1st Gen Tacoma Transmission Shifting Rough
Discussion in '1st Gen. Tacomas (1995-2004)' started by Comeaux18, Aug 5, 2021.
  1. Aug 5, 2021 at 3:48 PM
    Comeaux18
    Comeaux18 [OP] Member
    Colby
    2002 Tacoma TRD
    Hello I’m new to this forum but not very new to the 1st gens. My first truck was a 2000 Tacoma but I upgraded to a 2002 because I like the body style better.
    Now I have a 2002 Prerunner Crewcab with the 3.4 v6. Transmission is starting to shift rough so I imagine it won’t be too long before it’s time for a new one. I’m debating if I should 4x4 swap it while I’m at it or just put an identical one in it. What’s your guys opinion? And how long do y’all think I have?
  2. Aug 5, 2021 at 8:06 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Only the transmission will have the answer to "how long it will last" and only you will have the answer to "should you 4x4 swap it"
    Simple question to ask yourself, are you capable to doing the work yourself, do you have the proper tools and knowledge, and are you willing to take the time to source the parts? If not, is your pocket deep enough to pay someone the labor. From there, you can decide what you want to do.
  3. Aug 5, 2021 at 8:39 PM
    Glamisman
    Glamisman Well-Known Member
    manual or automatic? if manual have you checked the plastic cup at the bottom of the shifter and verified the clutch disengages fully? if automatic have you checked the TV cable adjustment?
  4. Aug 5, 2021 at 8:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    By chance was the 2000 an auto 4x4?
    I’ve found my 4x4 trucks shift smoother than the prerunner my dad has. But his has shifted rough since we got it at 68k, it’s almost to 200k now
  5. Aug 6, 2021 at 1:32 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Start doing fluid swaps, 4 qts at a time with synthetic maxlife mercon/dex, it may help and its relatively inexpensive
    Nessal likes this.
  6. Aug 6, 2021 at 12:26 PM
    Comeaux18
    Colby
    2002 Tacoma TRD
    The 2000 was a prerunner as well
  7. Aug 6, 2021 at 12:30 PM
    Comeaux18
    Colby
    2002 Tacoma TRD
    I did a fluid swap and it seemed to help some. It still jerks into gear when cold and shifts rough when cold but once warm you can barely notice when it shifts. The old fluid was very dirty so hopefully that was the issue
  8. Aug 6, 2021 at 1:05 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    hows the shifter bushing?
    edit: nevermind, ur auto right
  9. Aug 6, 2021 at 3:29 PM
    Comeaux18
    Colby
    2002 Tacoma TRD
    Yep mines automatic
  10. Aug 6, 2021 at 6:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you looked through this thread?
  11. Aug 26, 2022 at 1:23 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    I got a 97 taco shifts rough when cold, I have added lucas and still no good, wondering how long i can drive it like this
  12. Dec 14, 2022 at 12:06 PM
    chunts
    chunts Member
    2000 Tacoma SR5
    my 2000 just started doing this like a month ago. really serious, violent clunk when you shift it out of park, or back and forth into reverse, but like yours it only happens when it's cold. Mellows out almost entirely after it's been running 5-10 mins, though I can still feel the shifting is a little bit rough sometimes after that.
    I got a transmission fluid flush but that didn't seem to do anything. This morning I had to let it warm up a bit cause the window was fogged, and that time it wasn't nearly as rough as it's been. Annoyingly my mechanic could not repro the issue, which was pretty hard to believe but maybe he just thought that was normal? When it does it, it feels like you got rear-ended or something. It's really hard to miss.
    I've seen a lot of stuff that points to axle wrap or driveline, but the way it stops when it's warm makes that a hard sell. Feels like it's gotta be something in the transmission itself.
  13. Dec 14, 2022 at 10:32 PM
    YotaGangYotaGang
    Covina
    i fixed mine by adding an external transmission cooler, drain and filled with valvoline synthetic with Lucas additive and added a magnefine filter. Has not shift hard once ever after 7000miles later.
