1st gen tacoma
Discussion in 'New Members' started by wolf222, Apr 17, 2016.
  1. Apr 17, 2016 at 3:40 PM
    wolf222
    wolf222 [OP] New Member
    Randy
    2001 Toyota Tacoma 4x4
    Curious of any direction to turn to. i have a 2001 Tacoma 3.4 L 4x4 manual . i have had a check Eng light on for some time. a week back it started running rough , replaced all 6 plugs , it still ran rough. finely had a friend code it . Got a single P0303 . miss fire on #3 . replaced the #3 coil , it still ran rough. then after re fueling it hardly ran then died. i was able to restart and get back home. replaced #3 with a new injector . now after coding again , getting codes of P0301 / 302 / 1135 . so miss fires on 1 & 2 and now an O2 sensor. iv'e never had a issue with this motor until now , all parts are orgional.
  2. Apr 17, 2016 at 3:47 PM
    crazykilik
    crazykilik Well-Known Member
    Tim
    Dayton Oh
    TROUBLE (The good kind!)
    3 inch lift, 33 inch tires
    Do a compression test, see what kind of #'s you get.
  3. Apr 17, 2016 at 3:48 PM
    crazykilik
    Tim
    Dayton Oh
    Also, your sure you have spark on that cylinder?
  4. Apr 17, 2016 at 3:59 PM
    crazykilik
    Tim
    Dayton Oh
    could be the upstream O2 sensor as well, when mine went bad I had a similar experience.
  5. Apr 17, 2016 at 6:42 PM
    wolf222
    Randy
    I'll have to get my hand on a tester . i hate to consider a possible burnt valve, thanks for the info.
  6. Apr 17, 2016 at 6:51 PM
    wolf222
    Randy
    At first it was #3 , then i pulled the coil and it was firing / good spark. still i replaced to coil. iv'e also replaced the injector for #3. Now i am getting miss fires on No #1 & 2 , a code for an O2 sensor now that did not show when we first ran a code test. so ill look at the O2 sensor next. thanks again.
  7. Apr 17, 2016 at 7:11 PM
    crazykilik
    Tim
    Dayton Oh
    Yeah if your downstream cord is long enough you can just try swapping it with the upstream to see what happens so you don't waste cash. In my case I had to take the plunge and buy a new one. Picked up the denso off of Amazon for $45 and it cleared my codes and took care of the rough idle.
  8. Apr 17, 2016 at 11:44 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
