1st Gen Toyota Part Numbers & Prices
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Aug 7, 2018.
  1. Aug 7, 2018 at 4:14 PM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm starting a thread with Toyota part numbers, prices and pictures of the parts if I have them. Along with some common aftermarket parts. Please feel free post any I don't have and I'll update the first post.
    Under construction
    Part prices in bold I purchased from Camelback Toyota. Prices may be different now. But it gives you a ball park figure:
    2004 3.4v6 Prerunner
    00272-1LLAC-01 Red Concentrated Antifreeze $24.61
    90467-07041-B7 Gray Clip for Center Console $0.96
    91189-06157 Grommet, Screw (Inner fender push in clips) $0.83
    Table of context
    S1. Drivetrain
    P1.engine
    P2.transmission
    P3.axels
    P4. Drive shaft
    S2.exterior
    P1.body panels
    P2.trim/Accessories
    P3.armor
    P4.lights
    S3.interior
    P1.trim
    P2.eletrical
    S4.suspenion
    P1.Steering
    P2.Rear suspension
    P3.Front suspension
    S5. Brakes
    P1. Front
    P2. Rear
    Section 1
    Part 1 engines
    A1. Timing Belt 13568-69095 $37.52 $38.49
    A2. Water Pump 16100-69398-83 $164.11 $98.66
    A3. Tensioner 13540-62021 $31.09
    A4 Upper Idler 13503-62040 $71.22 $169.98
    A5. Lower Idler 13505-62070 $95.46
    A6. Crank Seal 90311-40022 $5.75
    A7. PS Belt 90080-91126-83 $8.33 $14.63
    A8. AC Belt 99364-20870-78 $17.41 $17.70
    A9. ALT Belt 90080-91090-83 $9.65 $16.95
    A10. Upper Radiator Hose 16571-62070 $35.31
    A11. Lower Radiator Hose 16572-07040 $22.54 $12.84
    A12.
    15777-62020 Oil Cooler Coolant Hose $10.98
    15778-62030 Oil Cooler Coolant Hose $26.89
    A13. Thermostat 82°C/180°F Stock 90916-03075 $19.31
    A13. Thermostat 76°C/170°F 90916-03107 $29.42
    A14. TRD Thermostat 71°C/160°F 00602-17621-001 16340-SP010 $65.00
    A15. Thermostat Gasket 16325-62010 $4.76
    Thermostat Gasket Fel-Pro 35445 $5.27
    A16. Fan Clutch Towing (green) 08921-0495
    A17. Engine Cooling Fan Pulley Bracket AISINFBT004 $112.79 Rockauto
    A18 PCV Valve 12204-62010 $10.48 1997-2003
    PCV Valve 12204-62030 $6.54 2004
    A19. PCV Valve Grommet 90480-18001 $7.44
    A20. EVAP Vac Tubing Gates 27050 $0.99per ft 4.95 5ft
    A21. Positive Terminal (black) 90982-05035 $21.35 $15.40
    A22. Negative Terminal (gray) 90982-06022 (not stock, modification to cable required) $14.17 $11.80
    A23. Terminal Flange Nut 94151-80801 $1.18
    A24. Pos Terminal Cover 82821-35020 $15.23 $10.99
    Part 2 transmission
    Part 3 axles
    A1. Rear Axle Bearing and Seals W/O ABS TAC-AX-RBKU $89.10 LowRangeOffRoad.com
    Rear Axle Bearing and Seals W/ABS TAC-AX-RBKU-ABS $120.31 LowRangeOffRoad.com
    Part 4 drive shaft
    A1. Carrier Bearing 37230-35130 $146.00
    A2. Drive Shaft Stake Nut 90179-18009 $2.59
    Section 2 Exterior
    Part 1 body panels
    Part 2 trim/accessories
    A1. Hood Prop 53441-04030 53441-AD010 19.54
    A2. Hood Prop Grommet 90480-15028 $2.93
    A3.Hood Prop Holder 53452-90351 53210-90353 $5.52
    A4. LF Outer Door Scraper 68210-04020 $46.97 Window weather-striping
