1st taco & lookin for advice on lifts/wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hot Chillae, Dec 24, 2011.
  1. Dec 24, 2011 at 9:26 PM
    Hot Chillae
    Hot Chillae [OP] Member
    Garrett
    Springfield
    03 PreRunner 4Cyl 2.7 Stepside :)
    pending.. Suggestions?
    Hey guys, Let me just say i am so proud to finally own a Tacoma! I have done quite a bit of research, but i feel i still have some un answered questions.
    My platform is an 03 PreRunner with the 2.7L 4Cyl. also its a step side in case that matters.
    these are my planned mods as soon as Christmas is over: ToyTec coilover kit with the Bilstein 5100 and Eibach springs, 2" ToyTec Shackles, and possibly Rancho RS5000 shocks for the rear. For wheels i want to do just the basic black steel pro comp series 52.
    My main questions are:
    Is there anything wrong/missing in this mod list for it to be complete?
    What size Wheels would be best? 15X8 3.75" backspacing?
    and is it possible to put say 32X10 tires on above mentioned wheels?
    Sorry to bombard you with so many questions, im just really new to understanding some things and would really appreciate any answers yall can give me! Once again so happy to be a Tacoma PreRunner owner!!!!
  2. Dec 24, 2011 at 10:33 PM
    brianpdx
    brianpdx Well-Known Member
    1999 SR5 TRD 4x4
    Congrats on your Tacoma. I'm curious about your lift choice for the rear, though. Why the Ranchos? Why wouldn't you go with extended length 5100's in the rear, or even 5125's? Personally, and this is just my opinion, I would recommend an add-a-leaf in the rear, combined with the aforementioned Bilstein shocks. If cost isn't a factor, then consider an entirely new leaf pack, such as Dakars.
  3. Dec 25, 2011 at 12:04 AM
    Hot Chillae
    Garrett
    Springfield
    well according to a guide i found on here, shackles are the best choice because they allow for more travel than AALs and cost is sort of an issue. heres what im referring to http://www.customtacos.com/tech/index.php?article=137
    as for the rear shocks, I'm not sure why im going with rancho... MAINLY because im on a poor man's budget. know of a good site to get Bilsteins in the rear?
  4. Dec 25, 2011 at 12:44 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    Right on toytecs website or you can go with dsms they'll hook you up and are very knowledgable any questions you have they'll be down to answer you
    Just realized your new to this place in case youre wondering dsms is down south motor sports
  5. Dec 25, 2011 at 2:10 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  6. Dec 25, 2011 at 12:51 PM
    Hot Chillae
    Garrett
    Springfield
    yeah i have read those and they where very helpful:D. but can anyone answer my question about wheels and tires? if i got 15"x8" can i put 10" wide tires on them?
    Also are LR UCAs required for this setup?
  7. Dec 26, 2011 at 9:31 AM
    4Wheelin4Banger
    Randy
    You might want to go wider on the tires. Mine came stock with 9 1/2" tires (245/75/16) on 7" wheels and my off road tires will be (265/75/16) 10 1/2" on 7 1/2" wheels.
    UCAs might be needed. I lifted 3" front & back and am running stock UCAs with no problem.
  8. Dec 26, 2011 at 10:01 AM
    Hot Chillae
    Garrett
    Springfield
    Thanks Randy that helps alot. ive been debating on wheather or not i even need new wheels but if you can fit 10.5" on the stock rims.. my wheels are the stock 16's so would i need to buy wheel spacers in order fit the wider tires?
  9. Dec 26, 2011 at 11:13 AM
    4Wheelin4Banger
    Randy
    It came with 16"? I thought the 1st gens were 15". 10 1/2" is the stock size on the 2nd gen 7 1/2" wheel. Not sure on the wheel spacers for your 1st gen, I know I wont need them on my 2nd gen.
  10. Dec 26, 2011 at 4:10 PM
    Hot Chillae
    Garrett
    Springfield
    [​IMG]these are my stock wheels and they are 16"s does anyone know if i will HAVE to replace them in order to fit 33 with my 3" suspension lift???
  11. Dec 26, 2011 at 6:49 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    you won't have to replace the wheels. if anything, you might have to add spacers depending on clearance plus it'll give you a wider aggressive stance.
  12. Dec 26, 2011 at 6:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    i believe those are 15's? i have them on my truck and they are 15s
  13. Dec 26, 2011 at 8:53 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    They (Toyota) also made those wheels in 16's
  14. Dec 26, 2011 at 9:03 PM
    2000GTacoma
    Snow Hill NC
    really? didnt know that. sorry op i learned something
  15. Dec 26, 2011 at 9:04 PM
    cnhunnell5
    cnhunnell5 New Member
    id go with chrome halo rims and a skyjacker lift
  16. Dec 27, 2011 at 9:19 AM
    Hot Chillae
    Garrett
    Springfield
    well i think ill have to be putting off bigger wheels and tires for now. thanks for all the info tho guys! i really appreciate it!
    does anyone know if i will need any special tools for the suspension lift install? such as a tool that compresses the coil-over for assembly? or can i just adjust the shock height all the way up, put on the top plate, then install it fully extended?
