1st Taco
Discussion in 'New Members' started by Dutch, Feb 6, 2008.
  1. Feb 6, 2008 at 3:30 PM
    Dutch
    Dutch [OP] Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    Been reading this site for a while. Thanks to all for great info. Posting pics soon of first Taco
  2. Feb 6, 2008 at 5:07 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Hey Dutch, welcome to TW, looks like you have a nice truck.
  3. Feb 11, 2008 at 4:09 PM
    Dutch
    Wilmington, NC
    07 4x4 Taco
    Thanks Jedi, Just finished rebore and customizing engine. A lot of dough for 23 more HP. Working on suspension now. Need better traction for tight turns in thick sand. Will post with what I come up with. Posting new pics this week.
  4. Feb 12, 2008 at 5:14 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Welcome to TW!
    You rebored the 4.0L? I didn't think the current tolerances allowed for that! I am really interested in seeing what all you have done to your truck.
    Don't forget you can upload pictures to your gallery in the member's gallery section.
    Cheers!
  5. Feb 12, 2008 at 5:52 AM
    Dutch
    Wilmington, NC
    07 4x4 Taco
    True 007........The wall thickness between the cylinders is quite narrow....however, after the bore and a good honing, inserts and rings were made from Astrolloy 4800. (Extreme wear resistant). More honing. New dome-shaped light weight pistons were machined along with cams. Nice to have a friend that builds race cars. Indexing for the bore was the hardest part. Will have pics up by the end of this week.
  6. Feb 12, 2008 at 6:55 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    How many thousand's did you bore, and whats the compression now?
    Sounds like a hot setup.
    Welcome to TW
  7. Feb 12, 2008 at 10:03 AM
    Dutch
    Wilmington, NC
    07 4x4 Taco
    Final Bore in sleeve (3.807), Comp Ratio......11.3:1 using new domed high compression pistons, modified deck clearance, new head gasket. Runs very nice as is, but will remount supercharger this weekend. New tuning next week. May need other mods (cooling), but have to move on to suspension. Should have pics up in a couple of days.
  8. Feb 12, 2008 at 11:43 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Welcome to the site man! Your boosting an 11.3:1 motor?
  9. Feb 12, 2008 at 1:03 PM
    Dutch
    Wilmington, NC
    07 4x4 Taco
    Thanks 06 BSP. Yes.......we stepped back a little with the TRD S/C. It normally runs about 5 PSI. Took the pulley off of a Whipple S/C from my Ranger (slightly larger diameter).....new center hub and belt......and put it on TRD S/C. Boost should drop sufficiently to avoid detonation. Can't go any larger as the belt path is already tight. Will re-mount S/C this weekend and let you know.
  10. Feb 12, 2008 at 2:01 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    It sounds like it's going to be a fun ride.
    :burnrubber:
  11. Feb 15, 2008 at 4:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    welcome....ya need to get that thing over for the carolina meet and do 120 down the trails!!
