1st Gen Toyota Part Numbers & Prices
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Aug 7, 2018.
  1. Aug 8, 2018 at 2:46 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    You know, after the member above complained about my post I was about to just delete the whole thing but figured it's gotta be useful to others.
    When I get a chance I'll edit it to make easier to read.
  2. Aug 8, 2018 at 2:46 PM
    tony2018
    tony2018 Well-Known Member
    god dammit...
  3. Aug 8, 2018 at 2:47 PM
    tony2018
    wow...complained. I misread something and took it as oem parts only, pointed out that those weren't oem and thats a complaint.
    The way things are these days this doesn't surprise me.
  4. Aug 8, 2018 at 2:57 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Look bro, I don't want to keep cluttering up Jon's thread with uselss jabber. Yeah I took it as a complaint. Rather than receive some gratitude for that list of P/Ns I've compiled for my own use, I get a comment pointing out that I listed non oem Toyota P/Ns which I found unnecessary (BTW, there's more in my list that you missed ;)). Thread title doesn't state specifically OEM P/Ns either.
    If it's good quality or even better than OEM part. What does it matter? But I understand there are those "OEM only" type of people.
    As you said. The way things are these days..... people are so unappreciative, I should just keep quiet next time. :rofl:
    Ok, but fair enough if you thought otherwise. We'll just call it a misunderstanding on both our ends. :cheers:
  5. Aug 8, 2018 at 3:13 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Lets see, for my 2004 2.7 Extended cab 4x4 I have purchased all of the following from the Rice Toyota (Greensboro, NC) parts counter:
    Oil Filter: 90915-YZZD1 $7.46
    Leaf spring main eye bolt: 90105-14025. $5.99
    Leaf spring main eye bolt nut: 90179-14039. $2.99
    Leaf Spring main eye bolt washer: 90201-14005 . $2.99
    Front lower shock bolt: 90080-10124. $5.99
    Front lower shock bolt washer: 94622-41400. $2.99
    Front lower shock bolt nut: 90170-14026. $1.99
    I got all the Diffs drain & fill gaskets off Amazon. The manual Tranny uses the same ones as the rear diff, if I'm not mistaken. So 12157-10010
    mechanicjon[OP] likes this.
  6. Aug 10, 2018 at 12:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    @mechanicjon here i made a more easy to navigate list using @zero4 list as the base
    Table of context
    S1. Drivetrain
    P1.engine
    P2.transmission
    P3.axels
    P4. Drive shaft
    S2.exterior
    P1.body panels
    P2.trim/Accessories
    P3.armor
    P4.lights
    S3.interior
    P1.trim
    P2.eletrical
    S4.suspenion
    P1.Steering
    P2.Rear suspension
    P3.Front suspension
    Section 1
    Part 1 engines
    A1. Timing Belt 13568-69095
    37.52 38.49
    A2. Water Pump 16100-69398-83
    164.11 98.66
    A3. Tensioner 13540-62021
    31.09
    Upper Idler 13503-62040
    71.22 169.98
    A4. Lower Idler 13505-62070
    95.46
    A5. Crank Seal 90311-40022
    5.75
    A6. PS Belt 90080-91126-83
    8.33
    A7. AC Belt 99364-20870-78
    17.41
    A8. ALT Belt 90080-91090-83
    9.65
    A9. Upper Radiator Hose 16571-62070
    35.31 35.31
    A10. Lower Radiator Hose 16572-07040
    22.54 12.84
    A12. Thermostat 82°C/180°F Stock 90916-03075
    A13. Thermostat 76°C/170°F 90916-03107
    29.42 29.42
    A14. TRD Thermostat 71°C/160°F 00602-17621-001 16340-SP010
    65.00
    A15. Thermostat Gasket Fel-Pro 35445
    5.27
    A16. Fan Clutch Towing (green) 08921-0495
    A17. PCV Valve 12204-62010
    10.48
    A18. PCV Valve Grommet 90480-18001
    7.44
    A19. EVAP Vac Tubing Gates 27050
    0.99 4.95 5ft
    A19. Positive Terminal (black) 90982-05035
    21.35 15.40
    A20. Negative Terminal (gray) 90982-06022 (not stock, modification to cable required)
    14.17 11.80
