1st Transmission fluid change at 123k ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bevans, Jul 3, 2019.
  1. Jul 3, 2019 at 7:47 AM
    bevans
    bevans [OP] Well-Known Member
    GA
    I bought my 2014 dcsb TRD OR prerunner with around 20k miles on it. In the beginning I did the oil changes and maintenance, then switched over to letting the dealership do the oil changes and brakes. I now have 123k miles but have never had the ATF changed or flushed. The dealership never mentioned it until this last weekend and said I was due for an ATF exchange for $275. I declined. I had my previous Tacoma (2007) until around 180k and never changed the ATF and never had any problems. My current 2014 runs perfect. However, I’m concerned if I really should have a change done. I e heard too many horror stories about high mileage vehicles have trans service done and then it failing.
    All of my miles are hwy miles, I don’t off road, and have only towed a light trailer a couple times for very short distances.
    I’m looking for opinions on this ATF service. I know I don’t want a full flush. I’m considering the drain/fill method, but am hesitant to mess with it at all. I’m changing the diff and plugs this weekend.. and just basically want opinions to see if I should even bother with a trans drain/fill.
    Thanks.
  2. Jul 3, 2019 at 7:52 AM
    11Bravo4x4
    11Bravo4x4 Well-Known Member
    Mitchell
    2018 Tacoma off road 4x4 quicksand
    DONT do a flush. DO a drain and fill.
    Do it every 30k from now on you’ll be fine.
    Just measure what comes out of your tranny pan and refill the exact amount back in with fresh fluid.
    I got my 3rd gen new and I’m doing drain and fill every 20k. About 4 quarts.
    goforbroke123 and spitdog like this.
  3. Jul 3, 2019 at 7:55 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I vaccinate. I see it as the same concept. Since 40k miles, I have drain and filled the transmission annually. Walmart Valvoline MaxLife ~$18 a gallon. YMMV.
    Plain Jane Taco likes this.
  4. Jul 3, 2019 at 7:57 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    What’s your logic
  5. Jul 3, 2019 at 7:58 AM
    11Bravo4x4
    Mitchell
    It keeps the fluid relativity clean throughout the life of your transmission.
  6. Jul 3, 2019 at 7:59 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Flush can dislodge sludge at that point is the logic I’m assuming he was implying. I did the same thing for my wife’s rx330 we got with high miles and no known maintenance record. I had them drain and refill tranny fluid around 120k, NOt flush
    goforbroke123 and 11Bravo4x4 like this.
  7. Jul 3, 2019 at 8:11 AM
    bevans
    GA
    Thanks for the replies!
    I just called the dealer to find out exactly what all is involved in the service. They say it’s a fluid exchange. That they hook it up to a machine that pulls all the old fluid out while filling it with new fluid. They clean the filter but do not replace it.
    Would you guys trust this exchange service at 123k miles.. I’m planning on a pretty big road trip in September from Georgia working my way out to Colorado and back to Georgia over the course of 9 days, so I’m trying to make sure everything is perfect.
    Thanks.
  8. Jul 3, 2019 at 8:15 AM
    11Bravo4x4
    Mitchell
    Sounds like a flush to me. That’s when they flush out the whole 13 quarts or so then replace all of it that’s where it’s risky because you MIGHT cause problems at your mileage and no history of doing Previous fluid changes. But I’m not sure.
    .. a drain and fill should just consist of taking off the drain bolt, draining what comes out. Measure what came out. (Assuming your already at the correct fluid capacity) And pump back in the same amount with a pump.
    It’s to easy. It’s a DIY in the garage.
    If you have the dealer do it make sure it’s only a drain and fill. Be specific that you DONT want a full flush.
    https://www.lowes.com/pd/hopkins-si...MIvp-Mh4WZ4wIVBavsCh17LAtXEAQYAiABEgJZtvD_BwE
  9. Jul 3, 2019 at 10:55 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I did this service myself at 20k miles and will continue at each 20k interval. Buy the Toyota WS fluid on Amazon, 4 qts. I use a gallon pump sprayer with a modified tip to put the new fluid back in. Then check the level by jumping the two pins. The tranny needs to be at the correct temp. to check the proper level.
