1st oil change on the truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EBBS03, Apr 8, 2010.
  1. Apr 8, 2010 at 11:39 AM
    EBBS03
    EBBS03 [OP] Well-Known Member
    Rob
    Philadelphia, PA / Morgantown, WV
    '10 Tacoma TRD 4X4 Off Road
    Stock
    So, the other day I just did my first oil change on the Tacoma (went synthetic, just makes it easier, cause the truck and mustang will need oil changed around the same time as each other, so I can instead buy two cases of oil between them). Everything went okay, but I'm looking for some tips for the next time.
    First issue... I take off the skid plate and get to the drain plug and remove it. However, it shoots straight down, and hits the oil pan thing with so much force it starts spraying everywhere! I have never seen oil shoot out of a car with so much force. I have a huge oil mark all over the ground of the garage, and a circle in the middle form where the tub sat, lol! My Mustang pours out to one side, so it kinda goes slow, and I've never had an issue like this. Even my mom's old 06 GTO went straight down, but not with that much force. So my question is, do you guys do anything special to prevent this?
    Next issue... I swear to god, Superman must work at Toyota, and his job is to put the filter oil filter on. I tried bare handing it, using an oil filter wrench, then using a rubber filter wrench, but each one just dented the shit out of the filter. Finally, I just jammed a screw driver through it, and got it off that way. The filter sits upside down at the top of the motor, so I figured most of the oil would have drained out. Nope. It just pooled in that little reservoir. Any way to prevent that, so I'm not sitting their soaking the oil up?
    Thanks
  2. Apr 8, 2010 at 11:42 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
  3. Apr 8, 2010 at 11:43 AM
    EBBS03
    Rob
    Stock
    Well damn. That would have been helpful. And I tried searching.... I guess I failed, lol
  4. Apr 8, 2010 at 11:51 AM
    EBBS03
    Rob
    Stock
    Nah, the plug is fine. I guess I'll just leave the plug in a little bit, and let the oil drain for a bit that way. I was just caught way off guard. Oil went EVERYWHERE, man. I was soo fuckin pissed.
  5. Apr 8, 2010 at 12:47 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    First filter was a PITA but the subsequent filters (that I installed correctl) haven't been a big deal.
    Oil does just flood out of these things - especially with the height of the 4x4. It tends to shoot down and splash up towards the drivers side for me so I just slide my pas that way. Seems to minize the mess on the floor.
  6. Apr 8, 2010 at 12:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmm? You shouldnt have had to take off your skid plate? Unless the 2010's are different then my 2006?:rolleyes:
  7. Apr 8, 2010 at 3:58 PM
    nhstang
    nhstang Well-Known Member
    Brian
    Nashua, NH
    2010 TRD Sport Double Cab
    Stainless Step Bars, Extang Trifecta Tonneau
    I always put a big piece of cardboard on the floor when I change oil. Won't stop a big spill but it sure saves the garage floor from all the small splashes.
  8. Apr 8, 2010 at 4:25 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I use a 2' scrap of black RV sewage hose and hold it under the pan when I first remove the drain plug. It's like a 4" diameter hose, works good but you have to hold it in place until it slows then just rest it in place.
    The first time I changed mine the oil hit the bottom of my catch bucket and sprayed out the side... messy.
    And the tube off the reservoir for the filter is the only way to go
  9. Apr 8, 2010 at 8:22 PM
    EBBS03
    Rob
    Stock
    Nah, there's a cut out, but I didn't feel like raising the truck up at all, so by removing the skid plate I had a little extra room. Plus, I wanted to make sure that I was removing the right drain plug, lol.
  10. Apr 8, 2010 at 8:33 PM
    JayJay
    JayJay Well-Known Member
    Pacific Northwest
    08'Taco.DC,SR5.TRD. Off Road,Manual 6Spd.
    3 inch lift Rev Tek Bilstien shocks .Westin crome side nerf bars (steps) Toyo 285-16" , HID High/Low 4300k ,yellow fogs 3000k, Lear cap 100 XQ , Thule Tracker 2 roof rack , Bed Rug bed liner ....
    Sounds to fun everyone ,Changing the oil that is ....... I just got to the point after years of changing oil on all my cars , that now i just rather pay $49.00 and get full syn. and get the car washed and vacumed while I surf the net or have a cup of coffee .... worth all of the fifty bucks ..... and everything gets topped off and checked for other stuff as well ...this only takes 30-45 min . PRESTO CHANGE-O .... ENJOY THE RIDE MY FRIENDS !!!!!!!!!!
  11. Apr 8, 2010 at 9:47 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You guys make this to hard. I just losen it with the socket, then use my hand to take the rest of the bolt out (using the socket and extention to get through the skid) while using my other hand to hold up the oil catch. After the initial burst it doesn't slosh up a lot when you set it down. Works for me...
    The side... sucks with this height. My ranger had a side drain... first time I did it I overshot the oil catch, pushed it over. Then turned around laughing, looked back, and it was missing the pan again because I pushed it to far....
    I prefer straight down :D
  12. Apr 8, 2010 at 9:51 PM
    ryanf
    ryanf Well-Known Member
    NY
    06 AC 4X4 6cly/6spd TRD-OR
    Rain Visors,
    plus let it fill that little resivoie under the filter, there is a plug underneath it to catch what dripped out
  13. Apr 8, 2010 at 9:55 PM
    comatosed
    comatosed Well-Known Member
    Central Florida
    Silver TRD Sport
    TRD roof rack, Roof Basket, Weather Tech liners, Wet Okole seat covers, bed mat, AFE Pro Dry Filter, Eclipse AVN726E dvd/nav, kicker door speakers, 8" kicker sub & amp, fox 2.0 coil overs, moab 2.0 front bumper, Full CBI Skid Set, CBI Offroad rear Bumper, CBI Sliders, BFG AT KO 2, Leer Topper setup for camping. Other mods-full synthetic, carbon filter, de-badged, center console lock.
    Put one of those long flex funnels up to it, or rig it up. Or you could get a drain pain that extends.
  14. Apr 9, 2010 at 5:54 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
  15. Apr 9, 2010 at 8:13 PM
    JayJay
    Pacific Northwest
    I go to the dealer only and this is covered if it fails .... $49.00 and everything is checked under the hood and below ..... never Jiffy lube , and when I said (Presto change -o ), that was just me talking out loud... not a oil change shop ... LOL !!! If u add up all the cost of 5 qrts of oil and a filter and the mess and getting rid of the oil ............. NOT ME !!!!! but u enjoy the mess , go for it .....
