1st gen turn signals to running lights with Switchback LEDs (a how to)
Discussion in '1st Gen. Tacomas (1995-2004)' started by mtucker, Apr 7, 2010.
  1. Mar 9, 2014 at 6:28 PM
    #101
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I would say just tap into the hot wire going to the parking light and run that to the third hole in the turn signal. Don't quote me in this. I hate dealing with electricity :D good luck!
  2. Mar 9, 2014 at 7:46 PM
    #102
    jamco20
    jamco20 Well-Known Member
    James
    Socal
    Bilstein 5100's up front
    I did this mod and i love it, but occasionally when i signal (right or left) the amber light will flash with the "fog" light still on, its like both white and amber light at the same time. If i turn the fog lights off (I have them wired to a switch) the turn signals work fine, this only happens occasionally. Any ideas?
  3. Mar 20, 2014 at 10:43 AM
    #103
    Prerunner225
    Prerunner225 Member
    St. Francisville, LA
    k & n air intake, daystar level, thrush muffler, Alpine type r 12, touchscreen
    I tried doing this mod, everything was done correctly but I kept blowing fuses. I read on here that maybe the led would have to be reversed because the positive and negative on the led. I tried the led before I installed the 12v wire just as a turn signal and it still blew the fuse. I'm pretty sure that the only explanation for this is the led being in the wrong way. is that correct?
  4. Mar 20, 2014 at 10:49 AM
    #104
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I remember there being two versions of the switchback (also make sure you have the CK version) that would leave the white on or turn it off while the amber was being used
  5. Mar 21, 2014 at 3:57 PM
    #105
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I have the parts in ready to do the mod (LEDs and blinker relay... come to find out the relay mod is easy to do...), but waiting to the pins/grommets in to make for a nice clean wire addition to the connector, make it somewhat OE looking and reliable (pins and grommets for Toyota connector 90980–11020)
  6. Mar 22, 2014 at 7:20 PM
    #106
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I got a junk set of pigtails and removed the green and white wires with the connector, just have to push them in place of the stopper
  7. May 9, 2014 at 2:31 PM
    #107
    thoy808
    thoy808 Well-Known Member
    Taylor
    Kea'au, Hawai'i
    04 PreRunner TRD Off-Road
    Toytec AAL Procomp rear shocks Toytec Bilstein front coilovers Nitto Trail Grapplers Pop n Lock Alpine deck Earthquake Audio door speakers Earthqueak Audio 900w 10" JL w3 Satoshi style billet 5000k Kensuns clear park light housing Magnaflow 18" Viper Alarm w/ Remote start Soon to be: deck plate mod blinker to fog conversion Wishlist: Super white 2013 Sport
    How would you wire the 12v source wire to a switch? I have no experience with circuits and I want to make sure I don't mess anything up. Im installing the V3 Triton switchbacks.
  8. Aug 4, 2014 at 11:22 AM
    #108
    mtucker
    mtucker [OP] Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I updated the OP to show that I have tried the "replacement" part for the part I used back in 2009. The old VLED part # was 3157_60_SWACK_5K and the new one is 3157_42_WA2_CK_5K.
    I noticed the driver's side bulb was looking dim. I tested the white LEDs individually and had at least six that were bad, but they are almost five years old so I decided to look for a replacement. The new bulb is similar except it has 42 LEDs instead of 60 and has an aluminum heatsink. Here is the old and new side by side. The new ones are a little longer (new has the aluminum near the end).
    Even though there are 18 less LEDs, the new bulb is definitely brighter than the old bulb....even back when it was new. Although five years isnt' bad, maybe pulling heat out of the LEDs with a heatsink will make this set last even longer.
  9. Aug 4, 2014 at 9:27 PM
    #109
    360taco
    360taco New Member
    Seattle
    03 Tacoma SR5 4x4
    Sub'd. Great write up!
  10. Aug 10, 2014 at 11:19 AM
    #110
    jpar9
    jpar9 Member
    Jeremy
    Dunn, NC
    '01 Tacoma PreRunner SR5 2.7
    Toytec 3" Coils, Toytec Add-A-Leaf, Bilstein 5100's on all 4 corners at 0". 5th Gen 4Runner Limited 20's, 275/60/20 Toyo Open Country AT2
    Where can order those bulbs since they don't sell them anymore?
  11. Aug 10, 2014 at 11:28 AM
    #111
    mtucker
    Escondido, CA.
    03 Prerunner DC
  12. Aug 21, 2014 at 2:32 PM
    #112
    zatarra
    zatarra Member
    Texas
    03 V6 4x4 Tacoma
  13. Aug 22, 2014 at 4:45 PM
    #113
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    That's awesome man! Is this relatively easy for someone who is extremely new to this type of stuff? I read your OP, but I somewhat got confused.
  14. Aug 24, 2014 at 2:29 PM
    #114
    mtucker
    Escondido, CA.
    03 Prerunner DC
    I just updated the OP and added a sections "Known problems". The thread is getting long enough that people might not be aware of the "winking" problem when you hit the brakes or go into reverse. Read through the OP again to make sure you know what you are getting into.
    Putting the Switchback bulb in is plug and play. Adding the third wire to the socket (it was made to accommodate three wires) isn't too bad especially if you use frizzman 's suggestion to get a spare connector/wires so you don't have to form a third contact using wire. You can just slide the new contact in.
    You can find 12V that comes on with your ignition or use a switch so you can turn the 12V on/off to your switchbacks (light up the white LEDs). Running a wire down to the turn signals is fairly easy.
    Avoiding the switchback wink is fairly easy if you want to go with LEDs buls in the rear housings.....more about that in the OP.
    Switchback or not, you will get turn signal hyperblink when you put LEDs in your turn signals. To combat that, you can just put in a turn signal flasher relay meant for LEDs.
    Nothing is too hard, but there are hurdles you have to go over to get everything working. I think it is worth it. It is a unique mod that you don't see much and the "LED running lights" make you much more visible during the day. Although expensive, the new VLED switchbacks that fit our truck have very bright white LEDs.
  15. Aug 25, 2014 at 5:47 AM
    #115
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    only issue I am running into is it is blowing fuses with the ones from fleabay so they are not CK style. I haven't ponied up the cash for the good ones yet as I have a few things occupying my time :(
  16. Oct 24, 2014 at 8:50 PM
    #116
    kevinpt3
    kevinpt3 4runner *****
    Kevin
    Richmond VA
    09 4runner limited
    so if i add the wire and keep the same bulbs i will not have any problems? looking to keep them amber
  17. Feb 28, 2015 at 8:36 PM
    #117
    Frankie Santoro
    Frankie Santoro Color matched master
    Frankie
    Wilmington NC
    Livin Life
    Rims tires 4 inch lift hids roof racks radio color matched bumper, , fenders, 5% tint straight pipe color matched everything
    When you said cigarette circuit is that referring to the back of the cigarette lighter. Just did the mod only took about an hour. Hardest part for me was just hiding all the wire.
  18. Feb 28, 2015 at 9:43 PM
    #118
    mtucker
    Escondido, CA.
    03 Prerunner DC
  19. May 16, 2015 at 8:53 PM
    #119
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
  20. Oct 12, 2015 at 2:54 PM
    #120
    Roo1041
    Roo1041 Well-Known Member
    Riley
    Tuscaloosa, AL
    2003 Toyota Tacoma Prerunner
    aFe CAI 3" OME Nitrocharger shocks w/ 883 Coils Rear OME Dakar Leaf Pack 17x8 ATX AX324 Assault Wheels 265/70R17 BFGoodrich Rugged Terrain T/A Tinted Windows to match stock rears
