1st Offroad Attempt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023Obar, Mar 23, 2023.
  1. Mar 23, 2023 at 7:10 AM
    2023Obar
    2023Obar [OP] Well-Known Member
    Central VA
    2023 TRD OR Lunar Rock
    * Tacoma TRD Lift Kit/Suspension Kit https://parts.toyota.com/p/Toyota__/Tacoma-TRD-Lift- Kit-Suspension-Kit/103339628/PT84K35221.html * UnderCover Tonneau https://undercoverinfo.com/undercover-flex * Spotter Mirror https://spottermirror.com/make/toyota/tacoma/ * Brite Box Anytime https://www.aspireautoaccessories.com/products/the-brite-box-toyota- tacoma-2016-2021?variant=39362278719552 * Bullet Point TacoBar https://www.bulletpointmountingsolutions.com/pages/toyota-tacoma- phone-mount-system-gen-3-2016 * Auxiliary Fuse Block Bracket https://overlandequipped.com/collections/fuse-block- bracket/products/copy-of-auxiliary-fuse-block-bracket-for-3rd-gen-toyota-tacoma-2016 * Blue Seas Fuse Block https://www.amazon.com/Blue-Sea-Systems-Blade- Block/dp/B001P6FTHC?&linkCode=sl1&tag=jeannet- 20&linkId=ea9025972a23e75ce7cde62b3f58ab70&language=en_US&ref_=as_li_ss_tl * Blue Seas Circuit Breaker https://www.amazon.com/Blue-Sea-Systems-Circuit- Breakers/dp/B000MMFJJI?&linkCode=sl1&tag=jeannet- 20&linkId=4470c99f70290fc3a632e51a3c69bf4d&language=en_US&ref_=as_li_ss_tl * Car Hard Wire Charger, 12V to 5V Dual USB Female Port Charging Cable https://www.amazon.com/dp/B07H6W1BZG?psc=1&ref=ppx_yo2ov_dt_b_product_details * Body Armor 4x4 HiLine Front Bumper https://bodyarmor4x4.com/products/tc-19339-front- winch-bumper * Rough Country Winch https://www.roughcountry.com/winches-and-accessories.html * Rough Country 20" Light Bar https://www.roughcountry.com/20-inch-led-light-bar- 70920bl.html
    Mar 11, 23 I completed my 1st attempt at easy off-roading. I made it up Flagpole Knob, in the George Washington Forest in Virginia, without incident. Now I need to spend more money because I am officially "bit" by this off-road bug. Damn it! :spending:
  2. Mar 23, 2023 at 7:40 AM
    Soppyrunner
    Soppyrunner Well-Known Member
    Madera
    2023 Lunar Rock TRD OR
    Meso customs chrome delete, console and glove box organizer, D ring shackles
    Howd it go? Is everything under the hood and tires still stock?
    2023Obar[OP] likes this.
  3. Mar 23, 2023 at 7:47 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    What I posted in another thread where guy is looking to drop major coin for mods and had no idea what his truck could do. You’d be amazed at what your truck can do stock and puts upgrades into a better perspective. Try to find a group you can go with and try something a bit harder then decide what would serve you best.
    Ricardo13x, Squirt, hiPSI and 8 others like this.
  4. Mar 23, 2023 at 7:47 AM
    2023Obar
    Central VA
    Still working on it. I have done a few inside mods that I will add to my build page, once I organize everything. Engine and transmission are stock. I did add the OEM Tacoma TRD Lift Kit. Suspension Kit (Part Number: PT84K35221). It adds 2" to the Off-Road front and 1" to the rear. Tomorrow I am adding Spidertrax WHS007 Black Wheel Spacer Kit, 1.25" and some 285/75/16 Falken Wildpeak AT3W tires. Beyond that some recovery gear, external compressor, winch, Body Armor Hi-Line Bumper, light bar, and I am sure more to come.
    Ricardo13x likes this.
  5. Mar 23, 2023 at 7:54 AM
    Soppyrunner
    Madera
    Love this. Unfortunately but probably fortunately I have a wife that won't let me go out and buy all that unnecessary stuff if i wont use it too often. My only plan is to suspension lift, tires, and wheels and that's about it. Trucks meant to go off road in my mind being stock. So with my little upgrades ill feel comfortable driving it everyday on the pavement and hitting up some trails on the weekends once every blue moon.
    Ricardo13x and 2023Obar[OP] like this.
  6. Mar 23, 2023 at 7:58 AM
    taco_naranja
    taco_naranja Well-Known Member
    New York
    2017 Inferno Tacoma TRD OR
    Prinsu, bronze Method 305, Bakflip MX4
    Trail recommendation: Davis trail in WV between black water falls and canaan loop road. Great camping back in there too.
    bls82261, J Williams and 2023Obar[OP] like this.
  7. Mar 23, 2023 at 8:00 AM
    2023Obar
    Central VA
    Agreed. That first trip I was blessed with a knowledgeable local to help me via FRS radio he had in his rig (I always keep my Baofeng GT-3WP on board). I really think the tires I mentioned earlier in the thread, will help my reach and capabilities to where I wanna be. Nothing as outrageous as some of these rock-crawler things are doing, just some good ole' boy off-road fun. Not that the rock-crawling doesn't look awesome, just not what I need or want.
