1st Gen tie rod replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by REP, Dec 6, 2019.
  1. Dec 6, 2019 at 10:46 AM
    REP
    REP [OP] Member
    So it’s time to replace my left inner tie rod on my 2002 rig. Just seeing if any have input on
    1. Do I replace both of the inners and outer rods.
    2. Should I try to stick with OEM $$$
    3. If not OEM any suggestions on decent after market companies.
    thanks in advance for any help.
    GQ7227, Area51Runner and OneWheelPeel like this.
  2. Dec 6, 2019 at 10:47 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    How many miles since last done?
    OneWheelPeel likes this.
  3. Dec 6, 2019 at 11:32 AM
    REP
    REP [OP] Member
    They are original 145k miles
    GQ7227 likes this.
  4. Dec 6, 2019 at 12:08 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    me thinks I'm in the same boat shortly, mine are original 168k and I have a little movement that wasn't there last year. I've already done the OTRE
    honestly @REP I would go with OEM, they lasted this long, a little more $$ for guaranteed another 145k+ is good investment
    GQ7227 and Area51Runner like this.
  5. Dec 6, 2019 at 12:11 PM
    eon_blue
    Azusa, CA
    I replaced my inner and outer tie rods over summer, I got OEM outer tie rods and 555 brand inner tie rods from Low Range Offroad.
    I am normally all about staying OEM on critical suspension parts but OEM inner tie rods are ridiculously expensive compared to the 555 ones, and the 555s inner tie rods have a great reputation from what I've read. I've had no trouble with them so far, been about 3 months since I installed them.
    TashcomerTexas and Area51Runner like this.
  6. Dec 6, 2019 at 12:12 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I go with OEM but that's just me. Well, wait - that is not entirely true. When I did my front suspension, I chose to go with OEM outer tie rods and aftermarket inners to save a bit of cash. While I have had zero issues, if I had to do it over again, I would stick with OEM.
    For the most part, this is a correct walk-thru. I would NOT hammer the steering knuckle to break the outer tie free. Rent or pick up a puller. Also, when removing the castle nut, flip it over and thread it back on so its flush with the top of the post. This way, when you pop it free with the puller (or the BFH lol), it won't go flying downward. For the inner tie, I ended up using a pipe wrench on it unless you have a monster crescent.
    https://youtu.be/AVQHgcXEhpE
    eon_blue likes this.
  7. Dec 6, 2019 at 12:14 PM
    Area51Runner
    lol, you beat me to it. hahaha
    eon_blue[QUOTED] likes this.
  8. Dec 6, 2019 at 12:14 PM
    eon_blue
    Azusa, CA
    it's nuts how expensive the OEM inners are, like a few hundred dollars if I remember right. Compared to what, $40 for the 555s?
    Area51Runner[QUOTED] likes this.
  9. Dec 6, 2019 at 12:26 PM
    Area51Runner
    exactly. at the time, I just could not justify it. Crazy price difference.
    I just looked it up @ camelback and its $142 now. Low Range is $30. o_O
    GQ7227 and eon_blue[QUOTED] like this.
  10. Dec 6, 2019 at 12:34 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what kind of movement?
    like noticeable steering movement?
  11. Dec 6, 2019 at 12:49 PM
    eon_blue
    Azusa, CA
    What convinced me to do my tie rods (even though mine only had 80k miles on them, but lots of offroad miles) was a looser than usual feeling in the steering wheel especially when I would hit bumps on the freeway going 75mph. Started to feel more sketchy than usual (always feels kind of sketchy in a lifted truck with no sway bar). Also I could grab my inner tie rod by hand and get a little movement in it with the truck's wheels on the ground.
    When I pulled the inner tie rods off they were loose/floppy as hell, not sure if that's normal or not. The new ones were very stiff. Makes the steering feel better.
    GQ7227[QUOTED] likes this.
  12. Dec 6, 2019 at 2:03 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    when I had my front driver's side up last time I had a "little/ 1/8 inch" play in the left/right, not top/bottom when grabbing the wheel
  13. Dec 6, 2019 at 2:54 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I installed 555 outers about 2 years ago, and they've been totally fine, although I haven't put a ton of miles on them as it's not my daily driver. I didn't do the inners at that time. Only thing is they have a fine sheen of surface corrosion (hesitate to even call it "rust" lol) on them.
    555's are totally fine, IMO even for the lower ball joits. They're certainly much nicer than the Moogs that I had put on 7ish years ago, and those were more than fine when I ended up replacing them (was doing, shocks, UCAs etc... at the same time).
    I have a balljoint rant if you care to read it on my build thread linked in my sig...
    OneWheelPeel, Ace115 and GQ7227 like this.
