1st oil change, i did it!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, Oct 4, 2008.
  1. Oct 4, 2008 at 9:55 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i just did my first oil change to mobil 1!!! oh yeah!!!!
    the funny thing is... i put in 5.5 quart of oil.... and when i put the old oil put into the 5 quart jug, it did not even fill it up??? what happened??
  2. Oct 4, 2008 at 10:02 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably not fully filled from the factory......it happens.
  3. Oct 4, 2008 at 12:45 PM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    some in oil filter
    normal oil consumption
  4. Oct 4, 2008 at 1:10 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    oh... ok, i hope mobil 1 rocks my world!
  5. Oct 4, 2008 at 1:16 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    mobil 1 will do good for me right? I like to keep my truck in perfect condition!
  6. Oct 4, 2008 at 1:34 PM
    mycoma
    mycoma Active Member
    Mobile1 is good, Im going to use Castrol GTX
  7. Oct 4, 2008 at 1:44 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    castrol gtx? regular conventionl oil?
  8. Oct 4, 2008 at 2:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....mobil1 is fine, and you can do 5k oil changes now...the synthetic gives you a little prolonged oil change.
  9. Oct 4, 2008 at 5:03 PM
    IB Slingin
    IB Slingin Well-Known Member
    If you really want to make changing your oil a breeze, pick up one of these bad boys. You wont spill a drop....
  10. Oct 4, 2008 at 8:55 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Where can I get one of these?
  11. Oct 4, 2008 at 10:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I had a friend that had one of those, and it was knocked off when off roading. Made for a short off road trip. If you do any wheeling near rocks, stick with the regular drain plug. It doesnt take much time out of your oil change.
  12. Oct 4, 2008 at 11:39 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    That makes sense. Thanks for the heads up!
  13. Oct 5, 2008 at 7:30 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Yeah, I wouldn't recommend one of these for off roaders, but for those of us that stay on the pavement they are pretty nice :D
    The one that fits our trucks is the F-103, or if you want the one with the nipple then you'll need the F-103-N.
    http://www.quickoildrainvalve.com/
  14. Oct 5, 2008 at 1:08 PM
    SilverMac
    SilverMac Mine's the silver one...
    Keller, TX
    2008 PreRunner DC SR5
    I've got the drain valve (don't really off-road, but it looks protected by a crossmember if I wanted to...?) and use Mobil-1. With the filter being located up high, the Tacoma is the easiest oil change I've ever done :D
    Invest in a quality filter, too. I used to always use Fram, but have heard some bad news about them lately. So far, only Mobil-1 filters on the Tacoma...
  15. Oct 7, 2008 at 8:52 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
  16. Oct 7, 2008 at 9:06 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Well.......I am going to start doing mine after Thursday. Since I am going to have the dealer do it. And I know they are going to give me hell about my ride. They seem to do that when I make changes.
    OK NOW fill me in, Mobil 1 oil, what grade??, and filter what type??
  17. Oct 7, 2008 at 9:39 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mobil1 5w30...and either oem filter or mobil1 m1-102 filter for the 4.0 v6. also,when you get a chance....swap the diff oils to mobil1 75w90....really good stuff.
  18. Oct 7, 2008 at 10:50 AM
    longbow
    Bill
    Indiana
    will do THANKS!!
  19. Oct 7, 2008 at 11:49 AM
    BULLETflight7
    BULLETflight7 Member
    Satsuma, AL
    06 PreRunner
    i run Royal Purple in eveything i own... truck, boat, lawn mower.
  20. Oct 7, 2008 at 2:06 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
