1st tire rotation on a tacoma- where to use floor jack and stands safely?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverflash, Dec 9, 2019.
  1. Dec 9, 2019 at 7:48 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    My method only lifts one wheel at a time; but, I'm also doing a rear cross rotation...
    I digress...
    In addition to the owner's manual, the service manual provides additional jack locations.
  2. Dec 9, 2019 at 7:52 AM
    81shark
    81shark Well-Known Member
    I take the left side off... Then gently lower thst side and let it rest on the floor. Do the right side. And then come back and put the lefts on
    Works like a charm
    Tocamo likes this.
  3. Dec 9, 2019 at 7:56 AM
    MGMStudioTaco
    MGMStudioTaco Member
    Trey
    Charlotte, NC
    2018 MGM Tacoma Limited 4x4
    Grande Tires W/Kings
    ? you let your truck rest on the floor with no wheel
  4. Dec 9, 2019 at 7:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the owners manual suggests front to back rotations.
    pinochle, GreyBaldTaco and daddy_o like this.
  5. Dec 9, 2019 at 8:23 AM
    silverflash
    silverflash [OP] Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    i found a similiar graphic as you posted. so i plan on getting 2 6 ton stands, and will jack the rear up first with the aftermarket jack, place stands under the axles on both sides of the diff, remove jack and raise the front with the center jack point and the aftermarket jack and place stands right where the oem jack would go if i was using it. let me know if there is anything wrong with my plan. i of course will loosen all the lugs first before raising anything.
  6. Dec 9, 2019 at 8:26 AM
    scocar
    scocar Patron of the Farts
    I assume you have wheel chocks. I put on the brake and jack the front first for an extra measure of safety, and use wheel chocks back there too.
  7. Dec 9, 2019 at 8:43 AM
    silverflash
    Bill
    Harnett county NC
    so i suppose i should jack front up first while rears are on ground in park/braked and chocked. Then once front is up, lift rear...
    thanks..,
    scocar[QUOTED] likes this.
  8. Dec 9, 2019 at 8:59 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Get front to back skids, lift it off the ground like a Formula 1 car
  9. Dec 9, 2019 at 10:55 AM
    silverflash
    Bill
    Harnett county NC
    i got two 6 tons stands over lunch and tested them out. Without loosening the lugs i raised the front first, put them under the frame where the oem jack would go then lowered. all good, then went to the rear and raised the whole rear off the pumpkin. put my 3 tons under there, under the spring perches, and lowered. all good but the drivers side front touched the ground whereas passenger side front was off the ground some. So i will go back out after work tonight, loosen all the lugs and repeat what i did over lunch but this time will raise front a hair more before going to the rear....
    scocar likes this.
  10. Dec 9, 2019 at 11:15 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Some things should be trusted to the professionals. I am a strong supporter of the DIY crowd, but rotating tires just makes more sense to take it to a shop. Most tire shops will do it for free. 10 minutes and a $10 tip and you are on your way. Much easier than dragging around a floor jack and lugging around jack stands that will you will undoubtedly bust your shin on a few weeks from now because you forgot that they were sitting in the garage.
    TacomaCZman likes this.
  11. Dec 9, 2019 at 11:22 AM
    silverflash
    Bill
    Harnett county NC
    well, i have shelving for them, so that's not a problem. As far as a "professional" doing things like this:
    1) i have to get in my truck, drive there. now, that ones easy as a good place- as far as i know- is 3 miles away.
    2) i have to wait as they do it- that may mean an hour or more- time i don't really have during the day- i am not retired.
    3) i will check behind them to make sure the lugs are not overtorqued or cross threaded- this has happened to me an more than one occasion.
    4) it costs 20-30$ at least in my area- i am not cheap but see 3 above.
    5) i have a nice large garage.
    it's just easier for my head to do myself. i know it's done right. i have the tools. incompetence runs deep in most industries. i am big on safety. the main reason of this thread hovers around safety. i have always done one side at a time and never had issues. but the taco is higher than anything i've ever owned, even the xterra.
    until i am too worn out to do myself, i will keep doing myself.
  12. Dec 9, 2019 at 11:26 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I don't do rotations per say, I swap summers to winters. I lift the front, do both sides, then lift the back and do both.
    If I were to do a full rotation I would lift the back by the diff, put stands on the axles, then lift the front.
  13. Dec 9, 2019 at 11:53 AM
    scocar
    "Trusted professionals" will often scratch your wheels, overtorque, or forget to torque, your wheels. So no thanks not so much.
  14. Dec 9, 2019 at 11:56 AM
    scocar
    The driver side is heavier by default, so I recommend going a little higher than you think you need, lock and count the notches on your driver side stand, then do the same number of notches on your passenger side stand.
  15. Dec 9, 2019 at 11:58 AM
    #35
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    same. Its piece of mind.
  16. Dec 9, 2019 at 11:59 AM
    #36
    silverflash
    Bill
    Harnett county NC
    https://www.youtube.com/watch?v=i6IUE4ECuSs
    helps me alot.
    i will also say, i jacked the front up at an angle meaning the lack was probably at a 45 degree to the front center jack point so that could have caused the one side to be lower. i will move a plastic shelf in front of garage away and see if that matters. the video above mentioned that very thing.
  17. Dec 9, 2019 at 12:03 PM
    #37
    silverflash
    Bill
    Harnett county NC
    i took my son's 88 mustang gt to AAA car repair once. actually it was towed because of a fuel leak and he was overseas. anyhow, they said it needed tie rods as well. so while there they swapped them out. and did a radiator flush. and replaced some tank hose. was like $1500 total. Well, got it back drove the 10 miles home. next day, took it for a spin and heard a noise. all the lugs on one side were finger tight. rest were ok. their "master" mechanic was the last to touch it and they swore up and down they wouldn't do that. i really doubt someone loosened them in the hood as i didn't have any enemies or whatever. they offered $250 in free labor. we said no thanks. if you can't torque wheels properly, you are not touching my cars.
    the radiator juice looked like mud when my son did it 6 months later...
    so they didn't do squat.
    LOL
  18. Dec 9, 2019 at 12:04 PM
    #38
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You live in a very friendly area. 20 bux is cheapest here and you'll be there all day.
    bigmw and silverflash[OP] like this.
  19. Dec 9, 2019 at 12:34 PM
    #39
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Good video, I cringed every time he called his steps rock sliders.
  20. Dec 9, 2019 at 1:10 PM
    #40
    Sungod
    St Augustine
    Lots of places do it for free if you ask.
    Pep Boys - https://www.pepboys.com/auto-service-repair/tire-services/tire-rotation
    Discount tire will, but they will try to sell you balancing which isn't a bad deal
    NTB/Tire Kingdom/Merchants and whatever else they own charge $19.99, but since they match competitors, they will do it. Of course they will try to sell you lifetime balancing on your factory tires.
    Totally agree witht he all day issue. Unless I can make an appointment that they reasonably stick to, forget it. As well as the fact that if I can't watch them work, probably not worth it, but a well placed $10 spot up front and asking to hand turn the lug nuts and reminding them to use the correct torq stick along with hand torqueing the lug nuts it is usually painless.
    One thing about rotation on a rear wheel drive is that you don't need to do it as frequently as a front wheel drive. I usually go 15K for rotations which makes doing it myself even more of a hassle because I get lazy. What takes me 2 hours doing it myself with getting everything together, the work, the clean up, the beer break in between, etc. I can get in and out of a tire shop in 15 minutes if I time it right late on a rainy Wednesday afternoon.
    Dagosa likes this.
