1st gen V6 5spd towing a 3rd gen 4Runner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PJL, Dec 28, 2018.
  1. Dec 28, 2018 at 3:55 PM
    PJL
    PJL [OP] Well-Known Member
    Baltimore, MD
    2003 xcab Tacoma 4x4
    Stock
    Hey all,
    I have a 1st gen V6 5spd Taco and I want to know if I could tow a 3rd gen 4Runner I found? I'll be towing it about 50 miles on pretty flat terrain. Thanks for the advice.
  2. Dec 28, 2018 at 3:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You sure can, but it won’t be fun. Curb weight of the 4Runner is roughly 3,600-4,000 pounds. Towing capacity of the v6 is 5,500 pounds. I think you might be better off pulling the rear driveline and using a tow dolly.
  3. Dec 28, 2018 at 3:58 PM
    ClassicVW
    ClassicVW Well-Known Member
    George
    North and South Jersey
    2018 Tacoma SR 4x2 2.7 DCSB MGM
    I think you can tow it, but can you stop?
    970btu, TacomaJunkie8691 and Wulf like this.
  4. Dec 28, 2018 at 4:01 PM
    PJL
    Baltimore, MD
    Stock
    So put the front end up on a tow dolly? As opposed to using a trailer.
  5. Dec 28, 2018 at 4:02 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If he uses a tow dolly he’ll be well under the 5,500 pound towing capacity. I’ve towed a few things and just as long as you have enough room to stop, you’ll be fine. U-Haul equipment all have surge brakes.
    It also helps that I have Tundra brakes.
  6. Dec 28, 2018 at 4:02 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Trailers are much heavier. Tow dolly is 900 pounds versus an auto transport at 2,000 pounds.
  7. Dec 28, 2018 at 4:06 PM
    PJL
    Baltimore, MD
    Stock
    Awesome! Thanks.
  8. Dec 28, 2018 at 4:09 PM
    ClassicVW
    George
    Yeah, that's what I meant to say. Make sure he can hook up the trailer brakes.
    And don't borrow someone's sh!tty trailer.
  9. Dec 28, 2018 at 4:54 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you are using a dolly, I’m pretty sure those don’t have brakes, and if you will be using a car hauler trailer, that will likely put you over the max tow weight of 5000 (not 5500).
    As far as I’m aware, most of the time you need brakes when you are towing over a certain weight (3000# I think), and with a dolly (like you see RVs towing), they use a brake actuator inside the car to operate the brakes pedal.
    So, it certainly can be done, but it’s far from an ideal plaform, and likely won’t technically be “legal”. Whatever you do, avoid the freeway.
    The other thing is that you mostly shouldn’t tow a 4x4 on a dolly, although over a relatively short distance, you’d probably be fine, especially if what you’re towing is a 5 speed.
    Read through the “tow biblel for more info on towing with the Tacoma.
  10. Dec 28, 2018 at 5:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    All U-Haul trailers have surge brakes. They’re better than nothing.
  11. Dec 28, 2018 at 5:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Plug your truck into U-Haul’s website. It’ll tell you everything you need.
    cruxofthebisquit likes this.
  12. Dec 28, 2018 at 5:10 PM
    jbrandt
    Justin
    not the dollys.
    But like you said, the trailers weight like 2000#, and putting a 4000#+ truck on it would exceed the 5k tow limit.
    Wulf likes this.
  13. Dec 28, 2018 at 5:16 PM
    jbrandt
    Justin
    Haha, it will 100% tell yu not to tow it with a tacoma. They will say the dollys are from front wheel drive cars only, and the flat beds are marginal.
    If anythig, don’t tell them what you’re towing. But that will get you in big trouble if anything happenes and you have exceeded the max tow rating of the tow vehicle.
    I would just rent a pickup from uhaul, but even that might only barely tow 6000 (according to their website).
  14. Dec 28, 2018 at 5:23 PM
    UnderFire
    UnderFire Well-Known Member
    Towed a WJ Cherokee on a tilt deck with my 02 double cab, worked fine, went about 30 miles on flat. That's probably about as much as I'd want to tow though, and wouldn't want to tackle many hills.
  15. Dec 29, 2018 at 4:49 AM
    ClassicVW
    George
    (Slaps forehead!) Hows about checking on what a towing service would charge you to just flatbed it home for you?
    Renting a truck and trailer from U-Haul has gotta be a similar price. And then you gotta have someone follow you back to return them. Also figure how much 4 or 5 hours of your time is worth if you do the two round trips yourself. (Also figuring in wait time at the U-Haul place. They always seem to be frazzled and unprepared when I've used them and I've stood around waiting wondering why a business that does ONLY ONE FREAKING THING can't get their sh!t together?)
    And this way you won't risk any harm to your beloved Tacoma!
    970btu, cruxofthebisquit and Wulf like this.
  16. Dec 29, 2018 at 8:19 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Tows are expensive. I had my truck towed maybe 10 miles and it cost $100. A U-Haul auto transport only ran me about $50 unlimited mileage.
  17. Dec 29, 2018 at 8:46 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    FWIW the u haul car hauler can weigh 2000-2400lb depending on which version you get. The older design is heavier.
  18. Dec 29, 2018 at 9:24 AM
    ClassicVW
    George
    What did you use as the towing vehicle? U-Haul's information says you must use a "qualifying vehicle" to rent their auto transport trailer. Will the OP's Tacoma "qualify" in their eyes?
  19. Dec 29, 2018 at 9:27 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Well I used a Chevy Tahoe to tow my 5-Lug, but there’s not a single vehicle made that the 4 cyl Tacoma can tow with the weight of the trailer. Maybe 3/4ths of a Smart car.
  20. Dec 29, 2018 at 9:36 AM
    ClassicVW
    George
    From U-Haul's list of requirements....(there are other requirements such a lighting and mirrors, etc.)
    *Towing Vehicle must weigh at least 3,500 lbs. (curb weight), and must equal or exceed 80% of the combined weight of the trailer (2,210 lbs.) and the vehicle being towed (up to 5,290 lbs.).
    *Must have a towing system that has a 5,000 lbs. minimum weight-carrying rating.
    OP's Tacoma may or may not weigh enough, depends on what his VIN plate says, the internet says a 2003 Tacoma weighs 3430 lbs. (70 lbs too light)
    I picked a 2017 4 Runner and it weighs 4675
    U-Haul's trailer weighs 2210
    Either way, the Tacoma does not weigh 80% of the trailer + 4 Runner combined weight of 6885.
