1st Gen Tuners/Programmers
Discussion in '1st Gen. Tacomas (1995-2004)' started by YODA_01, Nov 14, 2016.
  1. Nov 14, 2016 at 4:28 PM
    YODA_01
    YODA_01 [OP] New Member
    Barrett
    Knox
    3" Leveling Kit ProComp Shocks
    Have any of you tuned/programmed your 1st gens? I have a 2001 with the 3.4 4WD. Don't know if they are a good platform to tune, so I was looking for some insight.
  2. Nov 14, 2016 at 8:09 PM
    1stevertaco
    1stevertaco Well-Known Member
    atlanta
    2000 taco 4x4
    sway bar end links
    there isn't one on the market
  3. Nov 14, 2016 at 9:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Toyota made the ECU very difficult to decode. Or at least difficult enough where no one wants to invest in developing tuner programming.
  4. Nov 15, 2016 at 8:07 AM
    Xyphon112
    Xyphon112 Well-Known Member
    Supercharger is the way most people go it seems. 90 horsepower (I think) bolt on upgrade.
  5. Nov 15, 2016 at 12:06 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Pretty much the Split Sec FTC or the AEM FI/C 6 are you only piggy back options, no true plug and play.
  6. Nov 15, 2016 at 12:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The TRD/Magnuson supercharger adds 60 hp, if you do the smaller pulley/7th injector you can add another 20hp though
  7. Nov 15, 2016 at 12:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    You are correct.
    It's a product for other vehicles. Nothing on there says Toyota does it?
    Go here and check for yourself.
  8. Nov 15, 2016 at 12:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    there was tuners for these trucks. i believe unichip and jet still make them. That being said i talked with both jet and unichip reps and both said that youl really only see at max 5-6hp gain on the 91oct tune and only for the last few hundred rpm. Definitely not worth the $700.
  9. Nov 15, 2016 at 12:58 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    S/C is the only way for more power then. And at almost 250k miles on my 3.4 it's not worth throwing that much power at it. Correct? Transmission would be the next thing to go out with a S/C. Isn't a S/C high maintenance and $$$ anyways? And what's the deal with the knock sensor codes people seem to get? Is that because it's running too lean? Never understood that.
  10. Nov 15, 2016 at 1:06 PM
    eon_blue
    Azusa, CA
    I wouldn't call them 'high maintenance' but there is definitely more cost to owning one than just buying it and putting it on. Premium fuel, gauges, upgraded spark plugs, bigger injectors (or the 7th injector kit) to prevent lean out, stronger clutch for the manual trans, etc. Once you get it all dialed in right then really the only added cost is premium gas, as well as changing out the nosecone oil ever 30k and having to do a rebuild at around 100-150k.
    Then of course there are other mods you can do that aren't necessary, like the smaller pulley and fuel pump upgrades.
    Boost definitely ain't cheap.
  11. Nov 15, 2016 at 1:10 PM
    devinzz1
    devin
    2023 aclb trd or mt
    you can spend $700 on some headers and hate your life installing them for ~10hp. besides that boost is the way to go. at the psi the sc is pushing it doesnt really hurt the engine mechanically. If trans was well maintained i cant see it failing. they are pretty bullet proof. SC themselves are fairly low maintenance and itl be years before youl ever need to rebuild it. knock codes and pinging is from a lean condition allthough this seems to be hit and miss. some trucks do it and some dont
  12. Nov 15, 2016 at 1:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    It wouldn't be to me.
    Trans should not be an issue unless you are ham fisted. Manuals might need a clutch upgrade, especially if you're racy. Autos should have a temp monitor, aux cooler and a temp gauge installed, along with syn fluid, IMHO.
    Unless you intend for the vehicle to be a long term keeper/project. Like rebuilding the motor when it's time and all the other things it takes to make a 'lifetime' vehicle.
    With that type of commitment, it doesn't much matter what you do, it's your entertainment money.
    You know. One that your insurance company would only pay you about 10 cents on the dollar for, unless you had a declared value policy.
  13. Nov 15, 2016 at 1:21 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I plan on keeping this truck forever. Rebuilding tranny & motor when it comes time. I have my Tacoma just the way I want it. I previously had an 06 Tacoma sport w/ the 4.0, " the way I wanted it " first brand new truck I ever bought, but then I went through this thing called a divorce! LOL! Bye Bye Dream truck!!! But at least now I have my 1st gen and slowly but surely dialing it in the way I want it.
  14. Nov 15, 2016 at 1:23 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  15. Nov 15, 2016 at 1:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    In that case, I'd start saving now, and add the SC, headers and such on a fresh motor.
    Maybe find a donor motor to do your rebuild on while driving this one. When it's all done, do the swap.
    Sicyota04[QUOTED] likes this.
  16. Nov 15, 2016 at 2:10 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    The fic 6 is a great product for tuning. The install is straight forward but tedious. With it and an entire exhaust system upgrade I could see netting 20 hp at the wheels and you'd be making a shit ton more power in the mid range. Is that worth $1500? Probably not.
    The TRD s/c is as durable as the truck. That said, it's not exactly a power house. I wish I would have had my s/c in combo with the fic 6 I am running now. The closed loop tuning capability on the fic is the only way to truly utilize the s/c IMO.
    vasinvictor and elnip like this.
