1st Tacoma 2013, Lots of questions
Discussion in 'New Members' started by Charlie Maxwell, Sep 20, 2013.
  1. Sep 20, 2013 at 1:54 PM
    Charlie Maxwell
    Charlie Maxwell [OP] New Member
    Adam
    Columbus, OH
    Tacoma 4WD 2.7
    OEM fog lights, ARE x series cap, Keyless start
    Hi All,
    So I have a 2013 Tacoma, reg cab, 2.7, 4wd. I down sized from a Silverado 1500 LTZ. So Im used to all the options and this Tacoma has or had none. So far Ive added a new switch for intermittent wipers because yeah it was that base, a Toyota fog light kit from ebay, an ARE z-series cap, a bed rug bed mat, and a remote start. Future plans are an OME 3 in lift that is on order from toytech, UCA's from fat bobs also on order, I really like the power converter in the bed on the nicer models and have been thinking about researching that. Also gonna add probably trd rims and tires after the lift. I'm a big fan of making everything look like it is meant to be there so I stick towards quality parts and do the work myself because I'm super anal. I have a few questions about the lift mostly about the diff drop and shims for the leaf packs (I went with the leaf packs not the aal or block). I'm about to ask that question in another forum and forgive me if its the wrong one, this is the first forum I've joined, I usually just google and snipe info from them as I had from this one but finally joined last night. I live in Columbus OH. Since adding the cap my weak ass stock leaf springs clink on every decent size bump and as I said before I'm completely anal and will not stand for that. This is my first small truck and I'm a big fan of it but just want to do everything right the first time and not chase shimmies and shakes so look for my post in the appropriate forum if I can figure it out. From what Ive seen a lot of you guys have some pretty sweet rigs and are way into them and I would like some quality input.
  2. Sep 20, 2013 at 6:55 PM
    270wsm
    270wsm Well-Known Member
    AZ
    Hello adam welcome to TW
  3. Sep 20, 2013 at 6:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
