1st Gen: Zerk locations on 4x4 driveshafts (8 on regular cab, 9 otherwise))
Discussion in '1st Gen. Tacomas (1995-2004)' started by JasonLee, Nov 17, 2014.
  1. Nov 1, 2019 at 10:06 AM
    W1JCW
    W1JCW 2016 TRD Sport 4x4
    Bryan, Texas
    Tacoma TRD Sport 4x4
    I will check the entire drive train and look for them on my 2016 4x4 and report back.
    GQ7227 likes this.
  2. Nov 1, 2019 at 10:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i recently heard from mechanic that the newish trucks are all sealed, no greasing necessary :notsure:
  3. Nov 1, 2019 at 10:10 AM
    W1JCW
    Bryan, Texas
    Will let the group know what I find when I get under there this weekend.
    Will take pictures if I remember to take my cell under there.
  4. Nov 1, 2019 at 5:51 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Might be more helpful to post that in the 3rd Gen forum. This article is in the 1st Gen forum so it won’t get much visibility for those who can use it.
    JasonLee[OP] and GQ7227 like this.
  5. Nov 1, 2019 at 8:41 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    This is a great reference m. I need to get under my truck and make sure everything gets properly lubed.
    What brand(s) of grease are preferred? I saw some one recently name drop Lucas Red ‘n Tacky...
    Ace115 likes this.
  6. Nov 1, 2019 at 9:06 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I’m using the Lucas Red and Tacky. Works great and is easy-ish to clean up.
    joe25rs and GQ7227 like this.
  7. Nov 2, 2019 at 11:44 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yep, that's exactly what you're wanting to do GQ. This is good news that you're picking up on clues to see what has been and hasn't completed. Now keep in mind they may have hit that zerk with grease but wiped the zerk with a rag afterwards, being that zerk sticks out and could be more visible. That zerk you mention is the one used to get grease to the splines of the two drive line halves. That grease for that zerk only is supposed to be an NLGI 2 and moly fortified. The '2' is thicker or more viscous than '1' or '1.5' and holds better there in the splines. Typical symptoms of needing grease there would be a slight clunk feel in driveline when move from brake pedal to accelerate pedal.
    But it wouldn't surprise me if they didn't grease it. Glad you're seeing that stuff though
    GQ7227[QUOTED] likes this.
  8. Nov 2, 2019 at 12:26 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    good info! much to learn still have i
    sounds like you went to the mechanics school!
  9. Nov 2, 2019 at 3:52 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    I dunno, man--I might pay $40 just for that thumb release feature that tool has...
  10. Nov 3, 2019 at 12:51 PM
    joe25rs
    Joe
    Mrr’land
    2004 Black TRD
    Bought a nice Lincoln grease gun, a tube of Lucas Red and got to greasing today. It seemed like several of the joints were in dire need of lubricant. Glad I got on that before it gets real crappy out. I finished the service with the addition of rubber zerk caps on each fitting. :thumbsup:
    GQ7227 and cruiserguy like this.
  11. Nov 5, 2019 at 12:07 PM
    W1JCW
    Bryan, Texas
    2016 Tacoma 4x4 one fitting per U joint, very easy access x3 and 1 x 90 degree fitting on the front drive shaft into transfer case. 3 pumps per joint all set to go
    Did notice drain plug for transmission too. Thought it had to be sucked out the side access.
    GQ7227 likes this.
  12. Nov 5, 2019 at 1:26 PM
    JasonLee
    JasonLee [OP] Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Hey, you're in the 1st gen section. This thread is about 1st gen trucks only. That means 1995.5 - 2004. I edited the title of the post - maybe that will help you out.
    :stayontopic::threadjacked::threadjacked::threadjacked:
    a400ryan, ontarioyota and Ace115 like this.
  13. Nov 20, 2019 at 6:35 PM
    mastaplanna
    mastaplanna Member
    So I broke off the zerk in the middle of the carrier bearing...the space was too small to fit the thumb release connector on so I used the traditional connector on that one...I still cant get the zerk fitting out of there...I figure the worst thats gonna happen is grease is gonna fling out of there...anyone else ever have this issue? All the other fittings went perfectly well though
  14. Nov 21, 2019 at 11:54 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    i don't recall where i may have seen it but somewhere i saw that there is (or may be) a zerk in the carrier bearing of the 1st Gens. I dont recall seeing one. Anyone know for sure off hand?
  15. Nov 21, 2019 at 1:30 PM
    #35
    zach141b
    Zach
    Louisiana
    There wasn't one when I replaced that part a few months ago on my 3.4L 4wd 2001 double cab.
    Ace115[QUOTED] likes this.
  16. Mar 6, 2021 at 6:16 AM
    #36
    cobascis
    cobascis Active Member
    2004 Tacoma SR5 4x4 3.4L
    ARE Camper Shell
    Thank you for this thread! This was a huge help. Not sure when the last time mine were done--carfax said "chassis lubricated" about a decade ago. But who knows if they got to all of these.
  17. Mar 6, 2021 at 7:46 AM
    #37
    W1JCW
    Bryan, Texas
    coincidently I just did my Tacoma yesterday. There are many configuration but mine is simply right on the side of the U joint at the diff, trans and 4 wheel conversion point.
  18. Jun 29, 2021 at 1:23 AM
    #38
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Can you let me know where you bought your driveshaft and do you have any issues with it? Thanks!
    1997tacomav6[QUOTED] likes this.
  19. Jun 29, 2021 at 7:36 AM
    #39
    1997tacomav6
    Denver
    Nessal[QUOTED] likes this.
  20. Jun 29, 2021 at 2:46 PM
    #40
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    Great info and pics @JasonLee ...thanks.
    As a regular cab owner I just thought I would chime in on my 2001.
    I only have 8 zerks. My front driveshaft is the same as yours with 3.
    My rear driveshaft does not have a carrier bearing and therefore the Cardan joint is right at the transmission with 3 zerks. The rear axle has 2 just as yours.
    I guess with the short wheelbase the carrier bearing was not needed. 103 inch rear shaft as shown in @1997tacomav6 link above.
    Hope this helps the regular cab/standard cab 4x4 owners. 8 zerks total 100%.
    JasonLee[OP] likes this.
