1st to 2nd Gear Shift technique 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by specter208, Mar 29, 2017.
  1. Mar 29, 2017 at 9:50 PM
    su.b.rat
    su.b.rat broken truck
    the hang on that was worse than our 3.5's? our rev hang is pretty insane. getting on the highway is slowed so much while I'm hanging out in granny town.
    schmack b and specter208[OP] like this.
  2. Mar 29, 2017 at 10:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Its funny that I only really noticed that the first few weeks of owning my old 08 and then I adjusted to it and never really noticed it again, anxious to see how the my new 17 will act compared to my old 15.
  3. Mar 29, 2017 at 10:23 PM
    specter208
    specter208 [OP] Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Hey guys, what's the point of the annoying rev hang anyways?
  4. Mar 29, 2017 at 10:23 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Let it fucking eat!!!
  5. Mar 29, 2017 at 10:23 PM
    shakerhood
    Southern Ohio
    Have you had it very long? Maybe you are still just adjusting to it.
  6. Mar 29, 2017 at 10:24 PM
    shakerhood
    Southern Ohio
    That is an after effect of the Drive By Wire Crap.
  7. Mar 29, 2017 at 10:41 PM
    specter208
    California
    2 days.
  8. Mar 29, 2017 at 10:43 PM
    shakerhood
    Southern Ohio
    You will adjust to it for sure, give it a little more time and you wont even think about it.
  9. Mar 30, 2017 at 1:33 AM
    aquasurf
    aquasurf Member
    You can read about how rev hang works and why in my website.
  10. Mar 30, 2017 at 7:11 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    I dont know if anyone else has noticed this, but to me it seems like its a lot easier to get a quick shift into second if you agressively let off the throttle either as you press the clutch or slightly before. Something about jerking my foot off the pedal seems to let the truck come down in rpm quicker and without the dreaded rpm hang. Flow mods seem to help with the rpm hang too FWIW.
  11. Mar 30, 2017 at 7:56 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Just keep working at it and try different stuff until you get it smooth. I'm normally shifting around 2.5-3k in 1st and I don't rush it. You can help the revs down with the clutch if you quickly release to the engagement point and then slowly pull through it, releasing entirely once the revs have synced.
    It took me awhile to change my habits from my other car. Driving each smooth requires entirely different techniques.
  12. Mar 30, 2017 at 8:28 AM
    specter208
    California
    Wow, impressive knowledge.
    shakerhood likes this.
  13. Mar 26, 2019 at 8:27 AM
    TacoTruck33
    TacoTruck33 Member
    California
    2015 TRD OR manual access cab
    -Baja Designs Amber Fogs -3" lift/level kit -URD Quick Shifter
    You want to shift into second around 6k(after you hit the Rev limiter) and then do a gnarly 2nd gear burnout
  14. Mar 26, 2019 at 8:30 AM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Just practice. You'll get it.
  15. Mar 26, 2019 at 8:53 AM
    #35
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    2500 to 3500rpm, so the average is what, 3000rpm. Also, how quick are you throwing it? I imagine will have something to with it.....
    My wife is not smooth with this truck, but I find it VERY smooth.
  16. Mar 26, 2019 at 8:55 AM
    #36
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    I find that since first and second is suck a large reduction in gear ratio I like to get first to around 2-2500 ish rpm then quick wish the clutch and swift but not rough shift and slow off the clutch with minimal gas
  17. Mar 26, 2019 at 9:02 AM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    One thing that has been revealed is that our Tacos have individual throttle maps for each gear and neutral. That seems completely asinine to me. It was sort of masked on the stock and TSB tunes. I have been wondering how the ECU determines the gear and map since we only really have a neutral switch and switches on both ends of the clutch throw (I could be wrong). The delay of the ECU taking time to figure out RPM versus Speed could cause shift problems and inconsistency, esp between 1st and 2nd due to the greatest RPM difference.
    For me, I feel this is magnified with OVT Full Otto tunes since the bottom of the throttle and RPM range is much more effective.
    What I learned to deal with it is to never leave my foot completely off the throttle when up shifting. I'm still working on my muscle memory, but just keeping the slightest pressure on the pedal (5%?), makes thee nicest, smoothest shifts for me. I don't know what is going on inside the ECU with this, but it is working great. This technique does not seem to affect Rev Hang, which was lessened a bit with the TSB tune.
    This has worked for me while shifting at any RPM. Beyond that, I never try to shift in a particular range, just what feels right.
  18. Mar 26, 2019 at 9:04 AM
    #38
    WraeDeoHed
    WraeDeoHed Active Member
    2018 Tacoma TRD Off Road 6MT
    Extang Trifecta Tonneau Cover
    I find that I tend to skip 5th gear more than anything.
  19. Mar 26, 2019 at 9:10 AM
    #39
    shakerhood
    Southern Ohio
    Wow, that is interesting, never knew about the individual maps for each gear.
    tonered[QUOTED] likes this.
  20. Mar 26, 2019 at 9:13 AM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is absolutely crazy. A single map tune is being worked on.
    I could maybe see an in-gear and a neutral map, maybe? Seven maps is just wrong.
    On Map to Rule Them All! :D
    shakerhood[QUOTED] likes this.
