1st gen tacoma trd !
Discussion in '1st Gen. Tacomas (1995-2004)' started by Markster, Feb 7, 2017.
  1. Feb 7, 2017 at 1:38 PM
    Markster
    Markster [OP] Member
    Mark
    1st gen tacoma trd
    My question is I have a 2000 tacoma trd and it dosen't have a locking rear diff ! What makes my trd off road a trd off road
  2. Feb 7, 2017 at 2:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If you have an automatic, and 4-cyl, the elocker is not included in the TRD package.
    You do get progressive front springs, and bilstein shocks. Not sure what else.
  3. Feb 7, 2017 at 2:30 PM
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    I've read 4 bangers didn't get the rr locking diff.Here's what else you should have with the TRD package on the sticker.
    Here's from my 2000 TRD monroney window sticker. Does anybody know what the option FD - Four Wheel Demand for $240 is??
  4. Feb 7, 2017 at 2:31 PM
    Markster
    Mark
    1st gen tacoma trd
    Thanks for the redponse ! Mine is an automatic but is a V6. How complacated or expansive to make it a locker ?
  5. Feb 7, 2017 at 2:38 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Are you the original owner or a second/third/etc owner? stickers don't mean anything and we've seen a lot of sellers put them on and unsuspecting buyers do not know.
    you have to buy the locking rear axle and various electronic bits to make it work
  6. Feb 7, 2017 at 2:38 PM
    harper7
    Gary
    Tulsa/Claremore OK
    That more then likely means that somebody just bought the $80 TRD stickers and put them on it.You can get up underneath and look just in case somebody took the locking diff switch out.(highly unlikely)
    You would have to find a oem one, rear axle and diff in the classifieds or a junk yard(fairly rare),maybe ebay. Or you can get an ARB or other aftermarket. I had ARB front and rear on my last truck and actually liked them better as it seemed to be quicker engagement and disengagement.
  7. Feb 7, 2017 at 2:44 PM
    Markster
    Mark
    1st gen tacoma trd
    I'm not that worried about it I was just wondering if the 2000's even had the locking diff option
  8. Feb 7, 2017 at 2:47 PM
    Markster
    Mark
    1st gen tacoma trd
    I was thinking That I would rather have a LSD anyway because I like the snow anybody go that route ?
  9. Feb 7, 2017 at 2:47 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    YES
    Joe D and shakerhood like this.
  10. Feb 7, 2017 at 2:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you have the v6, it probably means a previous owner just slapped on a pair of stickers on the sides.
    Which side of your rear diff has the drain plug on it? Is it on the drivers side?
    1st gens came with two very different rear axle assemblies. The TRD elocker rear diff has its drain plug on the drivers side of the diff.
  11. Feb 7, 2017 at 8:34 PM
    Markster
    Mark
    1st gen tacoma trd
    Thanks alot I'll check that out
  12. Feb 7, 2017 at 8:44 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I added a trd off-road elocker to mine. From my experience, the easiest route is acquiring:
    1) elocker housing
    2) 3rd member with elocker
    3) wiring harness from 12v guy
    4) 8 pin rocker switch.
    ...and don't forget to make sure the front and rear diffs match, gearing wise.
  13. Feb 7, 2017 at 8:49 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I'm curious if you have been under the truck to look at the rear axle at all?
    Markster[OP] likes this.
  14. Feb 7, 2017 at 8:55 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Four Wheel Demand = Four Wheel Drive maybe?
  15. Feb 7, 2017 at 8:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think that may have been Push Button 4 Wheel Drive.
  16. Feb 7, 2017 at 8:59 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Probably is the tcase with the button and not just the plain j shift.
  17. Feb 7, 2017 at 9:00 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    :annoyed: Beat me to it
    shakerhood[QUOTED] likes this.
  18. Feb 7, 2017 at 9:04 PM
    Ice Horse
    Lauren
    Florida
    Ah that makes sense. What year did they start doing that? I know my 98 has the j-shift
  19. Feb 7, 2017 at 9:37 PM
    shakerhood
    Southern Ohio
    My 2000 also had a J Shift, but I do recall that Four Wheel Demand being an option but not sure which year it first started.
  20. Feb 8, 2017 at 1:10 AM
    roosterburm
    roosterburm Well-Known Member
    Ross
    2002 Tacoma Double Cab 4 x 4 TRD
    3" Toytec with bilsteins American racing 15' wheels 32'' Goodyear MTR's Daystar super shackles
    I woulda had to haggle em down on the full tank of fuel charge....
