1st gen Tacoma SAS swap using super duty axles
Discussion in 'Solid Axle Suspension' started by 96_taco, Jul 18, 2018.
  1. Jul 18, 2018 at 6:05 PM
    96_taco
    96_taco [OP] Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    ive been searching for info on this and found a ton of 10k plus rock crawler builds that use nothing but premium parts and blah blah blah. My real question is concerning what axles to use for a SAS swap. My first idea was a Dana 44, but have been reading that they are weak and not worth using. I have a matching set of 1999 superduty axles in my backyard, sterling 10.5 rear axle and Dana 50 front axle. Is the Dana 50 alright to use on a toyota 4 cylinder? Or is it worth it to find a Dana 60 like my 2004 superduty has? New to axles but not to working on cars
  2. Jul 18, 2018 at 6:58 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    D50 isn’t really worth the effort.
    Super duty axles got upgraded in 05 with bigger knuckles and unit bearings and are all D60 from then on, I would look for a 05+ axle, they aren’t too pricey and pretty easy to get. The rear axle you have should be fine.
  3. Jul 19, 2018 at 10:07 AM
    96_taco
    Clayton sandgren
    Northern va
    Yes but superduty front ends after 05 also went to coil spring, and I’d like to use leaf springs. I’m not confident enough in my ability to cut the mounts off the axle and revels new ones either
  4. Jul 19, 2018 at 10:07 AM
    96_taco
    Clayton sandgren
    Northern va
    Re-weld
  5. Jul 19, 2018 at 12:54 PM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    I understand your direction but I cannot fathom spending the time and resources it takes to swap one and end up with an archaic leaf spring front setup. I know, I know...They're everywhere, they work pretty good, they're cheap etc... I'm just the type that if I'm spending that much time and money I'm gonna spend that extra to go with a much more modern setup.
  6. Jul 19, 2018 at 12:59 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You'd have to cut the mounts for the superduty off either way so might as well have the better axle and maybe think about coilovers and links.
    SnowroxKT likes this.
  7. Jul 19, 2018 at 1:02 PM
    UnderFire
    UnderFire Well-Known Member
    If you're not comfortable enough to chop mounts off an axle and weld on a set of perches, a complete sas and rear axle swap may be way out of your ability.
  8. Jul 19, 2018 at 2:14 PM
    96_taco
    Clayton sandgren
    Northern va
    Let me reword, I’d rather not use coil springs, because I’m not comfortable with coil springs. The way I am thinking I want this is with leafs, just because that is what I’m used to and what I’m familiar with. I could spend the extra time to go to coil spring but that’s a whole lot more geometry and angles than I want to deal with. It’s not that I can’t do it, I’d just rather not
  9. Jul 19, 2018 at 2:16 PM
    96_taco
    Clayton sandgren
    Northern va
    Well if I’m gonna use a coil spring at all I’d like to use a coilovers setup, and a lead spring setup is closer to my budget and more well suited to what I use the truck for
  10. Jul 19, 2018 at 2:24 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just from this post your not ready to swap the truck. You can't just bolt on an axle on your truck your going to have hours of welding alone doing a swap. All of the factory mounts on the new axles need to be removed so you can mount all the mounting locations to fit your much smaller truck then the full size axles.
    I would go and read for about 6 plus months on swapping a Tacoma before you attempt cutting on your truck or your going to have a jack stand truck for a very long time.
    VeeSix, jubei, Jimmynolife and 6 others like this.
  11. Jul 21, 2018 at 3:55 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Fabrication issues a side, if it was me I would swap what ya got provided you can find gears and lockers for the d50.
    If you don't cut off the leaf spring perches and move them, you are going to be fabricateing leaf spring mounts on the frame, which also requires a shit ton of welding and math. I did both on mine and the frame work was way harder than re welding some leaf spring perches.
    TacoSupremeo likes this.
  12. Jul 30, 2018 at 7:46 PM
    96_taco
    Clayton sandgren
    Northern va
    Well I was thinking I can run the 50, and if I end up breaking it and destroying it it wouldn’t be hard to drop a 60 in. Again I’ve never even broken a CV shaft, so I’m sure the 50 will be fine for what I’m doing. I’m just an overly paranoid person who has a bad habit of talking myself into things I don’t need lol
  13. Jul 30, 2018 at 7:47 PM
    96_taco
    Clayton sandgren
    Northern va
    I was already planning on not doing this for another year or so, gotta finish my 6 speed superduty 7.3 restoration first lol
  14. Feb 15, 2019 at 10:18 AM
    Marcos103476
    Marcos103476 New Member
    Marcos
    1997 toyota tacoma
    3inch lift,tg stinger,warn winch ,33
    So if i get a matching set of axles of a 95 f250 for 300$ would it be worth to sas my tacoma or should i just use a retubed to driver side drop toyota axle?
  15. Feb 20, 2019 at 9:40 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Sure, but you gotta know what you're getting into. Those should be a ball joint 60 and sterling 10.25. Both are perfectly fine to use. Leafs might be harder to do because the perches are like 36" wide on center. Not every rig has to be $60k.
  16. May 8, 2019 at 11:37 AM
    TacoSupremeo
    TacoSupremeo Well-Known Member
    Michael
    2005 Tacoma Double Cab 4x4
    For the record my 03 F250 has a D60 front... it started before 05.
  17. May 8, 2019 at 1:21 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    02/03 was a funny crossover year for D60's vs D50's some F250's got one and some got the other. However, 05+ D60's in SD's are Super 60's that have bigger tubes, 35 spline shafts, bigger R&P, and bigger u-joints on the stub axles that let them turn tighter.
  18. May 27, 2019 at 1:40 PM
    TacoSupremeo
    Michael
    I have been considering doing an SAS with SD axles as well. In doing my research i found an interesting kit. Its a set of radius arms for an 05+ SD axles using the factory link mounts on the axle... would just need to locate the placement for the frame side bracket, might need some outriggers but it looks very promising to me. Could use coils or maybe even my Toytec/Bilstein coil overs.
    http://www.ruffstuffspecialties.com/catalog/R2348.html
  19. May 27, 2019 at 1:41 PM
    TacoSupremeo
    Michael
    Oh, and would need to make a panhard bar mount for the frame (no biggie) using a bar made for the SD.
  20. Oct 6, 2019 at 11:21 AM
    cantey
    cantey Well-Known Member
    96 Tacoma 3.4 Manual
    I know this is a bit old but did you ever get anywhere with this, my buddy is looking to do the exact same setup
