1st Gen Various
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by scofflaw, Feb 13, 2022.
  1. Feb 13, 2022 at 7:45 PM
    scofflaw
    scofflaw [OP] Well-Known Member
    Hoping to sell/give away/recycle some parts after doing front end work last week. All parts are from a 2000 Tacoma 4x4. Hmu and I can ship or deliver throughout California (may take a while but I travel the length of the state fairly often). Mostly just want to see if anyone can use these before I recycle them.
    - front brake lines (OEM) including the brackets that attach to the steering knuckle
    - front brake dust shields (OEM) including the right bolts
    - spark plug wires (NGK) that I used for about three weeks—old ones gave out and I got these at autozone while waiting on the OEM wires that I put on. These are the sexy blue ones that you see in a lot of pictures on this site and they also have the clips that keep them all together as pictured.
    - brake rotors (OEM) there is a small lip on these so they should be resurfaced but are otherwise in fine shape
    - CV axles (aftermarket) boot is torn and patched on one and the other is totally fine, just wanted to do them at the same time, fwiw the patched one was also just fine—it tore sometime over the summer and lasted the 6+ months to now without issue. The reman folks in Denver won’t accept these as cores because they are not OEM
    - brake master cylinder reservoir grommets, which go in between the metal cylinder and the plastic reservoir, these are for ABS trucks and mine is not, they are different from non ABS in important ways, VIN fitment is of not help for ABS v non ABS which is why I bought the wrong ones, part no. 47255-16010
    E73C1D3D-F38F-409C-BF6C-4F14BB841F07.jpg C412B7C1-D09A-45FE-9BB2-53C18466111B.jpg 6FF408F4-C484-41E8-BD24-6D59E976D4F4.jpg 708A4C64-0588-4294-8CF7-FE30591E7D28.jpg B7245355-0111-46D0-9A2B-9656F93BA8E9.jpg 26532DF0-CDF5-4822-A689-E00F7512BDA4.jpg 8CA082C4-A711-44B3-A84D-42C12143F292.jpg A45CA723-DDF6-4CCD-9051-7CA0157A3287.jpg
    Nessal, Area51Runner and Nicklovin like this.
  2. Feb 14, 2022 at 7:36 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I'd take the dust shields if you're willing to ship them.
  3. Feb 14, 2022 at 8:26 PM
    scofflaw
    Hi there—regrettably those are spoken for already but will let you know if for some reason that falls through.
    Jiveydude likes this.
  4. Feb 19, 2022 at 8:02 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Still have the front brake lines?
  5. Feb 19, 2022 at 8:16 PM
    scofflaw
    Sorry, spoken for already.
  6. Feb 20, 2022 at 11:45 AM
    scofflaw
    Rotors, CV axles and reservoir grommets are all still available.
    I also have a Dynamat 11905 Hoodliner insulation pad for under the hood of a first generation Tacoma, which was cut to match the OEM insulator. I found it to be too thick and took it off but someone else may find it useful. I have the clips for it as well, somewhere. It’s not fancy but it was only on the truck for a few months. 3/4” thick and originally adhesive backed but adhesive has been used. Holes for the clips are marked but have not been cut/stamped. Flexible on price, just want someone to get use out of it rather than trash it.
    9DDB81B2-5A13-4F5D-A816-8700BD9C1C45.jpg 2AD2A12D-DA0C-4047-BD37-89FD370727F6.jpg
