1st Gen: Zerk locations on 4x4 driveshafts (8 on regular cab, 9 otherwise))
Discussion in '1st Gen. Tacomas (1995-2004)' started by JasonLee, Nov 17, 2014.
  1. Jun 29, 2021 at 2:47 PM
    #41
    JasonLee
    JasonLee [OP] Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Thanks for the addition to the thread!
  2. Jun 29, 2021 at 3:41 PM
    #42
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    You are very welcome and you’re certainly on the ball updating the title of the thread!
    JasonLee[QUOTED][OP] likes this.
  3. Jun 30, 2021 at 1:09 AM
    #43
    starsandskies
    starsandskies Member
    kevin
    03 3.4 4wd manual
    Hello, first post(I thought I signed up in the past, but couldnt locate my account) here on the forum. Very informative.
    Kevin from Vegas. Saw this here post and wanted to say that Ive asked several times at oil change places to please grease the drive components and every time when I asked if they had greased them they responded, "the service manual says you dont have to", so I do it myself.
    JasonLee[OP] likes this.
  4. Oct 23, 2022 at 6:58 PM
    #44
    Zoster57
    Zoster57 Member
    2004 Red Tacoma
    None
    What a great thread. So helpful. I found I could not get my LockNLube coupler to engage on the middle of the three Zerks on the carrier bearing. I had to use a 1/8” regular coupler. That worked fine. Thank you so much for the work on this thread.
  5. Oct 24, 2022 at 10:31 AM
    #45
    Noakea_Bean
    Noakea_Bean Well-Known Member
    Noakea
    2001 Toyota Tacoma SR5 4X4 2.7L
    42" Light Bar
    I only have wheel bearing grease in my grease gun. Can I use that? It's grey (the grease) if that changes anything
  6. Oct 24, 2022 at 10:41 AM
    #46
    JasonLee
    15 TRD OffRoad
    Check the owners manual, I no longer have a 1st gen, but I think it calls for NGLI#2 grease. As long as your wheel bearing grease has this it should be fine, @Noakea_Bean
  7. Oct 24, 2022 at 11:23 AM
    #47
    Noakea_Bean
    Noakea
    42" Light Bar
    Awesome thanks!
  8. Feb 5, 2023 at 3:03 PM
    #48
    Stereo
    Stereo Well-Known Member
    Laura
    Colorado
    2003 DLX Xtra Cab SR5 4WD M/T 3.4
    I am comfortable with hands-on and have religiously changed my own synthetic engine oil by 5k, but I am now looking to lube my driveshaft for the first time myself. I have read several threads to get comfortable with the location of the zerks and procedure and this thread has been very helpful. Thank you!
    My main worry is applying too much grease to the zerks on the slip yokes to avoid any issues. (Recommended 2-3 pumps max.) My understanding is that, for the other zerks, you can squeeze until grease starts to come out, though some say to wait 'till you see the new grease and others say you risk blowing the seals that way so you should only push 'till you see a bit of the old grease come out.
    I want to confirm that the zerks I need to be most conservative with are the ones that are located ON the slip yokes, i.e. the arrow on the bottom in the far right photo in the rear series and and the arrow on the right in the first photo in the front series. Do I have that right?
    Black97v6MT likes this.
  9. Oct 20, 2024 at 3:12 PM
    #49
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I know this thread has been dead for a bit, and I hate to resurrect it; but I have a really simple question. I need to grease up the old gal (almost 200k) and was wondering what size fitting(s) are needed for the zerk locations.
  10. Oct 31, 2024 at 2:23 PM
    #50
    Taco302
    Greenbow, Alabama
    Bump
  11. Oct 31, 2024 at 7:28 PM
    #51
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    Are you asking what size the zerk fittings are? If so they are 6x1mm.
    Taco302[QUOTED] likes this.
