1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Woodman1!, Oct 2, 2019.
I have a1999 tacoma it ran good one the day it want start. Battery is good.
  1. Yes
  2. Yes
Results are only viewable after voting.
  1. Oct 2, 2019 at 10:41 AM
    Woodman1!
    Woodman1! [OP] New Member
    Tony
    1999 tacoma
    1999 tacoma drove it one day next day want start. The battery is good.
    Taco critter likes this.
  2. Oct 2, 2019 at 10:54 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    could be multiple different things. Does it crank? Do the lights dim and flicker while cranking if able to? If it does not crank at all or struggles to and dies then it could be battery or starter. If it does crank and the lights do not flicker or dim then it could be the fuel pump. Fuel, electricity, ignition are the 3 routes you want to look into
  3. Oct 2, 2019 at 12:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Welcome.
    Simple, fuel and spark.
    If jumping it solves it, test the battery elsewhere. Then your charging system ,etc. Sometimes it could be as simple as a ground.
    If jumping doesn't start it up, start looking at fuses/relays that are fuel related before going into the fuel pump. Afterward fuel pressure, and if that's good, then the fuel filter and so forth.
    I suggest you proof read your posts before submitting a reply btw.
  4. Oct 2, 2019 at 1:29 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Wow, you really have a way with words... did you make this a poll on purpose?
    The sparse details you’ve given, it could be a billion different things.
    Does it crank, but wont start?
    Does it click, but won’t turn over?
    Does anythig happen when you turn the key?
    Couple other tips. You’re in the first gen section, so your chosen title is superfluous, and not descriptive at all.
    There is also a search feature which you may find someone who has had a similar issue, and don’t need to wait for people to post a possible solution.
    GQ7227 likes this.
  5. Oct 2, 2019 at 2:14 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Mr. Obvious would say, "are you using the proper key'', it has happened to me on a couple occasions :facepalm:
  6. Oct 3, 2019 at 6:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    A few years ago I was in Ely NV with an almost empty tank. I put the key in the fuel fill cover and tried to turn it, but no go. There I was 400 miles from home, and couldn't get the damn door open. :angrygirl:
    Turned out that I had the right key, but for some reason (probably terminal senility) I was turning it clockwise instead of counter-clockwise. Boy was I relieved when I finally figgered it out. :facepalm:
    GQ7227[QUOTED] likes this.
  7. Oct 3, 2019 at 6:39 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have only had problem opening fuel tank door once, but that was because of the freezing drizzle had coated that side with a sheet of ice, low on fuel but close to home. luckily the gas station had some OVERPRICED lock de-icer and saved the day! ... only used that stupid bottle once
