1st Oil Change - Yellow Milky Substance in Oil Fill Tube ?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZanexGt, Dec 25, 2010.
  1. Dec 25, 2010 at 10:02 AM
    ZanexGt
    ZanexGt [OP] Well-Known Member
    Fairfax, VA
    2010 DC SR5 4x4
    Hey all,
    I bought my 2010 Tacoma in October and just passed the 1,000 mile mark (1,098 to be exact) and decided to do my first oil change now instead of wait for the 5,000 mile mark. I do this with all my new vehicles and then change at the recommended intervals thereafter.
    Well, bad news. Check out these photos. It looks as though there is water in my oil!
    Also, take a look at the murky yellow haze on my coolant overflow tank.
    So what do you guys think? Sounds like a bad head gasket to me. Any advice or comments are welcome and appreciated.
    Thanks,
    -Robert
  2. Dec 25, 2010 at 10:06 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yep,looks like condensation has built up from somewhere.i have seen this before on the oil cap but no were near that bad.i would be headed to the dealer asap.
  3. Dec 25, 2010 at 10:11 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    dealer asap
  4. Dec 25, 2010 at 10:20 AM
    ZanexGt
    Fairfax, VA
    2010 DC SR5 4x4
    Was just reading the following link, looks like I'm not the only one with this issue.
    http://www.tacomaworld.com/forum/2n...s-milky-condensation-oil-cap-filler-neck.html
    Some folks in that thread indicate that this is normal behavior for the Tacoma 4.0 engine as the Oil Fill tube is made of plastic and very long. Apparently, these two factors keep the oil up in the tube (and on the bottom of the cap) from heating up enough to burn off condensation.
    However, if that were the case, wouldn't everyone's Tacoma have this sludgy milky oil in the filler tube and cap!?
    Of note, I bought the truck on 10/21/10 with 59 miles. I only have 1098 miles on the truck now. I drive it almost daily but my commute is only 3 miles long, each way. Therefore the truck does not have time to warm up to normal operating temps.
    If this is normal, then I can deal with it.
    However, if this is a blown head gasket or some other issue allowing water to get into my oil system, I need to address it ASAP!
    Thanks for the comments guys, I appreciate it.
    Merry Christmas,
    -Robert
  5. Dec 25, 2010 at 10:21 AM
    ZanexGt
    Fairfax, VA
    2010 DC SR5 4x4
    That makes sense. However, what about the yellow haze on the inside surface of my coolant overflow tank? That doesn't seem right to me.
    The coolant appears pink when the lid is opened.
  6. Dec 25, 2010 at 10:27 AM
    ZanexGt
    Fairfax, VA
    2010 DC SR5 4x4
    True, commutes vary. However, in this post, the poster states he regularly drives 300 miles round trip and his engine exhibits the same symptoms.
    But, with only one post, the sample size is small.
  7. Dec 25, 2010 at 10:33 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The milky or creamy deposit itself is fairly common in the oil cap area but the yellow color would be bothersome to me...what's the oil itself look like?
    If you've had it almost three months and only put 1000 miles on it you obviously aren't driving it much. Drive it on freeway a while to get the oil temp up and cook off any moisture in it.
    After you get it good and hot the coolant level should also rise a little as the coolant in the engine expands and overflows. If it's not up to the 'full warm' mark then add some.
  8. Dec 25, 2010 at 11:11 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    It is you-re truck. Listening to this good, or stupid (however with good intentions) suggestions, ultimately is you-re truck. The outcome is up to you.
    If you want one more stupid sugestion, take it to the dealer. This way will be documented, they may do a pressure test, and give you an educated reason for it.
    Have a merry Christmas.
    take care
    vbibi:(
  9. Dec 25, 2010 at 11:18 AM
    ZanexGt
    Fairfax, VA
    2010 DC SR5 4x4
    The oil itself appeared to be normal as it was draining. Also, I did not notice the yellow milky substance in the drain pan.
  10. Dec 25, 2010 at 12:15 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  11. Dec 25, 2010 at 2:43 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    It looks normal to me.
    I too was worried about it after my first oil change, then I did a search and found that all kinds of people experience the same thing, especially those that have a short commute.
    It can't hurt to ask the dealer, but I wouldn't let it ruin your christmas!
    Shawn.
  12. Dec 25, 2010 at 2:57 PM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    It might be a factory break-in additive, for a new engine??.
    Just a guess since some folks with new trucks are seeing the similar stuff, and it doesent seem to be affecting anything.
    Condensation foam is normal on the cap,,but that stuff looks almost purposfull since it is so obvious.
    Wouldnt hurt to get a dealer opinion, and then another.
  13. Dec 25, 2010 at 2:59 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    I would go see the dealer.
  14. Dec 25, 2010 at 3:12 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    That condensation is normal for our trucks due to the plastic filler neck...nothing to worry about. Like mentioned it mostly happens from short trips. If you saw it on the dip stick or in the drain pan when changing the oil it would be a concern.
  15. Dec 25, 2010 at 8:02 PM
    2010tacoTRDOR6spd
    2010tacoTRDOR6spd Active Member
    Dave
    RI
    2010 Tacoma Access TRD-Off Road 4.0L 6spd
    My truck just reached the 1500 mile mark (2010 4.0L 6pd) so I decided to change the oil as I have a ski trip coming up and I figured why not. My plans are after this change to move to synthetic, but I read it shouldnt be done this early as the rings haven't properly sealed at this point.
    However, I too noticed this yellow substance build-up on the inside of the oil refill cap, but no where else. I originally attributed it to initial engine bs, but it seems as though it is quite normal for our engine.
    I will keep everyone posted once I do my second change to see if the problem comes up again.
    -DS
  16. Dec 26, 2010 at 6:57 AM
    Mod
    CR, WA
    stock
    If assembled and set up properly,your rings seal within the first 2-5 min of initial run time. the crosshatch pattern on the cylinder walls almost instantly lap the rings in. The initial run time is done on a assembly line engine stand or station.
  17. Dec 26, 2010 at 9:24 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    ^too bad subarus almost never break:D
  18. Dec 28, 2010 at 9:14 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    i have been thru 6-7 subys, still have one and my g/f drives a legacy, only reason i got a taco was because of the towing
  19. Dec 28, 2010 at 1:39 PM
    TampaDude
    TampaDude Well-Known Member
    Riverview, FL
    '06 Silver 5-Lug Access Cab
    Heh...reminds me of the time I went to Bowling Green, KY to the Corvette plant. The very first thing they do with each new Vette as it comes off the assembly line is roll it onto a dyno and run the sucker at full throttle to verify the engine's power output. :D
  20. Dec 28, 2010 at 2:21 PM
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    It appears that you, good sir, have a head gasket issue.... Dealer ASAP!!
