1st to 2nd Gear Shift technique 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by specter208, Mar 29, 2017.
  1. Mar 26, 2019 at 9:16 AM
    #41
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I agree, the factory way seems kind of a bizarre.
    tonered[QUOTED] likes this.
  2. Mar 26, 2019 at 9:39 AM
    #42
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    what is a throttle map? :anonymous:
    guessing it's the pedal response?
  3. Mar 26, 2019 at 9:40 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ha! Essentially, each gear has its own tune. This will just mess with the mind of most MTs drivers.
    shakerhood likes this.
  4. Mar 26, 2019 at 9:42 AM
    #44
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    ok gotcha. That's mental! Wonder why they did that...
    shakerhood and tonered[QUOTED] like this.
  5. Mar 26, 2019 at 9:45 AM
    #45
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Managers with too much time on their hands and engineers that don't say WTF?
  6. Mar 26, 2019 at 10:16 AM
    #46
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    This is totally unrelated but does anyone know if 5th gear is an overdrive in the 6mt or is 6th gear the only overdrive gear
  7. Mar 26, 2019 at 10:23 AM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Here you go:
  8. Mar 26, 2019 at 10:33 AM
    #48
    TacoJeff19
    Jeff
    19' DCSB OR
    Thanks!
  9. Mar 26, 2019 at 10:46 AM
    #49
    TacoTruck33
    TacoTruck33 Member
    California
    2015 TRD OR manual access cab
    -Baja Designs Amber Fogs -3" lift/level kit -URD Quick Shifter
    That's pretty wack. The URD Short Shifter helps a bunch
  10. Mar 26, 2019 at 11:12 AM
    #50
    Smk8609
    Smk8609 Well-Known Member
    2016 dcsb trd sport 4x4
    I honestly feel like i have used 5th gear about 20 times in the 3 years i have had my truck....
    goofydug and shakerhood like this.
  11. Mar 26, 2019 at 11:15 AM
    #51
    trackdaybro
    trackdaybro Well-Known Member
    Just wondering here, are there do’s and don’ts when it comes to OD gears? Like don’t pull a heavy trailer in 5/6?
  12. Mar 26, 2019 at 11:15 AM
    #52
    Smk8609
    I feel 3 - 3.5K is the sweet spot - what frustrates me more than anything is when you get it just right and the power delivery falls off at first then picks up, its almost like traction control is kicking in.
    TacoTruck33 likes this.
  13. Mar 26, 2019 at 11:16 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. Only go to 5th and 6th if you are truly coasting along.
    trackdaybro[QUOTED] likes this.
  14. Mar 26, 2019 at 11:27 AM
    #54
    TacoJeff19
    Jeff
    19' DCSB OR
    That's something I have been wondering as well. I don't have anything I need to tow right now but I'd like to know as well if I do. But if I had to guess I'd say use 4th for hills and most of the time. And maybe 5th for when it's flat or downhill.
  15. Mar 26, 2019 at 2:41 PM
    #55
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    Punch-it till redline in first Gear. Shift into second as fast as you can without letting off the gas.
    That's how it's done Son.
    Don't forget to post your timeslip
  16. Mar 26, 2019 at 2:52 PM
    #56
    Cement_Taco92
    Cement_Taco92 Beautiful Bearded Bastard
    Jeremy
    Roseburg Oregon
    2018 Cement Tacoma TRD Offroad
    Faux pro grille, plastidip wheels.
    Thats me and 6th gear in my AT. I put it in s mode and always stay in 5th. 4th in town.
  17. Mar 26, 2019 at 6:33 PM
    #57
    specter208
    specter208 [OP] Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    5th gear in the Auto is 0.72:1, that's the equivalent of 6th for us.
  18. Mar 26, 2019 at 6:53 PM
    #58
    iShiFT559
    iShiFT559 Well-Known Member
    2018 Tacoma OFF Road 4x4 6-SPEEDd
    Upgrade Mishimoto Weighted shift knob
    1st to second 2.75
    2nd to 3rd 2.50
    3rd to 4th 2.25
    1st thru 3rd gears are pretty clunking and it defently drives like a truck. 4th thru 6th if your good and have speed you can shift really quickly point to point and the clutch feels like its not really even doing anything and it will shift smooth like a car. I have a taller heavier shift knob, this will help. Took me some miles to get it down.
    Dont baby it too much, it should improve but I recommend getting a taller and heavy shift knob also, it will help with leverage.
  19. Mar 26, 2019 at 6:59 PM
    #59
    iShiFT559
    Dont take off too slow and let the RPM build! You will hate this truck if you drive that way.
    Dont baby it off the line.
  20. Mar 26, 2019 at 8:52 PM
    #60
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    I feel like my 6MT really started to break in ~30k miles, Now at 45k its like butter. Ok, not like my BMW was, but very good.
    Also, maybe its the nature of a truck transmission but to get into 1st gear smoothly, really need to be at ZERO mph (My german cars and iirc my old 4cyl 1st Gen would easily slip into first when not under load but not completely stopped.)