    A21. Terminal Flange Nut 94151-80801
    1.18 1.07
    A22. Pos Terminal Cover 82821-35020
    15.23 10.99
    Part 2 transmission
    Part 3 axels
    Part 4 drive shaft
    A1. Carrier Bearing 37230-35130
    146.00
    A2. Drive Shaft Stake Nut 90179-18009
    2.59 2.33
    Section 2
    Part 1 body panels
    Part 2 trim/accessories
    A1. Hood Prop 53441-04030 53441-AD010 19.54
    A2. Hood Prop Grommet 90480-15028
    2.93
    A3.Hood Prop Holder 53452-90351 53210-90353 5.52
    A4. LF Outer Door Scraper 68210-04020 68210-04010 46.97 145 set
    A5. RF Outer Door Scraper 68160-04020 68160-04010 46.97
    A6. LR Outer Door Scraper 68174-35020
    46.97
    A7. RR Outer Door Scraper 68173-35030
    46.97
    A8.Flare Clip Blue (8) 90904-67036
    3.28 0.99
    A9. Flare Clip Red (18) 90904-67037
    3.28 0.99
    A10. Front Flare Seal (2) 53851-35061
    10.97
    A11. Rear Flare Seal L 61783-35091
    11.51
    A12. Rear Flare Seal R 61783-35071
    11.51
    A13. Flare Protector L 58742-04020
    12.06
    A14. Flare Protector R 58741-04020
    8.82
    A15. TRD Offroad Decal PT211-TT980-28
    37.30
    A16. Fender Liner Screw Clip 90189-06157
    4.71, 50pcs
    A17. Fender Apron Seal Clip 90080-46327 90467-10107
    5.33, 50 pcs
    A18. Fender Apron Seal Clip 90467-10173
    A19. Fender Liner Push Clip 53879-60010
    6.99, 50pcs
    A20. Fender Apron Seal Set
    74.99
    A21. Fender Apron Seal Left 53738-04020
    50.63 35.01
    A22. Fender Apron Seal Right (front) 53738-04040
    29.11 20.13
    A23. Fender Apron Seal Right (rear) 53738-04030
    27.93 19.31
    A24. Front Bumper Top Pad Clip 52161-02020
    3.38 2.67
    A25. Grille Clip (7) 90467-12070
    7.49
    A26. Grille Clip Large Outer (2) 53145-12010
    2.82 11.28
    A27. Tail Light Gasket (2) 81552-04060
    14.50 29.00
    A28. Tail Light Screw Clip (small) 90189-04144
    3.32 13.28
    A29. Tail Light Screw Clip (large)
    A30. Windshield Washer Resivoir 85315-04060
    95.98
    A31. Antenna Assy 86300-04050
    A32. Antenna Ornament 86392-04020
    12.24
    A33. Antenna Nut 86396-16020
    9.95
    A.34 Lisle Antenna Nut Socket 29600 #4
    11.34
    A35. Antenna Assy (automatic) 86300-04060
    A36. Antenna Ornament(automatic) 86392-04030
    A37. Antenna Nut (automatic) 86396-04030
    Part 4 lights
    A1. License Plate Light w/ Gasket 00228-34938
    Part 3 armor
    A1. Skid Plate Bolt Black 90080-11373 90119-08A33
    A2. Skid Plate Bolt Silver 90080-11547
    2.07 1.86
    Section 3
    Part 1 trim
    A1. Inside Mirror w/ Dual Lamp Charcoal 87810-04050-B0
    152.22
    A2. Lens & Bezel w/ Dual Lamp Charcoal 87818-35010-B0
    49.13
    A3. Cup Holder Insert L (1) 66995-AD021
    0.74
    A4. Cup Holder Insert S (4) 66995-AD011
    0.74
    A5. Accessory Switch Cover Charcoal 55539-06010-B2
    3.56
    A6. LF Seat Scuff Plate Charcoal 67914-04040-B0
    59.22
    A7. Window Switch Panel Charcoal 74202-35010-B0
    25.98
    A8. Shifter Bezel 35971-35130
    36.29
    A9. Shift Indicator 35921-35172
    A10. Shift Lock Cover 33554-35050
    A11. Shifter Bushings (4) 33544-27010
    1.79
    A12. Coat Hook Charcoal 74631-35010-B2
    2.87
    A13. Front Door Panel Screw Cap Charcoal 67772-04030-B0
    3.05
    A14. Center Armrest Lid Charcoal 58905-AD010-B0 241-10891
    A15. Tool Kit Band 58780-89102
    13.71
    Part 2 electrical
    Section 4
    Part 1 steering
    A1. Steering Rack Guide 45504-35031
    73.90 53.52
    A2. Steering Rack Guide Spring 90501-26074
    3.02 2.72
    A3.Steering Rack Guide Lock Nut 90179-48003
    1.78 1.61
    A4. Steering Rack Guide Cap 45524-37010
    26.38
    A5. ES Steering Rack Bushings 8.10103.R
    24.22
    A6. ES Sway Bar Bushings 27mm 8.5118.R
    17.75
    A7. ES Tie Rod End Boots 9.13101.G
    3.64
    TRD FJ SE 16" Centercap PTR18-35092
    12.15 8.41
    AJ1001, CS_AR, ToxicTwin and 3 others like this.
