1st oil change: no washer on drain plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cavalry Taco, Sep 13, 2020.
  1. Sep 13, 2020 at 12:35 PM
    Cavalry Taco
    Cavalry Taco [OP] Member
    2019 Cavalry Blue Tacoma
    Just completed my first oil change and realized when I was draining the pan there was no washer on the drain plug. I’ve never let Toyota dealers mess with it so it had to come from the factory like this. Put one on the drain plug and anticipate no issues (no leaks from before either). Has anyone else seen this?
  2. Sep 13, 2020 at 12:36 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Are you sure that it isn't stuck to the pan? I've had this happen on my truck.
    Also, it didn't stick to the pan and THEN fall into the draining vessel?
    HP11, BillW, Chew and 7 others like this.
  3. Sep 13, 2020 at 12:40 PM
    Cavalry Taco
    I checked both, didn’t seem to be leaking either. Weird!
  4. Sep 13, 2020 at 12:50 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    its stuck on the pan #2
    e6400ultra, Chew, Junkhead and 3 others like this.
  5. Sep 13, 2020 at 12:54 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Ive seen oil pans with no gasket and no leaks. The problem is when there is no gasket, there is a risk of pulling threads of the oil pan.
    Junkhead, Taco_mike73 and somebody like this.
  6. Sep 13, 2020 at 1:31 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    It’s probably stuck to the pan like mine was. Use a PLASTIC trim tool Or scraper to knock it free. It almost fooled me into thinking it was a lip on the pan
    Chew, Junkhead, kahanabob and 3 others like this.
  7. Sep 13, 2020 at 1:37 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Beware of doubling up on the crush washer. Never heard a good thing about it.
    Chew and Junkhead like this.
  8. Sep 13, 2020 at 1:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have had them stuck before too, almost felt glued on and had to use plastic trim tools to get them off.
    Chew, kahanabob, VB25 and 2 others like this.
  9. Sep 13, 2020 at 1:53 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Same here. I thought the washer was stuck to the pan but NO. NO washer. 100%sure... I’ve done many many oil changes in my life.. basically all of them on all my previous cars.
    davidstacoma likes this.
  10. Sep 13, 2020 at 2:23 PM
    BillsSR5
    bill
    2014 SR5
    stuck on the pan #3
    Rockefelluh, Chew, kahanabob and 3 others like this.
  11. Sep 13, 2020 at 2:40 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Lots of stuck crush washers over the years..
    Had the o-ring off the screw on oil filter stick to the block of my F-150 once, too.
    Without noticing I just screwed the new can on. That's a mistake you'll notice quickly, at least on that truck.
    Blew so much oil so quickly it was spaying out the hood and rolling down the grille and quarter panel.
  12. Sep 13, 2020 at 6:23 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    That was a serious problem with the design in the Liberty CRD I used to have. It had a drain plug with hex key head and very few threads. Add an aluminum cast oil pan and you got easily torn threads. Fixing an oil pan isn't always cheap. That why I put an Fumoto valve on it.
    I think I may do the same with the Tacoma. It also makes changing the oil easier and a little bit cleaner as the oil drains straight down.
    The thing is I'm not sure what the dealership will say when I go to get my 2 oil changes from them.
    pop.tremuloides likes this.
  13. Sep 13, 2020 at 6:26 PM
    Tacomike18
    J
    I understand. I do many Honda oil changes with aluminum oil pans and I see so many damaged oil pans threads from over tightening. That’s why I’m glad Toyota used a steel oil pan but the threads are much shorter than the new Honda’s. I’m also thinking about using the fumoto valve but worried it might open up and leak everything out.
  14. Sep 13, 2020 at 6:41 PM
    Taco_mike73
    York, PA
    I had it on the Jeep over 10 years and no problem with it opening on its own. The valve actually has a lever that you need to pull first and then rotate it to open the valve. There is also a Plastik Clip they sell now that you can place over the lever, I think it may even be included now with new ones.
    I even went off road in the Jeep with it on. It was above the skid plate on the Jeep, as long as you get the short one it should be good. I would not get the one with the long nipple for a hose, I think it would hang down too low.
  15. Sep 13, 2020 at 7:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Funny story. I was helping my buddy change the oil on his neon. He removed the old filter and put the new one on, all good. Once he started the engine, the oil went all over the place! The old gasket was stuck to the engine. He installed the new filter without realizing it, it was great cleaning everything up.
    shakerhood likes this.
  16. Sep 13, 2020 at 8:08 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This
    It's stuck
  17. Sep 13, 2020 at 8:10 PM
    Bishop84
    Bishop84 Well-Known Member
    I've done thousands of first oil changes. This is extremely unlikely as it would have leaked.
    Chew likes this.
  18. Sep 13, 2020 at 8:49 PM
    Cavalry Taco
    100% sure there was never a washer. Plug was wrenched on pretty good (more than 30 ft lbs). Surprisingly never leaked. I left the skid plate off and drove around the neighborhood after the change and all seems good. I’ll keep an eye on it for future leaks.
  19. Sep 13, 2020 at 8:55 PM
    tinytim11B
    tinytim11B 2TRFE Gang
    Tim
    Northern CA Coast
    2016 BBP SR5 4x2 AC 2.7 AT
    Blacked out emblems, mudflaps, tint, nothing crazy.
    It mightve just been good to go without the washer. The factory probably forgot to install one. My wrangler doesnt use one. Manual doesnt call for it, and it doesnt leak. My tacomas fumoto valve came with a fiber gasket though.
  20. Nov 30, 2020 at 3:52 PM
    Claudiomartinof
    I have stated on this thread that my truck came without a washer.
    I was wrong. I just did my second oil change and I mistakenly put a washer over the first washer that came from factory.
    So the first washer was stuck and I thought it was part of the pan.
    last weekend I removed both and installed a new one.
    So for the ones that state that truck came without washer, double check.
