1st Gen Tail Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coldspire, Nov 1, 2009.
  1. Nov 1, 2009 at 7:59 AM
    Coldspire
    Coldspire [OP] Well-Known Member
    B-Rad
    AB, Canada
    2001 Xtra Cab, 2.7L 4cyl. Manual
    Grill guard, Helo rims on Wrangler 245/75 R16s, Altezza taillights, Kenwood DVD Player
  2. Nov 1, 2009 at 8:03 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ish
    they will FIT persay but the wiring harness is a bit different
    you may be able to make them work
  3. Nov 1, 2009 at 8:06 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Yeah, you can bolt them up, but like what tigerfan said, the wiring is a bit different, will probably need to fiddle with them to make it work properly.
  4. Nov 1, 2009 at 8:09 AM
    JimBeam
    JB
    2015 Tundra
    its gonna require adding a jumper for a ground
    it LOOKS simple enough but i have a set of carbon fiber taillights in my closet that disagrees with me
  5. Nov 1, 2009 at 8:54 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The grounding scheme changed in 2001. 2001-2004 tails will work in 2000 and earlier Tacos, but not the other way around.
    Whether you can mod the 98-00 tails to work and how much hassle it would be will depend on the exact units you're trying to install. Some don't work at all without massive surgery.
    The simplest fix is to swap the aftermarket lenses onto the OEM 'pods' (if that keeps whatever looks you're going for).
  6. Nov 1, 2009 at 9:02 AM
    JimBeam
    JB
    2015 Tundra
    after the frustration i had attempting to convert my wiring...i gave up...its not worth the time and effort
  7. Nov 1, 2009 at 7:45 PM
    Coldspire
    B-Rad
    AB, Canada
    Whatevs. Found another pair that will fit my taco with no modifications. I'm 16 so I don't have the time or knowledge do start tinkering with electircal stuff.
  8. Nov 1, 2009 at 9:49 PM
    YotaComa
    YotaComa Well-Known Member
    NorCal
    2004 Tacoma Double Cab
    pictures?
  9. Nov 1, 2009 at 10:14 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    You're 16 and you don't have time? Surely you must be kidding. Try being 40 having a kid and a job to worry about, then you'll know what "have no time" means.
  10. Nov 2, 2009 at 10:51 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    those should work fine. Im running 01-04 tails in my 00.
