 6, 2014 at 10:26 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    My truck has a locker and i'm pretty sure when i drained the diff fluid it came out the passenger side.
    This
  14. Feb 6, 2014 at 10:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    An elocker? sure. Just swap in an axle and some wiring.
    ARB..takes a bit more as yhou have to take apart the diff..not a first project type thing.
    Nope. Go out and look.
  15. Feb 6, 2014 at 10:33 PM
    95 taco
    95 taco Battle Born
    I will tomorrow if it's not raining and if i'm not throwing up.
  16. Feb 6, 2014 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  17. Feb 6, 2014 at 10:47 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    My 96 has a metal gas tank skid
  18. Feb 6, 2014 at 10:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea most do, mine does as well. No TRD package till 97/98. late 97 was the introduction to it
  19. Feb 7, 2014 at 5:01 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Thank you!