  7. Aug 10, 2018 at 12:34 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Thanks @Sperrunner. There's some items on my list that may not make sense so I'll add details for those later.
  8. Aug 10, 2018 at 12:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah i just made the list so @mechanicjon can copy and past to his first post
  9. Aug 10, 2018 at 6:19 PM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I need to spend about 2 hours organizing it all now.
    Sperrunner[QUOTED] likes this.
  10. Aug 10, 2018 at 6:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Sorry for the half ass job, did it at work
  11. Aug 10, 2018 at 7:49 PM
    Pappy Jon
    Pappy Jon Well-Known Member
    RZN60LV
    3RZ
    So is this a 3.4L fest, or can us 3RZ boys play?
  12. Aug 10, 2018 at 8:26 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Not a problem at all. Thx for the input.
    Ya we'll let the little brothers play to.
  13. Aug 11, 2018 at 11:21 AM
    Pappy Jon
    RZN60LV
    3RZ
    Golly, thanks …
    Back story. I don't have a Tacoma, but I do have a 3RZ in the garage for a Gen1 4Runner transplant. I've been working on rebuilding the engine as time and money allow. Engine had 250K on it, and I wasn't going through the effort of installing a high mile engine, only to remove it later for rebuild. Gonna do it now. So, here is my contribution for my "little brothers" out there. These parts are for a Ver2 engine with two coil packs. Note my prices include any shipping or tax I paid.
    OEM Toyota
    Alternator brush holder - 27370-75060, $17.51 (for 80A alternator, not for 70A**)
    Exhaust manifold, 17141-75080 with EGR to replace your cracked manifold, $287.70 list, $211~ish discount.
    Filter, oil – 90915-YZZG2, $4.36
    Filter, oil – 90915-YZZD3, $4.36 (Larger Land Cruiser filter that appears to fit)
    Gasket, thermostat guide - 16119-75020, $1.97
    Gasket Kit, Engine Overhaul, 04111-75102, $181.37
    Gasket, oil cap – 90430-37140, $1.95
    Gasket, oil pan drain – 90430-12031, $0.91
    Head bolts (x10) - 90910-02187, $36.20
    Hose, air, TB – 17882-75040, $21.94
    O-ring, fuel pressure regulator - 90301-07001, $1.72
    O-ring, bracket sub-assy, oil filter – 96721-24018, $4.75
    Plate, cylinder head, rear – 11181-75021, $8.62
    Plate (Decal), engine "16 valve" – 11929-74130, $2.85
    PCV – 12204-75010, $5.53
    Sensor, water temperature EFI – 89422-35010, $58.75
    Spacer, fuel injector - 90561-10018, $8.72
    Spark plug wire clamp, x2, 90469-05006, $1.53
    Spark plug wire clamp, x3, 90469-05007, $3.24
    Spark plug wire clamp, x4, 90469-05008, $1.56
    ** The alternator brushes for the 70A alternator are the same part used on my 1985 4Runner alternator, 27370-35060 ($22.70 list).
