1st Oil Change Poll
Discussion in 'Performance and Tuning' started by spaghettiedy, Oct 7, 2008.
1st Oil change
  1. 500 - Dyno
    3.9%
  2. 500 - Synthetic
    3.7%
  3. 1k - Dyno
    4.9%
  4. 1k - Synthetic
    7.6%
  5. 2k - Dyno
    2.2%
  6. 2k - Synthetic
    6.2%
  7. 3k - Dyno
    12.3%
  8. 3k - Synthetic
    16.8%
  9. 5k - Dyno
    13.2%
  10. 5k - Synthetic
    29.1%
  1. Mar 28, 2010 at 9:10 AM
    #81
    tacomamodboy
    tacomamodboy Member
    annapolis md
    09 trd off road
    Tube steps
    thats what the oil filter is for
  2. Jan 16, 2011 at 6:29 AM
    #82
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I drained my factory oil on day 1. Then again at 500 miles. Both changes done with Mobil 1. All changes have been done with Mobil 1.
    Oh, and if there are any folks about to tell me the myth that there is some sort of better break-in with factory or dino oil, I have over 220k miles now, and my engine is like new, burns no oil, and keeps the oil very clean between drains.
    Mobil 1 EP 5W-30
  3. Jan 28, 2011 at 4:07 PM
    #83
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    soo for motorcycles, i ran my first few hundred miles hard... not red lining it every time.. but higher than what the manual says (keep below 6 rpm)... in doin soo the compression, the o rings and what not settle much better than if u just run it by factory regulations....my question is, does this same 'rule' apply to a new car?? im about 1k miles into my new truck and would like some insight... i am planning on getting the oil changed to synthetic at 3k miles... then again at 5k miles.. then every 5k afterwards... all synthetic..
    -ant
  4. Feb 21, 2014 at 10:33 AM
    #84
    golferdawg17
    golferdawg17 4 banger DC Taco
    DAWG in War Eagle country
    '13 2WD Double Cab I4 AT PreRunner SR5
    WeatherTech DigiFit Mats, Dee Zee Bed Mat, Clazzio Custom Leather seat covers (gray outer/black insert) ordered from Tyler at Clazzio (DO NOT ORDER FROM clazzioseatcovers.com)
    Mine is a 4 banger and comes with synthetic. First oil change according to toyota is not due until 10K miles.
  5. Mar 6, 2014 at 5:10 PM
    #85
    Jffrobo
    Jffrobo New Member
    Jeff
    Virginia Beach
    13 lb 4x4 sport
    At 6 months and 3100 miles I stuck with dyno. I have always heard to break in with dyno.I will probably switch to syn next time.
  6. Mar 7, 2014 at 6:07 PM
    #86
    TacoFlavouredKiss
    TacoFlavouredKiss Well-Known Member
    Kevin
    O CANADA
    Dumped at 5000K w/ synthetic
  7. Mar 7, 2014 at 6:28 PM
    #87
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
    Not sure if anyone has looked or mentioned it, but at my Wal-mart here in north Tx i get 5qt jug of mobil 1 for $25. Was $23 but went up recently. It and a purolator filter for $30 bucks. Way more expensive at most auto parts stores.
  8. Mar 10, 2014 at 9:21 AM
    #88
    DirtyTaco24
    DirtyTaco24 Well-Known Member
    Greg
    Ottawa
    '12 TRD DCLB Black
    I use Dyno in my 2012 4.0 V6. The manual says change every 8000 km's (5k miles) using 5W 30 conventional oil. That's what I'll continue doing for the life of the truck. I hope it doesn't blow up :eek:
    I can understand switching to syn if you're constantly towing, driving in harsh conditions etc. If you use the truck for your daily driver with the odd tow here and there, why waste money? Just my 2
