1st oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dsixnero, Apr 4, 2017.
  1. Apr 4, 2017 at 4:00 AM
    dsixnero
    dsixnero [OP] Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    Im at 7100 miles but my truck was delivered to a different dealer 5 months before and now the oil is a year old. So I'm screwing up the whole Toyotacare plan but the service adv. and I made a new plan. They just did the oil and control arm plugs @7k At 10k, the tires and check a cold trans for fluid level. Then at 15k will be tires and oil and at 20k just tires and then I'm on my own.
  2. Apr 4, 2017 at 5:01 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Cool!
    GPsevinSixx and HutchJ like this.
  3. Apr 4, 2017 at 5:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ok.
    But I'd have had the trans done now.
    If it's low, you want it fixed sooner, not later. Why would you risk another 3k with a low level?
  4. Apr 4, 2017 at 11:16 AM
    NitroExpress
    NitroExpress Active Member
    Texas
    '17 TRD PRO
    I don't think you are really screwing anything up. You basically get two oil changes with Toyota Care on a Tacoma. I don't think they care when you do them. I just couldn't make myself go 10k miles on the first oil, So I went in at 5k and the dealer asked if I wanted this as part of my Toyota care or if I wanted to pay.
    Rambo54 and Storman like this.
  5. Apr 4, 2017 at 11:19 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Its based off of time or miles. Just yesterday I took our Rav4 in for the 24 month/20k service, she only had 12, 000 miles on it. There is a reason its based on either one, you didnt screw anything up.
    shakerhood, Rambo54 and Storman like this.
  6. Apr 4, 2017 at 11:41 AM
    CusterFan
    Had any problems with the RAV4? Still deciding between the Mazda CX-5 or the RAV4 when the warranty on this truck runs out in NOV 2018. Or I may keep this truck and have the shiny black paint Line-X'ed. Think it will be about the same money either way I go.
  7. Apr 4, 2017 at 11:47 AM
    daddy_o
    Bossier City, La
    No real issues. Wife uses it to run son to karate classes, go to the gym, and we have made a trip from shreveport to Dallas and back, and several trips back and forth 1 hour each way taking our daughter to college
    (parking is terrible on campus so she has a bike there but when she needs to come home we have to get her). The one minor problem we had was the seat trim on the bottom driver seat broke, but they ordered a new part and are replacing that under warranty. She got the Hot Lava and it seems like the paint is fairly thin, a few rock chips, but I got a touch up pen from the dealer for that.
    CusterFan[QUOTED] likes this.
  8. Apr 4, 2017 at 12:39 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Lower Control Arms have holes in them, under side. Crawl under the front of your truck and look at the LCA you will see the small holes. When driving on windy days sometimes between 35 to 45mph it will cause a howling noise that sounds like someone blowing over the top of an empty bottle. Toyota finally released a TSB to fix this and the fix is to plug the holes with small plastic plugs. You can buy the same thing essentially at most hardware stores
    https://www.tacomaworld.com/threads/solved-howling-noise-between-35-45.410480/
  9. Apr 4, 2017 at 12:44 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    That is the minimum required maintenance, you can always do the maintenance sooner or more often based on use.
    During winter I drive lots of short trips and change my oil after 4 months only 2000-3000 miles.
    I'm sure the 3.5 runs a lot cleaner than the 4.0, but do maintenance based on use not miles.
    All fluid levels should be ck asap.
  10. Apr 4, 2017 at 12:45 PM
    Taco16LB
    Taco16LB Well-Known Member
    Remember that some vehicles are made and sit on the lot for a year or more , I highly doubt the oil is changed when it is a year since the build date. I would really be shocked if a dealer said this truck or car is 9 months old and you must change the oil in 3 months etc. !
    Storman, smitty99 and Rambo54 like this.
  11. Apr 4, 2017 at 1:40 PM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Changed mine at 1000, will change again everytime it hits the 5k mark.....5k, 10k, 15k, 20k ,etc....it was just 2 years ago that the "toyota engineers" said change it at 5k OCIs for the 2TR-FE 4 cylinder...., 2 years later, they deemed its good for 10k oci's now that we have "Toyota care free maintenance ":jerkoff:
    ....not my truck, its 5k or sooner...."toyota care":jerkoff: won't be seeing my truck unless its for warranty work.
    Amsoil Signature Series 0W20
    Toyota OEM filter
    shakerhood and Broheim like this.
  12. Apr 7, 2017 at 8:32 PM
    2017TACOPRO
    2017TACOPRO Well-Known Member
    Billy
    Delaware
    White 2017 Tacoma TRD PRO TACO
    TRD exterior cab badges, 3D TACOMA tailgate emblems, Weather Tech trailer hitch step / bumper guard.
    First oil change at 3,700 miles
    Requested:
    Oil change
    Tire rotation
    Transmission fluid level check
    Zerk's checked for grease - (service guy said "I don't think those trucks have them"
    Lower control arms TSB fix by placing plastic caps in holes to stop "whistle sound"
    Service:
    changed oil (I hope)
    Rotated tires (confirmed)
    Told me the trans fluid was fine?
    Said all the zerks had grease?
    Did not fix the TSB, not mentioned on service invoice WTF!