    J Williams likes this.
  8. Mar 23, 2023 at 8:02 AM
    PTSDTherapy
    22 SR5 DCSB
    You really don’t even need a suspension lift. Just shocks that perform like you want. I let a few guys drive mine and the comment was that it was nice to have that little bit more downtravel that I still had.
    Running 32’s now and it seems adequate for most anything.
  9. Mar 23, 2023 at 8:03 AM
    2023Obar
    Central VA
    Same for me! Leaving wheels stock for now, but I'll probably be 75% on and 25% off. A couple weekends a month if I'm lucky enough to find a local group to get out with.
  10. Mar 23, 2023 at 8:04 AM
    2023Obar
    Central VA
    The Falken's I'm going to are technically 32.8". I am sure they will get me where I wanna go. If not, then I got no business being there anyway. :devil:
  11. Mar 23, 2023 at 8:05 AM
    PTSDTherapy
    22 SR5 DCSB
    And if you need to test winter grip or shock setup forest road 112 that turns off of 28 and is 14 miles of single track forest road that goes to spruce knob lake in wv. From Staunton take route 250 all the way to WV then turn right on 28.
  12. Mar 23, 2023 at 8:13 AM
    2023Obar
    Central VA
    This is the kind of stuff I'm talking about. Looks fun, but no thank you!
    J Williams and LeakyAC like this.
  13. Mar 23, 2023 at 9:18 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I did not see skid plates mentioned ... RCI from front plate back to transfer case and converter covers is $1000+ (steel less money than aluminum) but it will protect the underside fro your ... um ... er ... "ill-advised decisions". There are other brands and much discussion in Garage>Armor and a recent "Full Skid Plates".
    LeakyAC and 2023Obar[OP] like this.
  14. Mar 23, 2023 at 9:32 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I'm going to remain stock until I need new tires then I'm going to upgrade to something more substantial and then I'll feel
    better about going places I normally wouldn't. Lots of places to roam around the desert but you sure don't want to get stuck
    out here especially when it's 900 degrees out there.
  15. Mar 23, 2023 at 10:55 AM
    Soppyrunner
    Madera
    Whats your current setup? shocks? uca? aal? blocks?
  16. Mar 23, 2023 at 10:57 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Everyone writes off a bone stock SR5 4x4...til someone who knows their stuff gets at the wheel lol
    J Williams and TexasG like this.
  17. Mar 23, 2023 at 11:59 AM
    PTSDTherapy
    22 SR5 DCSB
    None of the above. Bone frickin stock with 32’s. No rubbing anywhere even at full stuff. Now I am running skinnies because for what I do they seem to work better. And my e rated 235/85/16’s are the same weight as 265/75/16’s so I pick up the durability and air down ability without the weight compromise.
    The only thing I’m going to change out is the shocks and that’s for a change in compression and rebound ie different valving. Don’t need a lift. 32’s get it done for me. The advice given to me was correct.
    I’ve held an SCCA license and ran an old Chevy Biscayne in the old NHRA pro mod class. I’m a gear head at heart. I can tell you how to go fast on a track but I didn’t and still don’t know enough shit about off-roading. The guy that gave me the advice was 26 years old and had been off-roading with his dad and uncle for years. Most guys my age I know would have an issue with listening to a guy not quite half my age. Action in Panama, Kosovo, Iraq, the Stan, and Syria over the last 30 plus years taught me that if you humble yourself and listen you can learn more than you ever thought possible…often from those who you wouldn’t usually associate with.
  18. Mar 23, 2023 at 12:11 PM
    2023Obar
    Central VA
    Thank you for your service! Glad you made it home! Always stay humble, it's the fastest way to learn.
  19. Mar 23, 2023 at 1:19 PM
    Coldies
    Coldies Well-Known Member
    Travis
    San Diego
    2020 TRD Off-road 4x4 DCSB
    My wife drove my Tacoma (I was pulling our trailer in my F150) off the lot straight to our local desert ocotillo wells. I was blown away how capable these trucks are bone stock. You would be completely happy with bigger all terrain tires, start there. It may or may not lead to new shocks. You don’t need kings or Fox’s to have fun, although they are amazing, there’s cheaper options. Just really depends on where you off-road and how much. I would also suggest recovery gear as well and some way to re-inflate your tires. I use a battery powered Makita inflator and it’s worked for a few seasons for me. Nothing wrong with doing it in stages. The more you go out there and wheel, you’ll soon know what you do and don’t need.
  20. Mar 23, 2023 at 1:38 PM
    RichochetRabbit
    Another aspect to consider, not as obvious visually. The exhaust from the driver side crosses over UNDER the transfer case instead of behind, which some call "low clearance". If you add transfer-case armor, the company will ask if you re-routed the exhaust. I was told of (I am not an expert but ...) two options
    > A new stainless (non-rusting) kit like this from Borla: https://www.borla.com/products/toyota-tacoma-connecting-pipe-60699 (you see the price)
    > Find a local muffler shop that re-routes without full replacement of the Y-pipe (can be as low as $140)
    To find a local shop go to the regional forums (https://www.tacomaworld.com/forums/regions.36/) and post the question.
