1st time Tacoma Owner...but problems with MPG!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Riddler, Feb 28, 2013.
  1. Mar 1, 2013 at 11:56 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    X2 I did this and started getting 21mpg
  2. Mar 2, 2013 at 3:51 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Tacomas get shitty gas milage..
  3. Mar 2, 2013 at 4:31 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    Get a Scangage or Ultragage to watch your instantaneous mileage. That will take care of the driving habits side of things.
    A dirty MAF sensor could also be the culprit from the K&N. Before you replace the K&N I would clean the MAF sensor and see if the mileage goes up. It may have been the initial oiling that got it dirty.
    Most of the time it seems like the bed caps are roughly break even on mileage, so I doubt that is dropping you 5mpg.
  4. Mar 2, 2013 at 6:24 AM
    TexasCub
    TexasCub Well-Known Member
    2013 PreRunner
    Take that stupid K&N filter out, they are junk! Drive it for a few tanks and then report back.
  5. Mar 2, 2013 at 7:09 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Not 14-15 mpg in a 4 cylinder.. I think the op has something else going on..
  6. Mar 2, 2013 at 9:53 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Oops wrong thread...But My take is its a truck, MPGs should only be relevant on a Prius
  7. Mar 2, 2013 at 10:04 AM
    Larry
    Larry CARL
    CARL
    I think we need a sticky to remind members not to be offended when a new member asks a question that's been asked before. Just sayin'.
  8. Mar 2, 2013 at 10:28 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Brilliant :rolleyes:
  9. Mar 2, 2013 at 10:55 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Agree... but if most folks in a 4 cyl. Taco get 20-25 mpg, you got to wonder why he is only getting 15 mpg, right? 15 mpg is all I get if I am doing only city (stop and go) driving... but I have a double cab 4WD V-6. Once I get on the highway and cruise... my mileage instantly improves to 17-19 mpg.
  10. Mar 2, 2013 at 11:12 AM
    David K
    You are 100% correct! :)
  11. Mar 2, 2013 at 11:30 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    I can drive and get 12-14 or 20 w/ a 4WD. All depends on the pressure I put on the pedal....
  12. Mar 2, 2013 at 11:46 AM
    Eightball
    Eightball Member
    Boston, MA
    2013 MGM AC 4x4 V6 TRD Sport
    I think its the traffic man. I get 12-13 mpg with my V6. Spend 90% of my time driving in and around the city.
  13. Mar 2, 2013 at 11:54 AM
    BikPickle
    BikPickle Well-Known Member
    Nick
    NOVA
    12 TRD Sport
    You are in Boston Mass. Everyone's mpg goes to crap in the winter, even hybrids and electrics. The K&N was probably a bad call if you are concerned about MPG. Keep in mind, more cold dense air means the computer has to add more fuel to maintain the air-fuel mixture. You probably spend more time warming up your truck and idling too. Boston Traffic... Do I even need to say it!? Wicked retãdded. Add that to the crappy winter blend gasohol and presto... Crappy MPG.
  14. Mar 2, 2013 at 11:57 AM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    also the extra weight of the cap in the city kills mpg
  15. Mar 2, 2013 at 12:03 PM
    #35
    jimbowie
    jimbowie Member
    Jim
    north texas
    07 4dr prerunner v6 trd
    On the freeways I gt 22mpg drivng 65 to 75 mph.
    Just did a compete tune up transmison fluid change and rear end lub change hpe tha make it get better mileage.
    Also thinking about. GF Performance Chip Kit for the TOYOTA TACOMA
    jim
  16. Mar 2, 2013 at 7:46 PM
    #36
    worthywads
    Snake oil, don't do it.
  17. Mar 2, 2013 at 11:09 PM
    #37
    The Riddler
    The Riddler [OP] Well-Known Member
    Boston, MA
    17 Sport
    Thanks for all the help and insight.
    Went out to Central Mass tonight and had some positive results. The only mods I did was remove the charcoal secondary filter and added a K and N Filter. I filled up with sunoco 94 @ 4.00 bucks a gallon. I also checked the tire pressure and made it 30 psi. I drove 133.7 miles on 6.53 gallons for a an average of 20.47 MPG. It was about 50% highway. This is the best I got so far. I don't know if it was playing with the filters or sunoco 94 or tire PSI....Now it's back to city driving for about 60% of the upcoming work week. I will report back with averages.
  18. Mar 2, 2013 at 11:19 PM
    #38
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    K&N air filters are not that bad I used one in my old Camry and it got great mileage with it plus it all depends on how heavy you oil it
  19. Mar 2, 2013 at 11:29 PM
    #39
    worthywads
    Your I4 does not benefit from higher octane, waste of money.
    It also doesn't benefit from any intake mods for mpg.
    What was the tire pressure? That's the 1 thing you mentioned that certainly was hurting you if low. Try even higher than 30 psi.
    Highway driving is always good for mpg, at legal speeds.
    Topper usually makes it worse.
  20. Mar 2, 2013 at 11:33 PM
    #40
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    if you start the truck in AM and let it warm up, it eats like over a pint of gas an hour.... also sitting in traffic eats gas.
