1st time oil change question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnnyrecon, May 8, 2023.
  1. May 8, 2023 at 8:13 AM
    Johnnyrecon
    Johnnyrecon [OP] New Member
    Johnny
    2009 4x4 TRD
    Did my first oil change past weekend. Truck on ramps, oil filler cap removed, oil hot. When I took the drain plug out, the oil shot out as if under pressure creating a huge mess as the oil's drain velocity shot it out of the drain pan like water out of a hose. Having done many many oil changes I have not ever had oil come out like this. 2009 4.0L. I have now installed a fumoto drain plug so I would hope not to have this issue again.
    Lexi0216 and szidls like this.
  2. May 8, 2023 at 8:53 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    So what exactly is your question? Or is this more of a statement?
    -J
    Rick's 2012 likes this.
  3. May 8, 2023 at 9:02 AM
    TacoDinner
    TacoDinner Well-Known Member
    You can also attach a flexible tube to the fumoto valve to better direct the oil
    usmc2msu and Bagman like this.
  4. May 8, 2023 at 9:03 AM
    Johnnyrecon
    Johnny
    2009 4x4 TRD
    is the pressure normal? sorry I was not more specific
  5. May 8, 2023 at 9:06 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Only if you get the -N part with the nipple. My fumoto doesn't have the nipple.
    Yeah, that's kinda normal. Maybe you just got unlucky with how the oil came out, kinda like a spoon in the sink where the water hits it just right to splash out. It's done that to me in the past, I'd say your good.
    -J
  6. May 8, 2023 at 9:08 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    I have done all of the oil changes -- 22 so far -- on our 2005 Tacoma with a V6. Never had oil shoot out as if pressurized.
    jproffer likes this.
  7. May 8, 2023 at 10:27 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Did you remove the oil cap 1st. If the oil were warm enough it could have been slightly pressurized at 1st.
  8. May 8, 2023 at 11:08 AM
    XSplicer62
    Jefferson State
    That's something I didn't think of and it might have affected the OP.
    In my case though, I never remove the oil cap until I'm ready to add oil.
  9. May 8, 2023 at 11:45 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've done 32 oil changes on my 07 and never had it shoot out like it's under pressure. Never seemed to make a difference if the filler cap or filter were removed beforehand. You say you had it on ramps and oil was hot... was the truck level and was the plug removed immediately after turning off engine or did you wait a minute or two?
  10. May 8, 2023 at 11:49 AM
    Import Driver
    Import Driver Active Member
    Jesse
    NE Iowa
    2008 TRD Sport
    Since I didn't see it I can't say if it was normal or not. But I don't feel like I've ever pulled a drain plug and had the oil push out pressurized. Fast but not pressurized.
    I remove filler caps when draining oil. But I usually do it after I pull the drain plug for some reason. Why do I do it? Same reason I pop the vent open on the gas can.
  11. May 8, 2023 at 11:52 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s why I do it cold and let it drain for hours or overnight if I want. If I’m that worried about it I’ll change the filter again in a couple of weeks or not.
    HondaGM likes this.
  12. May 8, 2023 at 12:42 PM
    Marshall R
    Marshall
    none
    I was taught to always remove the filler cap 1st. This lets air in at the top and helps push more of the oil out faster. But if the engine is hot I'd think it would be slightly pressurized and result in a sudden gush of oil. But with the cap in place the overall flow of oil out will be slower. At least in theory. How much it matters in the real world may be negligible.
    jeminyned likes this.
  13. May 8, 2023 at 1:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Hot oil flows WAAAAAY better than ambient temp... this is normal.
    HondaGM and Mods2Travel like this.
  14. May 8, 2023 at 1:35 PM
    Johnnyrecon
    Johnny
    2009 4x4 TRD
    cap removed before changing. I know the back pressure if cap is on will reduce flow, maybe that was the reason?
  15. May 8, 2023 at 2:52 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    You might want to check your PCV valve.......ANY crankcase pressure, unless vented, is a recipe for oil leaks (gaskets).
    HondaGM and TnShooter like this.
  16. May 8, 2023 at 3:22 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve seen it happen if you don’t remove the fill cap. There could be a little pressure, then it’ll sorta glop glop glop out.
  17. May 8, 2023 at 3:29 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    This is why I always lay out about 25 square feet of cardboard and have lots of carb cleaner on hand for splatter whenever I change mine. While I wouldn't quite call it pressurized, in the past 5 years I think only one oil change wasn't a mess, and I always pop the dip stick and pull the fill cap. No matter how I try to catch the oil, it always jumps out of the pan to some extent. That's why I've given up and focus on damage control. I would consider your situation normal.
    MSgt O likes this.
  18. May 8, 2023 at 3:48 PM
    TacoTuesday1
    SD CA
    Remove the filter first.
  19. May 8, 2023 at 4:01 PM
    XSplicer62
    Jefferson State
    I won't say I never spill a drop -- how about almost never? My drain pan has a nice big 16" opening that's easy to hit, and a spout so it's easy to pour into recycle jugs.
  20. May 8, 2023 at 4:08 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    OP, if hot, 100% normal, has happened to me at least three times. Either change cold or buy an oil catch container that is deep like the one pictured above. I prefer to change when the truck is warmed up, so I use a deep oil catch can or you can rest your shallow pan on a wooden block so it’s elevated, that works too.
    Leomania likes this.
