1st. gen. Toyota seat trim. Too pricey.
Discussion in '1st Gen. Tacomas (1995-2004)' started by william bussey jr., Oct 13, 2022.
  1. Oct 13, 2022 at 2:28 PM
    william bussey jr.
    william bussey jr. [OP] New Member
    william (Bill)
    1st. gen. 2004 TRD Tacoma
    K and N Air Flow system, 1000 hours of hand rubbed wax
    My trim piece broke just like almost everyone elses. Hadn't checked prices in over a year. I spent at least 4 - 8 hours laminating a sheet (layer) of fibreglass cloth, with resin onto the back inside, and another layer on the outside of trim. sanded it smooth and covered it with a piece of leather. Looked really cool and custom. Lasted a year and a half. My brand new trim piece just arrived from ( WALMART ), thats right, for under $40.00. Think I'll still put a layer on the back of new one. Appears identical. go Walmart.
  2. Oct 13, 2022 at 3:54 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Being that you've broken a laminated reinforcement already, I'd suggest adding something else into the layup- a few flat pieces of 1/8" alloy or something across where it breaks? Composites generally don't do well in flat panels and need to be reinforced with stringers or other structural members. Maybe lay up some "V" shaped glass stringers you can then glue to the back and then cover in glass?
  3. Oct 13, 2022 at 4:29 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    When I got my first Gen 1 (a 2001) it had that broken trim piece on the driver side. I replaced it with the OEM part, making sure the the tab in the center of the piece was latched onto the metal of the seat. Twelve or so years later, including a swap of that charcoal interior into the 2003 Gen 1 I have now, and the piece is perfect.
    I've often wondered if some trucks not having that center tab hooked up correctly leads to the stresses and strains that result in cracking.
  4. Oct 13, 2022 at 4:31 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I think it's more about how you get in and out of the truck, and to some degree lift.
  5. Oct 13, 2022 at 5:02 PM
    4xdog
    Santa Fe, NM
    Indeed -- could be. I'm 6' 6", so I fold myself into my Gen 1 pretty carefully. :)
    The trim was cracked on my first Gen 1 when I got it, and that little center tab wasn't engaged when I took the piece off to put the new one on.
  6. Oct 13, 2022 at 5:08 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  7. Oct 14, 2022 at 2:19 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
