1st Gen - Who has Leveling Kit Spacers? Ball Joint touch Spring????
Discussion in '1st Gen. Tacomas (1995-2004)' started by bama trd, Aug 20, 2013.
  1. Aug 20, 2013 at 4:39 AM
    bama trd
    bama trd [OP] Well-Known Member
    Alabama
    2007 Silver Tacoma TRD Off Road
    Painted Grill with painted Land Cruiser emblem,Tinted Windows, BF Goodrich AT 275/70/17's on 4 Runner SR5 Rims, Bilstein 5100 front and Rear, debadged, fog light on anytime mod,
    I recently installed brand new Kelly Safari TSR 265/75 tires and I really need this 2.5" leveling kit to work. But when I drop the lower control arm and install the spacer, I try to reinstall and the spindle is forced downward , forcing the Ball Joint into the Spring pretty hard!!! Anyone else have or had this problem? What did you do without buying aftermarket UCA's ???:confused:
  2. Aug 20, 2013 at 4:55 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    you need new UCA's or you need to go lower on the lift, enough said...
  3. Aug 20, 2013 at 6:58 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    fixed :D
    You can lift the front end properly (either stock springs and 5100's or eibach coils and 5100's) with stock UCA's and there will be enough clearance. I'm not familiar with spacer lifts but everything I've read on them says they are not good, throw everything out of whack...that may be your problem. I have a 3" lift in the front and when I had stock UCA's....I had zero problems.
  4. Aug 21, 2013 at 4:55 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    if you set the 5100 strut to 2.5, using stock coils or Eibachs, you may have ball to coil contact on full droop, plus proper alignment (especially caster) will be hard to achieve...it depends on the truck, some are ok, some are not...
    anyway, spacer lifts are not the way to go...I would imagine you installed blocks in the rear, not an AAL? This can lead to problems too..
    not all lifts are equal..
  5. Aug 21, 2013 at 5:02 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I'm interpreting bama trd as having installed a spacer kit that gives 2.5" lift. This causes the spindle in full droop to be 2.5" lower than stock.
    @bama trd: While the truck is supported at the frame, you can put a jack under the lower control arm and raise it. This will compress the suspension and let you move the spindle away from the coil. However, as others have said, spacers are bad. You can imagine the setup will stress the ball joint and cause it to fail prematurely.
  6. Aug 21, 2013 at 6:00 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Is the ball the joint hitting the spring after you've dropped the truck back down to the ground?
    Is the spacer 2.5" tall or the overall advertised lift supposed to end up at 2.5" tall?
    A couple solutions:
    1. Uniball UCAs.
    2. Shorter top plate spacers
    Pictures would be most helpful.
    Top plate spacers (like body lifts) aren't necessarily bad. It is just that there are better ways of solving the same problem. And, like everything else in life, best in moderation.
    BTW, I had a 3" lift in the front using OME coilovers and had spindle to coil contact with the stock UCAs at full droop. Solved it with Icon UCAs. YMMV.
  7. Aug 21, 2013 at 7:24 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
  8. Aug 21, 2013 at 7:40 AM
    tomtom
    The Desert SW
    2012 FJ
  9. Aug 22, 2013 at 9:52 AM
    bama trd
    Alabama
    Thanks everyone for the replies, it was an advertised 2.5" spacer front lift. I sent it back for a full refund. I didn't get to drop the truck down off the jack stands with it installed, because the ball joint was hitting the spring so hard. I just pulled it right back off. I'm going to save and purchase the 5100 shocks, I just hate to buy new upper uca's ....I've heard they're really expensive...
  10. Aug 22, 2013 at 9:55 AM
    bama trd
    Alabama
  11. Aug 22, 2013 at 1:20 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    You can get LR UCA's for <$400. Not that bad compared to some of the uniball setups out there.
  12. Aug 22, 2013 at 2:08 PM
    tomtom
    The Desert SW
    2012 FJ
    Not sure LRs will solve the problem because they have a ball joint just like stock. Would have to compare the two geometries between stock and the LR to see.
  13. Aug 25, 2013 at 2:18 AM
    bama trd
    Alabama
    Just order Bilstein 5100's for Front and Rear!!! Can't wait , Thanks Guys