    A5. RF Outer Door Scraper 68160-04020 $46.97 Window weather-striping
    A6. LR Outer Door Scraper 68174-35020 $46.97 Window weather-striping
    A7. RR Outer Door Scraper 68173-35030 $46.97 Window weather-striping
    A8. Fender Flare Clip Blue (8) 90904-67036 $3.28 $1.27 1998-2004
    A9. Fender Flare Clip Red (18) 90904-67037 $3.28 $1.27 1998-2004
    A10. Front Fender Front Flare Seal/Pad L&R (2) 53851-35061 $10.97 $16.88 1998-2004
    A11. Rear Fender Flare Seal/Pad L 61783-35091 $11.51 $17.64
    A12. Rear Fender Flare Seal/Pad R 61783-35071 $11.51 $17.64
    A13. Flare Protector L 58742-04020 $12.06 $18.54
    A14. Flare Protector R 58741-04020 $8.82 $18.54
    A15. TRD Offroad Decal PT211-TT980-28 $37.30
    A16. Fender Liner Screw Clip 90189-06157 $4.71, 50pcs $0.87each CT
    A17. Fender Apron Seal Clip 90080-46327 90467-10107 $5.33, 50 pcs $1.05each CT
    A18. Fender Apron Seal Clip 90467-10173 $1.68 CT
    A19. Fender Liner Push Clip 53879-60010 $6.99, 50pcs?
    A20. Fender Apron Seal Set $74.99
    A21. Fender Apron Seal Left 53738-04020 $50.63 $35.01
    A22. Fender Apron Seal Right (front) 53738-04040 $29.11 $20.13
    A23. Fender Apron Seal Right (rear) 53738-04030 $27.93 $19.31
    A24. Front Bumper Top Pad Clip 52161-02020 $3.38 $2.67
    A25. Grille Clip (7) 90467-12070 $7.49
    A26. Grille Clip Large Outer (2) 53145-12010 $2.82 $11.28
    A27. Tail Light Gasket (2) 81552-04060 $14.50 $29.00
    A28. Tail Light Screw Clip (small) 90189-04144 $3.32 $13.28
    A29. Tail Light Screw Clip (large)
    A30. Windshield Washer Resivoir 85315-04060 $95.98
    A31. Antenna Assy 86300-04050
    A32. Antenna Ornament 86392-04020 $12.24
    A33. Antenna Nut 86396-16020 $9.95
    A.34 Lisle Antenna Nut Socket (tool) 29600 #4 $11.34
    A35. Antenna Assy (automatic) 86300-04060
    A36. Antenna Ornament(automatic) 86392-04030
    A37. Antenna Nut (automatic) 86396-04030
    A38. Front clearance lamp retainer
    53137-04010 right side
    53138-04010 left side
    Part 4 lights
    A1. License Plate Light w/ Gasket 00228-34938
    Part 3 armor
    A1. Skid Plate Bolt Black 90080-11373 90119-08A33
    A2. Skid Plate Bolt Silver 90080-11547 $2.07 $1.86
    Section 3 Interior
    Part 1 trim
    A1. Inside Mirror w/ Dual Lamp Charcoal 87810-04050-B0 $152.22
    A2. Lens & Bezel w/ Dual Lamp Charcoal 87818-35010-B0 $49.13
    A3. Cup Holder Insert L (1) 66995-AD021 $0.74
    A4. Cup Holder Insert S (4) 66995-AD011 $0.74
    A5. Accessory Switch Cover Charcoal 55539-06010-B2 $3.56
    A6. LF Seat Scuff Plate Charcoal 67914-04040-B0 $59.22
    A7. Window Switch Panel Charcoal 74202-35010-B0 $25.98
    A8. Shifter Bezel 35971-35130 $36.29
    A9. Shift Indicator 35921-35172
    A10. Shift Lock Cover 33554-35050
    A11. Shifter Bushings (4) 33544-27010 $1.79
    A12. Coat Hook Charcoal 74631-35010-B2 $2.87
    A13. Front Door Panel Screw Cap Charcoal 67772-04030-B0 $3.05
    A14. Center Armrest Lid Charcoal 58905-AD010-B0 241-10891
    A15. Tool Kit Band 58780-89102 $13.71
    Part 2 electrical
    Section 4
    Part 1 steering
    A1. Steering Rack Guide 45504-35031 $73.90 $53.52
    A2. Steering Rack Guide Spring 90501-26074 $3.02 $2.72
