1st oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwr80, Oct 20, 2009.
  1. Oct 20, 2009 at 8:01 PM
    dwr80
    dwr80 [OP] Well-Known Member
    09 double cab... what oil would you recommend for my first change?
    synthetic or conventional?
    Thanks
  2. Oct 20, 2009 at 8:07 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    Iv heard that synthetic is the way to go but not too sure
  3. Oct 20, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Personally, I run Mobil 1 with good results.
  4. Oct 20, 2009 at 10:19 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    The man speaks wisdom, I would listen if I were you :) :p
    I love Mobil 1 it's the only thing I will ever use in my vehicles.
  5. Oct 20, 2009 at 11:22 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Question - why the oversized vs regular filters.
  6. Oct 21, 2009 at 2:40 AM
    DHSDave
    DHSDave Member
    CA
    Tacoma TRD
    Stocker
    I see no reason to go with the the high $$ synthetics. If regular dino oil was good enough for Toyota, that's what I'll continue to use. Were not talking about some high end performance motor here. My Viper came with Mobil1 from the factory which it was designed for, so I don't mind spending the extra $$$.
    If you plan on racing your truck well then maybe I would consider it. Just make sure you change on a regular basis and use a decent oil filter. You can also get a free oil sample test kit from Blackstone Labs who will test your used oil for a small fee. You get a pretty good detailed report.
    Regards,
    Dave
    09 Tacoma TRD
  7. Oct 21, 2009 at 8:34 AM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    I plan on having my truck til he wheels fall off..I only use good stuff..you pay for what you get..
    What's wrong with the mobil 1 filter?
  8. Oct 21, 2009 at 8:47 AM
    Masada
    Taylor
    Laveen, AZ
    Use the factory filter if you can. They are about the same if not cheaper.
    Mobil 1 maybe a couple bucks more, but why not spend the extra coin to keep your engine in tip top performance? Remember the factory fills these things with the cheapest stuff they can find to reduce cost of manufacturing. Just because it didn't come from the factory with synthetic doesn't mean it's not built for it. That's like saying because your burger didn't come with ketchup on it's not supposed to have it on there.
