1st gen toytec coilover and billy 5100 install question
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefsteak, Jul 11, 2011.
  1. Jul 11, 2011 at 8:24 PM
    beefsteak
    beefsteak [OP] Active Member
    TRD 4x4
    Grey Wire mod, Eibach and bilstein 5100s all around, Alcan leafsprings, tundra brake swap with steel lines, loose steering column weld mod, keyless/alarm mod
    Hey guys, I just got a set of toytec adjustable coilovers and new bilstein 5100s for my 03 tacoma. I'm trying to set the the thing up, but not sure which setting I should set the billys on. I read somewhere that the C-clip should be set to on the the lowest setting "0", and that's what's in the directions from toytecs install for the 2nd generation tacoma, but when I spoke to a rep from toytec on the phone, after checking with his coworker, he said the setting should be set at the middle setting. So I dunno...I know OME coils should be set to 0 because the coils are larger, but I think the toytec adjustable coils are stock size, so I dunno what to set the billys on. Also, how high should I adjust the coilover setting?
    Any help would be greatly appreciated. Thanks in advance yall!
  2. Jul 11, 2011 at 8:38 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    so you ordered their adjustible coilovers, and they didnt come assembled?
  3. Jul 11, 2011 at 8:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Toytech doesn't manufacture thier own coils. They use Eibach coils. And I belive the coils themselves are 620# and 3 inch lift. Which means, you'd set the billys at 0 (bottom setting) otherwise you'll be preloading the shit ouf the springs. You can always adjust the preload later with the spanner wrenches instead of the clip on the shock. In the end, you'll still be doing the same thing (preloading the spring).
  4. Jul 11, 2011 at 8:57 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Just ordered the Eibach and 5100 combo, and i didnt get them assembled. You get 3" and set them to 0.
  5. Jul 11, 2011 at 8:58 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  6. Jul 12, 2011 at 7:15 PM
    beefsteak
    TRD 4x4
    Thanks guys, yeah, that's what I figured. I saw the instructions that Jason linked to for the 2nd gen. I ended up calling them to double check again, and a different guy at Toytec said that from what he saw it should be on the "0" setting.
  7. Jul 12, 2011 at 9:30 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    agree, set the 5100 to 0 and you can adjust the coilovers to where you want.