    A3.Steering Rack Guide Lock Nut 90179-48003 $1.78 $1.61
    A4. Steering Rack Guide Cap 45524-37010 $26.38
    A5. ES Steering Rack Bushings 8.10103.R $24.22
    A6. ES Sway Bar Bushings 27mm 8.5118.R $17.75
    A7. ES Tie Rod End Boots 9.13101.G $3.64
    TRD FJ SE 16" Centercap PTR18-35092 $12.15 $8.41
    Part 2 Rear suspension
    Part 3 Front suspension
    A1. Left Lower Ball Joint w/bolts 43340-39585 $118.45
    A2. Right Lower Ball Joint w/bolts 43330-39815 $118.45
    A3. Front wheel Bearing 4x4 and Prerunner 90369-54002 $79.85
    A4. Front Outer Wheel Seal 4x4 and Prerunner 90316-69001 $42.42
    A5. Front Outer Wheel Seal 710571 NATIONAL (Rockauto) $6.38
    A6. Upper Control Arm Bolt 90105-14105
    A7. Upper control arm washer 90209-14010
    A8. Lower Control Arm Bolts 90080-11283
    A9. Lower Control Arm Camber/Caster Adjust 48409B 48409-35050
    A10. Lower Control Arm Toe Adjuster Plate 48452 48452-35020
    S5. Brakes
    P1. Front
    A1. Tundra Hard Brake Lines when converting to Tundra style brake hoses
    47314-35330 Front Brake Tube #4 $6.83
    47316-35250 Front Brake Tube #6 $6.83
    P2. Rear
  2. Aug 7, 2018 at 4:14 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  3. Aug 7, 2018 at 4:19 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    This will be very helpful to all of us.
    Thanks, Jon
  4. Aug 7, 2018 at 5:07 PM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    Toyota Parts Deal
    2002 Tacoma Extended Cab
    rope hooks: 66312-35010 [order 4 (1 per corner)] $10.64 each
    bolts: 90149-80034 [order 8 (2 per hook)] 0.93 each
  5. Aug 7, 2018 at 10:19 PM
    tony2018
    tony2018 Well-Known Member
  6. Aug 7, 2018 at 10:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Just a thought but you should break everything into section then put a table of content on top
    GQ7227 and Dalandser like this.
  7. Aug 8, 2018 at 12:09 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    IT's a work in progress
  8. Aug 8, 2018 at 1:18 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Good idea as many part numbers aren't listed with online catalogs. I have a spreadsheet of pretty much every part/part numberI have purchased with price, list price, & vendor. A bit too much to post here. But there are a few online dealers to have the same catalogs as dealers see on their computers posted online.
    Posting prices doesn't do that much good but I suppose.it will serve as a ball park figure I guess. One thing to keep in mind that Toyota pricing varies from dealers. Online dealers are usually much cheaper than my local dealers. Even prices from my local dealers differ significantly on many parts. Then there's inflation, parts I have purchased a year ago cost more now. And even the list/msrp price differs from pretty much every local & online dealer I have purchased from.
    This bugs the hell out of me, list/msrp price should not vary. I can understand online prices being different & prices can vary depending on region but why can't local dealers at least have pricing somewhat close to each other. Well I guess that's just part of business.
