1st Gen Tacoma Rear Suspension Advice!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Arman Bagdasarov, Feb 3, 2016.
  1. Feb 3, 2016 at 12:09 PM
    Arman Bagdasarov
    Arman Bagdasarov [OP] armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
    Ok so i have a 2001 tacoma and and need some advice on what to do with my rear suspension. Its all stock for now and only has 35,000 miles on it!!
    First thing i want to do is get some softer springs but what kind????? Because i live in L.A. i do mostly highway and street driving but ill go off road whenever i get a chance so a few times a month.
    Also, i will occasionally load it up so I'm thinking about adding some airbags for whenever i need them...
    http://www.4wheelparts.com/Towing/R...l00_ContentPlaceHolder1_pDetail_pdf_Container
    Lastly i have a question on what kind of rear shocks i should look into but mostly PLACEMENT! I've seen them on other tacomas mounted over the differential in a triangle shape, others on the outside of the frame behind the tires and all sorts of different spots. What do those placements been at far as travel and response?
    Thanks in advance for the help!
  2. Feb 3, 2016 at 12:12 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    first off, your not allowed to post about having a 35k miles first gen and not post a picture :)
    but if your not going to be racing through the desert ot flexing out, just use the stock shock locations with a nice set of shocks like 5100s or OME.
    FirstGen Jer likes this.
