1st Gen Tacoma Rear Shock Info (Aftermarket)
Discussion in '1st Gen. Tacomas (1995-2004)' started by nzbrock, Feb 18, 2023.
  1. Oct 8, 2024 at 7:02 PM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    damn thats the easiest
  2. Oct 23, 2024 at 8:46 PM
    PaulyFromLA
    Pauly
    1st gen tacomas
    just wanted to say thank you, your thread really helped me out, I orders bilstein 5125’s and I ordered the correct bushing with your help
    nzbrock[OP] likes this.
  3. May 18, 2025 at 10:05 PM
    YotaBro
    YotaBro Well-Known Member
    98 Tacoma
    saving 4 later
    Black97v6MT likes this.
  4. Jun 4, 2025 at 6:44 AM
    plarson3
    plarson3 Active Member
    Virginia
    '04 Prerunner Xtra Cab 3.4L
    @nzbrock
    GREAT info here. Thanks. Question:
    I have a 2004 V6 Prerunner with no lift. Looking to soften ride a bit. Rarely carry any weight.
    Based on your research above, I am looking at getting the following:
    https://www.amazon.com/dp/B00I97UXFS
    https://www.amazon.com/dp/B00EIES3DU
    Does this seem right to you?
  5. Jun 4, 2025 at 8:29 AM
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Those would be for 1.5-2" of lift.
    For no lift I would just go with two of these if you wanted 5100s:
    8 Inch Travel -----------------------------------------
    Part Number: 33-230313
    Valving: 170/60
    Travel: 8.00 Inch
    Extended Length: 21.70
    Collapsed Length: 13.70
    Mount Type/Size: 5/8" ID bushing
    Link: https://amzn.to/3YWZcOV
    With those you many need to extend your bump stops by about an inch so the shocks don't bottom out. You'd need to cycle them to be sure though.
    You could also get the 4600 stock replacements:
    Driver side: 24-184960 https://amzn.to/3FIEYDX
    Passenger side: 24-184977 https://amzn.to/3ZMc78w
    I believe the 4600 are softer dampening than the 255/70 of the "standard" 5100, but I am not positive on that.
    YotaBro likes this.
  6. Jun 4, 2025 at 9:50 AM
    clavelle262
    clavelle262 Member
    Connor
    Los Angeles + 805
    1999 ExtraCab SR5 PreRunner 3.4
    great post, saving for later for sure
    YotaBro likes this.
  7. Jun 14, 2025 at 1:41 PM
    plarson3
    Virginia
    @nzbrock
    I went with the 4600 stock replacements on the back and am happy with them. Improved and softened the ride.
    Any thoughts on the fronts - shock/struts?
    Not looking to spend a ton. Bilsteins up front seems to be very pricy. Any suggestions for shock strut all in ones that are decent and have a good ride?
  8. Jun 14, 2025 at 3:03 PM
    nzbrock
    Noah
    San Marcos, TX
    I will have to defer to others on lower cost options for the front. I went with Sway-A-Way coilovers back when they were still a company and recently had them rebuilt after 60k miles.
  9. Jun 14, 2025 at 8:21 PM
    02hilux
    Planet: EARTH
    If you’re looking at inexpensive coilovers, consider KYB
  10. Jun 15, 2025 at 8:07 PM
    plarson3
    Virginia
    Thanks all. Last question - money aside, what front struts would give the best ride - bilsteins?
    ab_1280 likes this.
  11. Jun 15, 2025 at 11:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No
