1st gen Tundra speakers to 2nd gen Tacoma???
Discussion in 'Audio & Video' started by UNDEAD1153, Jul 14, 2012.
  1. Jul 14, 2012 at 8:02 AM
    UNDEAD1153
    UNDEAD1153 [OP] Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    I have a 2011 Tacoma with the non JBL package and installed a kenwood dbl din head unit, it sounds better but still not that great. My grandfather has a 2004 Tundra limited with JBL package, I have been driving it around work a little bit since I work with him. I decided to see what the old yota's were putting out so I turned on the radio and I couldn't even get it to the maximum setting because of how loud the speakers are. :eek: Is there any way I can put the Tundras speakers in my Tacoma going from non JBL to JBL??? And would there need to be anything else changed? Also could I put my speakers from the Tacoma back in the tundra? He keeps his radio off at all times anyways.
  2. Jul 14, 2012 at 8:17 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I think it might be the head unit that is the difference, not the speakers. I've got an 05 non-JLB and can reach the maximum setting fine.
  3. Jul 14, 2012 at 10:17 AM
    UNDEAD1153
    Weston
    I'm looking for a better sounding system, the tundra sounds much better and the reason I couldn't reach the maximum setting is because it was so loud.
  4. Jul 14, 2012 at 1:36 PM
    UNDEAD1153
    Weston
  5. Jul 14, 2012 at 1:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... Even the non-JBL Tundra has an amplifier under the stock headunit. It's a totally different system than the basic Tacoma system.
    I replaced my stock Tundra speakers with Rockfords.
    Not bad, but not as big of a help as I was hoping. I'm really liking the Polks in the Tacoma, but on the stock head unit they were not a big improvement... I could not hear the radio on the highway with the window down.
  6. Jul 14, 2012 at 1:45 PM
    UNDEAD1153
    Weston
    I was just waiting to switch out the speakers from the tundra to the Tacoma because it's free and the tundra sounds much better.
  7. Jul 14, 2012 at 1:53 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    But it won't sound better in the Tacoma.
    The "magic" is in the head unit and amplifier, not the speakers.
    Yes, the stock Tacoma speakers suck, but I replaced mine with $200 Polk component units and it was no better until I replaced the head unit.
    Replace just the speakers and you will be dissapoint.
  8. Jul 14, 2012 at 2:08 PM
    UNDEAD1153
    Weston
    I've already added a new kenwood head unit which made it sound much better, would adding an amp improve it? Or what would be needed?
  9. Jul 14, 2012 at 2:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    At this point, speakers.
    But the Tundra speakers will only be a marginal improvement.
  10. Jul 14, 2012 at 2:19 PM
    UNDEAD1153
    Weston
    Even though the tundra sounds much better?? And is much louder?
  11. Jul 15, 2012 at 4:47 PM
    UNDEAD1153
    Weston
  12. Jul 15, 2012 at 4:50 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You would be ok with putting the Tundra speakers in your truck but it may just be the JVC head unit/Amp with some internal EQing done to make it sound like that. A set of speakers will be your next best move. A set of high sensitivity coaxial or component speakers will sound as good or, most likely, better than the Tundra speakers.
  13. Jul 15, 2012 at 4:55 PM
    UNDEAD1153
    Weston
    New to the audio world so have no idea what "high sensitivity coaxial or component speakers" means haha. Any recommended brands? And how much to get a better sounding, louder system?
  14. Jul 15, 2012 at 5:09 PM
    Warhorseforever
    Will
    Sand Lapper
    Don't worry we all were once. Sensitivity is that amount of noise, measure in DB, that a speaker can make with a given amount of power measured using one watt of power usually the higher that number the louder that speaker will get. Coaxial speaker is one that has the tweeter and woofer attached to each other, it's the easiest to instal, and for the majority of the people in the world looking to do a stereo upgrade. A component system is where the tweeter and woofer are separate. If you don't want to spend the money on an amp look for something ~95db or higher and they'll be plenty loud.
  15. Jul 15, 2012 at 5:27 PM
    UNDEAD1153
    Weston
    Thanks man, got any coaxial speakers to recommend and an idea for the cost for all 4 doors, if all 4 are necessary.
  16. Jul 15, 2012 at 5:30 PM
    Warhorseforever
    Will
    Sand Lapper
    I've only got 2 up front I like the sound of sound coming from up front but you may not. Right now I have Kicker DS65 and they are nice but I'd recommend Polk Audio or Alpine for good cheap speakers.
  17. Jul 15, 2012 at 5:36 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I wouldn't call Polk cheap, but I love my set.
    Didn't go with the coax though... replaced the whole shebang with the Polk db6501 for about $200.
    http://www.crutchfield.com/p_107DB6501/Polk-Audio-db6501.html?tp=106
    I used the TacoTunes adapters.
    I used the 6022i coax on my motorcycle (4 of them) and it sounds great from the Pioneer HU on the highway.
  18. Jul 15, 2012 at 5:37 PM
    UNDEAD1153
    Weston
    Thanks man, I'll look into it more as time goes on. Was just gonna swap the tundras speakers in because it was free and sounded better haha. A color matched grill and eyelids are on the to do list first, not sure what else is above speakers at the moment.