    Toyota OEM Timing Parts, both camshafts and balance shafts.
    Cam chain - 13506-75020, $66.00
    Gear, crankshaft timing - 13521-75010, $29.03
    Gear, camshaft timing - 13523-75010, $15.88
    Sprocket, crankshaft timing #2 - 13597-75010, $15.58
    Tension assy, chain #1 - 13540-75020, $17.85
    Slipper, chain tension - 13559-75020, $22.46
    Damper, Chain vibration, #1 - 13561-75020, $30.47
    Chain sub-assy, balance #2 - 13507-75010, $51.40
    Gear, balanceshaft driven #1 - 13632-75010, $4.86
    Gear, balanceshaft driven #2 - 13633-75010, $19.25
    Gear, balanceshaft drive - 13063-75011, $19.25
    Tension assy, chain #2 - 13550-75010, $16.25
    Damper, chain vibration #2 13562-75010, $18.75
    Damper, chain vibration #3 13563-75010, $10.65
    Damper, chain #4 13554-75010, $6.25
    Denso Aftermarket
    AC Compressor – Denso New 471-1242, $175.55
    Sensor, Camshaft Position - Denso 196-1103, $36.40
    Sensor, Crankshaft Position – Denso 196-1108, $53.79
    Sensor, Ox - Denso 234-4153, $45.21 (note I'm using one part number for both)
    Spark plugs – Denso 5303, $19.63 (lots of Denso choices)
    Spark plug wires – Denso 671-4143, $27.02
    Starter, Cold Spec – Denso Reman 280-0178, $123.54
    AISIN Aftermarket
    Clutch kit – AISIN CKT051, $154.77
    Clutch slave – AISIN CRT029, $20.97
    Thermostat – AISIN THT013, $9.40
    Timing Cover – AISIN TCT069, $183.88
    Water pump – AISIN WPT044, $43.36
    Other Aftermarket
    Belt, AC - Gates K040360 (4PK918), $12.63
    Belt, Alt - Gates K050340 (5PK867), $11.24
    Belt, PS - Gates K040440 (4PK1121), $11.60
    Fuel Filter - Wix 33500, $16.38
  14. Aug 12, 2018 at 9:06 AM
    1997tacomav6
    Denver
    As these trucks get older I’ve noticed parts I need that Toyota DOES NOT make any more.
    So may as well add them here, Toyota does not make the driveshaft or differential bracket bushings any more, out of stock.
    Maybe ther should be a separate thread for where to find parts that are discontinued or no longer available from Toyota
    Rear drive shaft 480.00 new with Cardin joint
    https://www.wholesaleimportparts.com/Toyota_Tacoma_Driveshaft_1997.php
    Diff bracket bushings for 4x4 63.00 pair
    https://www.toyotabumpstops.com/index.php/product/1st-gen-toyota-tacoma-front-diff-bracket-bushings/
  15. Aug 12, 2018 at 2:24 PM
    #35
    JakesTacoTRD
    JakesTacoTRD "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    What is the difference between oem and oem trd thermostats? If I have a trd is that the one I should buy? Also I am trying to buy a new radiator cap and they are all sub assemblies. Thanks!
  16. Aug 12, 2018 at 2:37 PM
    #36
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Can we request P/N's here?
    Sperrunner likes this.
  17. Aug 12, 2018 at 2:43 PM
    #37
    License2Ill
    Ian
    Or anybody have a link to that killer parts catalog with the vin input and stellar pictors? I lost the link when I reformated my puter...
  18. Aug 12, 2018 at 3:39 PM
    #38
    mechanicjon
    Jon
    Scottsdale Arizona
  19. Aug 12, 2018 at 3:40 PM
    #39
    mechanicjon
    Jon
    Scottsdale Arizona
  20. Aug 12, 2018 at 7:13 PM
    #40
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    The TRD thermostat is no longer made & they were stupid crazy expensive. They were made to be used with the TRD supercharger. If your naturally aspirated it's too cold to run. Just run the stock 180°. I live in desert climate, I run the 170°. The p/n I have listed for the 170 is an oem Toyota tstat but it's not from a Tacoma.
    JakesTacoTRD[QUOTED] likes this.