  9. Aug 8, 2018 at 1:33 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    That's one thing I noted. These were purchased from Camelback Toyota and yes prices do change. Like you said i's a ball park figure.
  10. Aug 8, 2018 at 2:00 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Awesome, thanks! I’ll be using this in the future. :thumbsup:
  11. Aug 8, 2018 at 11:57 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Ok, here's some of mine, 2001 3.4 DC 1C8. various dealers & vendors though that I won't list (too complicated). Sorry for the weird formatting, just copying & pasting, too lazy to fix. :rofl:
    37.52 38.49
    164.11 98.66
    31.09
    71.22 169.98
    95.46
    5.75
    8.33
    17.41
    9.65
    35.31 35.31
    22.54 12.84
    29.42 29.42
    65.00
    5.27
    10.48
    7.44
    0.99 4.95 5ft
    2.93
    Hood Prop Holder 53452-90351 53210-90353 5.52
    LF Outer Door Scraper 68210-04020 68210-04010 46.97 145 set
    RF Outer Door Scraper 68160-04020 68160-04010 46.97
    46.97
    46.97
    3.28 0.99
    3.28 0.99
    Front Flare Seal (2) 53851-35061
    10.97
    Rear Flare Seal L 61783-35091
    11.51
    Rear Flare Seal R 61783-35071
    11.51
    12.06
    8.82
    37.30
    4.71, 50pcs
    5.33, 50 pcs
    6.99, 50pcs
    74.99
    50.63 35.01
    29.11 20.13
    27.93 19.31
    3.38 2.67
    Grille Clip (7) 90467-12040
    7.49
    2.82 11.28
    14.50 29.00
    3.32 13.28
    95.98
    12.24
    9.95
    Lisle Antenna Nut Socket 29600 #4
    11.34
    152.22
    49.13
    0.74
    0.74
    3.56
    LF Door Sill Scuff Plate Charcoal 67914-04040-B0
    59.22
    25.98
    36.29
    1.79
    2.87
    3.05
    13.71
    73.90 53.52
    3.02 2.72
    1.78 1.61
    26.38
    24.22
    17.75
    3.64
    146.00
    2.59 2.33
    12.15 8.41
    Skid Plate Bolt Black 90080-11373 90119-08A33 1.21
    2.07 1.86
    21.35 15.40
    14.17 11.80
    1.18 1.07
    15.23 10.99
    AJ1001, GQ7227, baachor and 1 other person like this.
  12. Aug 8, 2018 at 12:15 PM
    tony2018
    I actually like this because now that gunny is gone we need to find a way to get part #'s. hopefully he drops back in from time to time though.
  13. Aug 8, 2018 at 12:17 PM
    tony2018
    Brah...this is not oem.
  14. Aug 8, 2018 at 12:20 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    And your point is? My list from that I talked about in a prev post. Those parts I would never buy oem anyway. Don't like it, move on. :thumbsup:
  15. Aug 8, 2018 at 12:22 PM
    tony2018
    Title of thread
    Just trying to keep it correct before someone decides to put those part #'s into a toyota site or sound stupid on the phone.
    GQ7227 likes this.
  16. Aug 8, 2018 at 12:22 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Go online, the part numbers aren't hard to find. Every p/n I have I found in online catalogs.
  17. Aug 8, 2018 at 12:24 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Are you serious? Anyone who orders Toyota parts will know those aren't a Toyota p/n format. ES is Energy Suspension. :facepalm:
  18. Aug 8, 2018 at 1:10 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I always thought energy suspension parts were considered an upgrade anyways. Doesnt bother me.
    zero4[QUOTED] likes this.
  19. Aug 8, 2018 at 2:28 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    If you read the first line of the post. It says some aftermarket part numbers to.
  20. Aug 8, 2018 at 2:29 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Damn!!
