1st gen Tacoma rear shock help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02blancotaco, Feb 9, 2020.
  1. Feb 9, 2020 at 12:48 PM
    02blancotaco
    02blancotaco [OP] Well-Known Member
    Colby
    02 Toyota Tacoma 4x4 Trd
    Hey there, I was just reinstalling my factory rear shocks on my 2002 Tacoma as I just removed my airbags on the truck (airbags are for sale if interested) as there are the 5100s that require the lift, and I am not currently at stock height. But does the longer shock go on the drivers side or passenger side. Thanks.
  2. Feb 9, 2020 at 1:40 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Not having any idea what might have been done.
    Why do you have 2 different length rear shocks ??
    From new they should be the same.
  3. Feb 9, 2020 at 1:42 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Should be same length
  4. Feb 9, 2020 at 1:43 PM
    LoveableWerewolf
    Nashville
    I've heard of some people who run different spring rates for more weight on one side, but that's custom and kinda weird. And this has nothing to do with shocks
  5. Feb 9, 2020 at 4:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Longer shock goes on the passenger side; they're not equal length between the 2 of them.
    El Taco Diablo and Rachelsdaddy like this.
  6. Feb 9, 2020 at 4:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  7. Feb 9, 2020 at 4:23 PM
    LoveableWerewolf
    Nashville
    Hmm, I guess I know a guy who put the wrong shocks on his truck:rofl:
    cornbread_wy and Kwikvette like this.
  8. Feb 9, 2020 at 4:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof
    The way the shocks are setup doesn't attribute to an equal length setup.
    This becomes more apparent when you're upgrading for a more specific purpose such as off-roading where suspension travel is very important.
  9. Feb 10, 2020 at 1:35 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I guess mine are wrong as well .
    Must have been a bad day learn something new all the time .
  10. Feb 10, 2020 at 7:27 AM
    kamaaina1
    kamaaina1 Well-Known Member
    Sean
    Vancouver, WA
    2004 TRD Tacoma x-cab
    Two different lengths: Collapsed / Extended lengths:
    • BIL BE5-D559-TO 5100 Rear Shock, 95-04 Tacoma, Driver Side, 13.9" x 21.6"
    • BIL BE5-D560-TO 5100 Rear Shock, 95-04 Tacoma, Passenger Side, 14.7" x 22.6"
    El Taco Diablo and Kwikvette like this.
  11. Feb 10, 2020 at 8:42 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You forgot the other style meant for minimal lift, also Bilstein 5100's
    33-247724 21.26 EXT 13.62 COL Driver side shock
    33-247717 22.09 EXT 14.07 COL Passenger side shock
    kamaaina1[QUOTED] likes this.
  12. Feb 10, 2020 at 12:18 PM
    adamdsgn
    adamdsgn Well-Known Member
    Adam
    2003 Tacoma Double-Cab - TRD/4x4
    I ran into the same issue during my install. Had to google part numbers and run thru a couple of pages before I found the answer.
  13. Feb 11, 2020 at 7:20 AM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Shorter shock goes on the driver side since the brake like is there and too much droop with oem length hose is never a good idea.
  14. Feb 29, 2020 at 2:07 PM
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Any idea why KYB's appear to be excluded from this requirement?
    I was looking at TRQ shocks & there was a review regarding this R/L thing. The length & I guess the ID of the bushing being another clue. He kept the front assemblies & gave 'em thumbs up, but returned the rears. The whole thing piqued my interest. Went to a taco parts site & sure enough, whether your a TRD or not, R/L. I had noticed the KYB exclusion earlier, so back to this TRQ site to post the following examples....
    "THIS PART REPLACES:
    • KYB 344428
    • OE # 48541A9010
    • OE # 48531A9040
    • Monroe 37113
    • Monroe 37032"
  15. Feb 29, 2020 at 2:37 PM
    ccraider
    ccraider Well-Known Member
    Carson City
    I’m not following you here ?
    The KYB, OE and Monroe numbers are the same on both lists ?
  16. Feb 29, 2020 at 2:56 PM
    Kristi with a K
    Western MA
    Correct. Just using two examples to make my point, or rather, pointed question. Although maybe that just confused it cuz the second list has front assemblies & this post is about the rear shocks. My bad.... Point is, using the first list, there are two OE, L & R specific. There are two Monroe, L & R specific. There is one KYB, non side specific.... Why does side specific matter with the others (other brands as well), but not KYB?