    It takes about 3.2 qts.
  10. Jul 3, 2019 at 11:05 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I did a full flush with the pump sprayer method. There is a thread on here to show you how to do it. I refilled my A/T with Valvoline Maxlife ATf and one bottle of Lubegard. I also dropped the pan, cleaned the magnets and replaced the filter and gasket. My truck Runs like a charm.
  11. Jul 3, 2019 at 11:15 AM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Drain and fill, do NOT flush.
    Especially at that mileage and it’s never been touched.
    Do it yourself and save some money.
  12. Jul 3, 2019 at 11:36 AM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    I rolled the dice and did a full flush myself. Previous owner had put about 90k on it before I purchased and then I neglected doing it 'til 197k. I have no idea what he did. Yes, I know. Should have done it sooner.
    I read all the dangers and lots of people saying it was just coincidence if you have problems afterwards.
    Used WS fluid, changed the filter. Very little crud in the pan or any fine metal on the magnets. Fluid was a little darker but didn't smell burnt.
    Shifts smooth and no problems....yet. I will just do the drain and fill from now on.
  13. Jul 3, 2019 at 12:11 PM
    bevans
    GA
    How many miles have you put on since the flush?
    I keep reading mixed opinions too.. maybe I should have made it a poll, and just went with the popular vote.
    I don’t understand a lot about transmissions but from my research (which could be wrong) the fluid goes bad more from temperature than from mileage..
    so my thinking is that someone with 60k miles but offroads, tows, lives in hilly areas, or has mostly city miles puts more stress on and would have a trans in worse shape than my 123k mile truck that has been on street only, basically all hwy miles, flat terrain, doesn’t tow or off-road... am I correct in this thinking? And if so, would this make you choose the fluid exchange over the DIY drain and fill? I plan on keeping this truck and hopefully getting 250k-300k out of it and just want to do any maintenance I can to make sure of this.
  14. Jul 3, 2019 at 12:13 PM
    TacomaSport86
    If I were in your shoes I wouldn't hesitate on a full flush, pan drop, clean filter and magnets. Then going forward do a drain and fill every 30k miles.
    Freeheelbillie and Lawfarin like this.
  15. Jul 3, 2019 at 12:17 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    A flush isn’t going to hurt anything. If you have a problem after a flush, there was probably an underlying problem to behind with
    TacomaSport86 likes this.
  16. Jul 3, 2019 at 12:45 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I've done 3 full flushes in 216k miles, still running great. :fingerscrossed:
    Drain and refills are very easy, you can do one each week if you want.
  17. Jul 3, 2019 at 12:45 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Flush is in the book at 100k so at 115k I had mine done by the dealer as most of the trans fluid is in the torque converter not the pan.
    Shifted slightly smoother and noticed the torque converter locking up in 5th more firmly as it should. Opinions are many but to save a few dollars and loose a trans is very costly. The full flush runs thru the cooler too so the entire system is flushed. Your call.
    Lawfarin likes this.
  18. Jul 3, 2019 at 12:56 PM
    bevans
    GA
    I think I’m leaning towards letting the dealer do the fluid exchange ( I guess this is a flush, I couldn’t get them to say the word flush?)
    Hopefully all goes well.. and then I can do a drain and fill as needed after that.
    But am definitely open to others suggestions.
    Thanks.
  19. Jul 3, 2019 at 12:57 PM
    CTtoNoVa
    Pop N Lock
    I wouldn't worry too much. However, I would recommend driving as much as possible before embarking on this long trip so it happens near home vs on the open road.
    bevans[QUOTED][OP] likes this.
  20. Jul 3, 2019 at 1:27 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Honestly, don’t touch it. Let it ride....
    Blockhead likes this.
