1st Gen Tacoma RS3200 GBS install
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01tacoma4by4, Sep 28, 2021.
  1. Sep 28, 2021 at 3:18 PM
    01tacoma4by4
    01tacoma4by4 [OP] New Member
    2001 Gold Ext Cab
    side mirror turn signals,
    Hi everybody, I have a 2001 Tacoma Deluxe, SR5, Auto, 4x4 Ext Cab with 270,000 miles on it. I have rebuilt most of the truck including the engine and have done a lot of modifications to it. It is gold with black wheel flares, factory bucket seats and I have just installed the RS3200 VIP alarm which also adds the RKE option as well since I already have power locks and windows. I pulled the module and connectors w/pigtails from a 2004 Tacoma at the local salvage yard that had the option hard wired by the factory, unfortunately it is not the plug and play that I see in all the you tube videos and write ups. So basically I have used the wiring diagram I found on the internet and the troubleshooting manual by Jujitsu Ten which I understand is the manufacturer of the RS3200 for Toyota to find out where all the wires go. I had to install a 30A relay to wire the starter interrupt which the wiring diagram does not show is needed. If you have any questions about the factory RKE and alarm install on a 2001-04 let me know and I will be glad to help. I also acquired a GBS sensor with pigtail connectors from Ebay to add on to it and that is where I have a question that hopefully someone can help me with. The GBS connector has a yellow signal wire that I do not know where it goes. The RS3200 wiring diagram does not show the GBS at all, just the status indicator and the microphone. I noticed the RS3000 wiring diagram shows the yellow wire going from the ECU module to the GBS but the wiring is not the same as the RS3200. There are a few open terminals on all three connectors so I am guessing it should go to one of them If anybody can help, I would greatly appreciate it. I am trying to stay OEM which is why I did not just buy an aftermarket unit. Thanks!!
  2. Dec 20, 2022 at 2:06 PM
    thatshittyredtruck
    thatshittyredtruck Member
    Jeremy
    02 DC Tacoma 3.4 4x4
    Any leads as to where I can find the rs3200 module? Tacomas are so hard to find in pick a part yards in my area.
  3. Dec 20, 2022 at 5:34 PM
    kevinnnn
    kevinnnn Member
    Kevin
    2001 Tacoma 4x4 TRD
    Sorry, no help on the yellow wire, but OP, do you have part numbers by chance for the parts that you used? I have an 01 and was hoping this would be plug and play as well.
  4. Dec 20, 2022 at 5:38 PM
    kevinnnn
    kevinnnn Member
    Kevin
    2001 Tacoma 4x4 TRD
    hah definitely did NOT notice that, thank you!
    Taco critter likes this.
  5. Aug 29, 2024 at 9:08 AM
    czotie
    czotie Dang Ol' TacoBio
    Zote
    California
    2001 Silver Tacoma 4x4 Xtra Cab
    Bilstein 5100's Firestone Riderites Deckplate Mod & AEM Aisin Clutch plate Luk Flywheel Timken bearings Marlin Crawler shifter bushing GTA CarKit Gentex 453
    I have an extra RS3200 with no connectors. Don't know if you're still looking. I'm still trying to track down the 82132-YY050 wire harness for a 2001-2002 in the pick and pulls but no luck. Its out of stock everywhere, there is a site in Ukraine that claims to have it but I have mega doubts.
    Let me know if you want the extra unit.
