1st gen Total Chaos 2.0 rear shock relocation trying to run 2.5
Discussion in 'Long Travel Suspension' started by Robertdalton, Feb 5, 2020.
  1. Feb 5, 2020 at 11:56 AM
    Robertdalton
    Robertdalton [OP] Member
    Robert
    Encinitas ca
    2000 trd tacoma 4x4
    So I have the tc rear shock relocation kit for a 2.0 shock I have a pair of 2.5 10 inch Kings I really want to run in that location with that kit because I already have it I asked total chaos if it’s possible they just told me to mock up and see I know that I can weld a bar in between the frame and hang the shocks on the inside of the frame but I’m trying to avoid that if I can I have 1.5 offset rims and can use wheel spacers if need be have tc 3.5 lt in the front so wouldn’t mind spacers thanks
  2. Feb 5, 2020 at 12:12 PM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I'm running the TC kit with 2.125'' shocks and don't have any issues. I think I've seen a few people running 2.5's on the kit, they just had to run larger wheel spacers than the 1.25'' spacer that TC recommends. The problem you might run into is the shock body contacting the frame in on the wheel that droops out when you articulate your suspension. As TC said, I would just bolt them up, articulate the suspension, and found out if they clear the frame or not.
  3. Feb 5, 2020 at 1:20 PM
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
    Check out my thread El Honcho... I just fabbed my own SUA setup and I placed the shocks outside the frame. 14" 2.0 smooth body Bilstein 7100. I first used 1.5" spacer but after my first test run the tires were putting a lot of rubber on the outside of the shock body. I switched to a 2" spacer that definitely reduced the amount of tire contacting the shock body. I had cleaned the shock bodies and after the 2" were put on there is still some rubber marks on the shock body but it's a lot more minimal than it was originally. This is also with LT springs so not sure that helps if you dont have SUA kit. This is also a GEN 1 Taco. I would think the only difference would be during mock up you would just need the shock to sit a little further away from the frame then the 2.0
  4. Feb 5, 2020 at 1:23 PM
    austinmtb
    Austin
    Southern Oregon
    He's running the TC relocation kit so he has no choice how far the shocks sit off of the frame unless he got some offset misalignment spacers for the top mount.
  5. Feb 6, 2020 at 9:51 AM
    Robertdalton
    Robert
    Encinitas ca
    2000 trd tacoma 4x4
    Do you think it’s worth trying to run a 2.5 on the tc kit or should I just weld a bar on the inside of the frame and hang the shocks on the inside of the frame
  6. Feb 6, 2020 at 12:45 PM
    austinmtb
    Austin
    Southern Oregon
    I would give it a shot. Wheel spacers don't cost much and bolting them up and cycling the suspension won't take long.
  7. Feb 6, 2020 at 10:01 PM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    My bad dog. I'm a newb man. I thought it was similar to the solo bent tube relocation kit. I see it isn't now that I have looked at it.
    https://www.chaosfab.com/accessories/1996-2004-Tacoma-Rear-Shock-Mount-Kit-49625
    Couldn't you weld some outer lays on the frame? Like 3/16 or 1/4 or something and then weld that to it? That would space it out away from the frame further.
  8. Feb 7, 2020 at 12:04 PM
    austinmtb
    Austin
    Southern Oregon
    In theory you could, but if I'm not mistaken his TC kit is already installed.
  9. Feb 7, 2020 at 12:10 PM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    Damn, why they have to keep a brother down? Pimps up.
  10. Feb 7, 2020 at 4:16 PM
    Robertdalton
    Robert
    Encinitas ca
    2000 trd tacoma 4x4
    Actually I just have the mounts in the box upper part isn’t hard to bolt on at all guess I could just tack weld the bottoms on and cycle out the rear ended what should I look for just contact with the frame when I lift one side of the axle up
  11. Feb 7, 2020 at 4:56 PM
    austinmtb
    Austin
    Southern Oregon
    Oh okay, that should work. Yeah just make sure the shock body isn’t contacting the frame. You could also try moving the lower shock mount as far out toward the wheel as possible to get the shock body away from the frame.
