1st start after disconnecting the battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike06toyota, Apr 22, 2015.
  1. Apr 22, 2015 at 8:54 PM
    Mike06toyota
    Mike06toyota [OP] Well-Known Member
    Santa Clarita
    06 PreRunner TRD Sport
    K&N Intake Flow Master
    The 1st start of my truck always dies after I disconnect my battery... After that the second time I start up everything is fine. Why is this and does this happened to any other 2nd gens?
  2. Apr 23, 2015 at 2:31 AM
    holeshot1982
    holeshot1982 Active Member
    North Augusta, SC
    12 PreRunner Sport DC
    Yep, happens to me on my '12. No issues after that first time though.
  3. Apr 23, 2015 at 2:42 AM
    Tacoma Mike
    Southern Maine
    Normal....
    Ecu's are cleared of short term learning.
  4. Apr 23, 2015 at 6:31 AM
    Mike06toyota
    Santa Clarita
    If the ECU is being cleared of memory and the truck dies is that because the truck is no longer preforming to OEM standards? after the 1st fail is it spiting more air or gas to get the truck ruining?
  5. Apr 23, 2015 at 6:33 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No its just part of clearing after first start. The truck isn't starting out of spec or anything.
  6. Apr 23, 2015 at 10:20 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I had a GM ECM "learning system" on a past chebbie outfit - and it would "re-adjust" based on the worst tank of gas (low octane). So it would slowly de-tune itself down and down trying to accommodate junk gas. But it wasn't smart enough to power itself back up when the ghetto gas was done and something better was available. Finally took to running a bottle of Techron through it every month or so - and disconnecting the battery to make it re-start the learning process.
    I suppose the programming wizards at Taco central did that sort of number on these outfits as well......... does anyone "re-set" their trucks for a similar reason and get good results?
  7. Apr 23, 2015 at 10:22 AM
    tonyt915
    tonyt915 Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    Mine does the same thing
